Finally, a good screwdriver - Electrician Talk - Professional Electrical Contractors Forum
Old 06-13-2009, 10:27 PM   #1
Rewards Points: 6,421
Default Finally, a good screwdriver
Seems like someone's finally made a set of screwdrivers that might actually last, considering how I use (abuse) them:
http://www.lowes.com/lowes/lkn?actio...509&lpage=none
Old 06-13-2009, 10:43 PM   #2
Rewards Points: 300
Ain't those the ones with the steel shaft that's connected to the striking head? As in you can get zapped if you're touching the striking cap?
Old 06-13-2009, 10:43 PM   #3
Yes, but that causes me to ask what you'd ever do that for?
I'm thinking more along the lines of a purposed "beater screwdriver".
Old 06-13-2009, 10:45 PM   #4
Rewards Points: 300
I don't own them, I just remember them being talked about on another thread for just this reason.
Old 06-13-2009, 10:49 PM   #5
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
If you are stupid enough to use those screwdrivers on energized circuits - you deserve what you receive.
~Matt
Old 06-13-2009, 10:50 PM   #6
BIGRED's Avatar
Rewards Points: 1,006
I keep a beating screwdriver in my tool bag and use the good one in my pouch for beating, does that make sense?
BIGRED is offline   Reply With Quote
Old 06-13-2009, 10:55 PM   #7
cdnelectrician's Avatar
Rewards Points: 1,018
No, not really...but most of my beaters started off as good screwdrivers at some point. I have had a Klein screwdriver I use as a beater daily for 7 years or so.
Old 06-13-2009, 11:08 PM   #8
Rewards Points: 178
Doesn't anybody have any safety rules to follow regarding hand tools?
Bill
wptski is offline   Reply With Quote
Old 06-13-2009, 11:10 PM   #9
Rewards Points: 300
Yeah, pointy end faces away from you.
Old 06-13-2009, 11:10 PM   #10
Ohhh right, got to remember to carry a cold chisel and ball peen hammer in my pouch for tightening those pesky 1/2" locknuts...
Old 06-13-2009, 11:11 PM   #11
Ambassador of Amps
TOOL_5150's Avatar
haha yep thats what I was taught!
~Matt
Old 06-13-2009, 11:15 PM   #12
Rewards Points: 1,360
I have had the same beater Klein for 8 years now. A little touch on the grinder keeps it useful for turning screws as well..
Old 06-14-2009, 12:51 AM   #13
Rewards Points: 2,000
I own a pair.
They're not that great honestly, the tips on the flathead is already dented and I've only had them for a few months. Plus the top cap doesn't seem like it's made of a very hard steel since it dents almost as soon as your start beating on it.
I bought a mechanic's screwdriver that was cheaper and lasted longer than this.
Only reason why I scrapped that was because the top of the handles was made of this weird dark clear plastic that split in half one day, otherwise I really liked it.
My review? I wouldn't recommend them.
I think Wiha makes set with a striking cap. I would suspect theirs are of better quality.
Old 06-14-2009, 06:19 AM   #14
Rewards Points: 2,050
At $8.00 for a pair I am sure they are top quality.
Old 06-14-2009, 06:30 AM   #15
Well they look like junk !
Ill stick with my KLEINS or any thing i can find made in the USA.
Ya see now that HD and LOWES has took over the tool bussiness were going to get junk made cheap tools made by under fed children in china .
If you need a beater just use your helpers tools .Take care
Old 06-14-2009, 06:58 AM   #16
Tuckahoe Sparkplug's Avatar
Rewards Points: 25
I haven't bought a Stanley tool in years since I heard they moved their corporate headquarters off shore to avoid paying taxes in the U.S.
A bad day of fishing is always better than a good day at work.
Tuckahoe Sparkplug is offline   Reply With Quote
Old 06-14-2009, 08:25 AM   #17
Speedy Petey's Avatar
Rewards Points: 610
Some Wiha/Witte screwdrivers have the metal shaft going all the way through and exposed on the handle end. It's just not a mushroom like on theses Stanleys.
The steel is incredibly tough also.
Old 06-14-2009, 10:34 AM   #18
R.I.P. 2014
randomkiller's Avatar
I have the straight bladed model since the beginning of the year and have been beating on it regularly since then with no damage to the tip or handle. It works nice as a small pry bar as well.
"One Nation Under God"
Old 06-14-2009, 10:35 AM   #19
R.I.P. 2014
~Matt
I couldn't agree with you more. I remember the thread about that issue and thought you just have to be smarter than what you are working with.
Old 06-14-2009, 10:54 AM   #20
Really?
Like I said, my cap is very dented which leaves some sharp knicks around the edges, the handle around the shaft has come a little loose, and the tip is dented.
I'm gonna look into those Wihas.
With the exception of my Volkswagen (which was actually made in Brazil), German products rarely let me down.
Torque-limiting screwdriver KayJay Tools, Equipment and New Products 30 11-19-2011 03:28 PM
controls screwdriver pehelectric Tools, Equipment and New Products 16 09-19-2009 09:56 PM
wiha screwdriver conductivity unLucky17 Tools, Equipment and New Products 49 03-29-2009 06:40 AM
DeWalt Two-Position Screwdriver Kit - DW920K-2 REVIEW TOOL_5150 Tools, Equipment and New Products 19 01-10-2009 10:34 AM
Philips #2 holding screwdriver MNservicetech Tools, Equipment and New Products 11 06-09-2008 10:33 PM
