FYI For SeeSnake Micro Owners - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 07-02-2009, 11:51 AM   #41
I own stock in FotoMat!
Rewards Points: 6,520
Originally Posted by 76nemo View Post
.......... Why in the heck would you snake a camera 3' into a piece of thinwall or any pipe for that matter?
To look for rubble in large pipes under the slab.
Old 07-02-2009, 01:54 PM   #42
Rewards Points: 2,710
The head is smaller and the shafts are the same????????
Only time in the recorded history of man where men want a smaller head on their shaft.
Old 07-02-2009, 11:24 PM   #43
You've got alot better aim than me.
Actually, I was thinking more along the lines of pushing the camera from an existing box, out into a wall or ceiling cavity, not so much the other way around.
Something such as, if I want to investigate the inside of an interior plumbing wet-wall above and around an existing wall switch or receptacle, before cutting in a box to add a new wall sconce in a bathroom… etc, etc, etc… you see what I’m driving at.
I was primarily giving some examples of things that can’t be done with the present setup that I would like to have been able to do in the past and will most likely want to do again at some time in the future.
Old 07-04-2009, 06:27 AM   #44
Larry Fine's Avatar
Rewards Points: 150
Originally Posted by Dennis Alwon View Post
Actually a comma between SeeSnake's and they would have worked fine, Hackman.
Nah; a semicolon.
I laid in bed last night, looking up at the stars, and
I said to myself, "Where the hell is my ceiling?!"
Larry Fine, Master Electrician and
Electrical Contractor, Richmond, Va
Larry Fine is offline   Reply With Quote
Old 07-04-2009, 01:26 PM   #45
That's worth a buck twenty for ya'???????
Actually, it was $103.50 total, including UPS Ground delivery.
Old 07-07-2009, 04:39 PM   #46
So, now that I actually have the new camera head, I can say that the shaft is also definitely smaller in diameter than the old one. Just to give an idea of how small it is, it will pass through the hole of an MC connector with room to spare and will easily pass through a cable entry hole in a device box from the inside of the box. Apparently the new head is also compatible with the more expensive MicroExplorer camera as well.
Also, all of the Ridged camera heads are now made of machined aluminum, instead of plastic, so would be less likely to break if they get caught on something and you have to yank it back out.
Old 08-02-2009, 02:17 PM   #47
When the smaller head first came out I read someone saying how the field of view was worse and that the original size head gave a better image.
Kayjay, what is your opinion on that?
SideWorker is offline   Reply With Quote
Old 08-03-2009, 03:52 PM   #48
Yes, I would say that it is different, since it only has one LED and is half the diameter of the old head.
I look at it like this... If I can't get the camera head into the space where I need it, the brightness and field of view are the least of my concerns.
I consider it another accessory and still carry the old camera head as well as a 3-foot extension coiled up in the bottom of the case under the foam insert.
Old 08-03-2009, 04:34 PM   #49
Thanks for the info!
Where did you find a 3' extension?
Old 08-04-2009, 07:38 AM   #50
I got it from Coastal Tool.
Ridgid also has a new 6' extension available now as well.
link: http://www.coastaltool.com/hand_tools/ridgid/ridgid.htm
Business Owners' Cost Calculator Speedy Petey Business, Marketing, and Sales 48 10-08-2018 08:36 PM
Micro & Island outlet BIGRED General Electrical Discussion 62 03-12-2010 10:13 AM
Owners meter/ panel Magnettica NEC Code Forum 10 05-31-2009 08:51 PM
Owners panel preacher NEC Code Forum 22 03-09-2009 09:13 PM
owners salary capt1012 Business, Marketing, and Sales 5 10-08-2007 12:07 AM
