Harris TS22AL - Electrician Talk - Professional Electrical Contractors Forum
Old 08-10-2009, 11:59 AM   #1
Default Harris TS22AL
was given this butt, without instructions? ive changed the battey in it, but never have used one. any input?
Royston is offline   Reply With Quote
Old 08-10-2009, 12:08 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Originally Posted by Royston View Post
...... any input?
On how to use it, or how to get it to even work?
Old 08-10-2009, 12:34 PM   #3
Senior Moment
drsparky's Avatar
Rewards Points: 212
http://www.datacomtools.com/Manuals/ts22l.pdf
Old 08-10-2009, 12:40 PM   #4
Rewards Points: 1,564
Wow, drsparky, you are so above average. I went to the Fluke/Harris web site and couldn't even find the "AL" model. and you picked up on my Austin Powers quip in the pet peeves area.
ralpha494 is offline   Reply With Quote
Old 08-10-2009, 03:53 PM   #5
how to use and get it to work. the pdf didnt help at all
Old 08-10-2009, 04:19 PM   #6
Rewards Points: 27
What did the manual not explain?
Using one of these is not much different than just using a phone.
Bruce Wayne is offline   Reply With Quote
Old 08-10-2009, 04:49 PM   #7
ive connected it to the line to test the phone but get nothing. new battery in it no lights come on
Old 08-10-2009, 07:43 PM   #8
Check out this pdf from Fluke's website, it is the original operating and service instructions that should have come with the buttset.
http://www.flukenetworks.com/fnet/en...tegorycode=TTS
Thayer is offline   Reply With Quote
Old 08-10-2009, 07:46 PM   #9
Rewards Points: 6,421
The Ts22 is a pretty run of the mill buttset. I'm not sure what the AL is all about. Connect to the line, monitor or talk switch on the side. Not much to it. If you can't draw dial tone, the butt set is probably messed up.
Teach a man to fish and youve ruined a good business opportunity.
Old 08-10-2009, 07:59 PM   #10
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
Or the line is actually dead.
~Matt
Old 08-11-2009, 09:01 AM   #11
Royston, I'm assuming that you pushed the large black slide switch on the side of the test set into the up position. Otherwise the buttset will remain on-hook and do nothing.
P.S. The AL indicates that it is datasafe tester (won't disturb data circuits if you accidentally tie into one).
Old 08-15-2009, 02:43 PM   #12
I believe A means it has Amplified hands free speaker phone for use with voice prompts and L means data Lockout to keep you from going off hook and downing a data line, which was the next level up from the older TS22 DS, Data Safe model that I have. Its a nice butt set if you ever get it working.
