Help me Design a new Product - Answer 1 simple question - Electrician Talk - Professional Electrical Contractors Forum
View Poll Results: Would you prefer a Solenoid Wiggy trip a GCFI outlet when measuring from Hot to Gnd?
Trip 12 60.00%
No Trip 8 40.00%
Voters: 20. You may not vote on this poll
Old 06-14-2009, 09:05 AM   #1
Rewards Points: 27
Default Help me Design a new Product - Answer 1 simple question
Hello,
I work for a company that designs electrical testers. I am working on a new design, and would like a opinion from as many fellow electricians as possible. I only need seconds of you time, and for you to simply give me a 1 or 2 word answer. But, let me give you a brief background first.
I am designing a new wiggy "type" product. I am aware of all of the testers that are out there, both solenoid and solid-state. I have used them all, and know of the T+, Volt/Con, pure solenoid, etc. I am looking for a preference here, and do not want to know which units do what. So, this question is about a typical wiggy. Standard wiggy's will give about a 10K load to the circuit it is measuring. This is good to eliminate ghost voltages. But, and a standard outlet, this will give you about 12mA of draw. If you were to measure Hot to Gnd in a GFCI outlet with this wiggy, this would trip the breaker.
My question is..........Is this a plus, or a minus for you??? Some may say they do not want this to trip, so they can measure the voltage to ground. Others may say they like it tripping, because they know the ground is good, and so is the GFCI breaker. They can get the voltage level from Hot to Neutral So, please give me your 1 or 2 word answer........
If you use a "wiggy" in a GFCI outlet, would you prefer Trip, or No Trip????
Bruce Wayne is offline   Reply With Quote
Old 06-14-2009, 09:11 AM   #2
Chris Kennedy's Avatar
Rewards Points: 2,000
No trip. (T+ has a gfci button)
Old 06-14-2009, 09:29 AM   #3
Rewards Points: 27
Thanks,
But again, I'm not looking for suggestions of what other units like a T+ (that sells for $50) do. I'm saying that "if" you are using a $20 solenoid wiggy, do you prefer trip, or no trip.
Old 06-14-2009, 09:39 AM   #4
Rewards Points: 6,421
I know that before the three-light receptacle with the GFCI test button, many guys would "test" a GFCI with the Wiggy. That was their pass/fail test. I think you'd be screwing up a good thing if that capability was removed.
Old 06-14-2009, 09:46 AM   #5
R.I.P. 2014
randomkiller's Avatar
Not trip under normal test, trip with button only.
"One Nation Under God"
Old 06-14-2009, 09:50 AM   #6
william1978's Avatar
No trip. Trip needs to be an feature on the tester.
Old 06-14-2009, 09:58 AM   #7
Master Electrician
electricalperson's Avatar
Rewards Points: 2,002
the knopp k 60 is the best solenoid tester on the market
Old 06-14-2009, 10:27 AM   #8
R.I.P. 2014
And for helping out we all get a free tester, correct?
Old 06-14-2009, 10:34 AM   #9
I like this idea.
Old 06-14-2009, 10:56 AM   #10
R.I.P. 2014
Originally Posted by william1978 View Post
I like this idea.
Fair is fair.
Old 06-14-2009, 10:58 AM   #11
Fair is fair.
You know thats right.
Old 06-14-2009, 11:27 AM   #12
Trip
NevadaBoy is offline   Reply With Quote
Old 06-14-2009, 12:18 PM   #13
jbfan's Avatar
Rewards Points: 196
I like it to trip.
"The problem isn't that Hillary Clinton lies. We all know she lies. The problem is that her supporters don't seem to care"
jbfan is offline   Reply With Quote
Old 06-14-2009, 04:27 PM   #14
WELL BATTMAN NO IT DOESNT MAKE A DIFFERANCE . I like it to trip !!!
Sorry i just could not resist ! Take care Bruce
Old 06-14-2009, 05:30 PM   #15
Rewards Points: 27
The Knopp K-60 is a good example to use. Many feel it is the best Solenoid tester on the market today. The Knopp K-60 will trip a GFCI when measuring Hot to Gnd. My first thought was this unit could be even better, if it did not trip the GFCI, and allowed you to measure from Hot to Gnd. But, then I thought......You might be losing a "feature" you like by not tripping the GFCI. So, that is why I wanted to ask this question.
Yes, testers like the T+ will measure without tripping, and give you a button to test. I know some like this, but I kind of wanted to leave solid-state type testers out of this. That is why I wanted people loyal to solenoid type testers to reply. I wanted to know if they would be losing a feature. So far, the votes are for tripping, so it looks like I would be taking a desired "feature" away if a made a solenoid tester that does not trip.
It is still early, and I expect a lot more votes, so we will see where we end up. Thanks to everyone who has cast a vote so far.
Old 06-14-2009, 11:47 PM   #16
Rewards Points: 23,532
Not trip.
Old 06-15-2009, 12:53 AM   #17
Rewards Points: 25
No trip. Add trip button.
monitormix is offline   Reply With Quote
Old 06-15-2009, 10:16 AM   #18
Toronto Sparky's Avatar
Rewards Points: 1,008
Thats how I test a GFI
Bit of a pain when it's a GFI breaker that you were not aware of and the panel location is far away or unknown.
Old 06-15-2009, 11:01 AM   #19
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
Old 06-15-2009, 12:58 PM   #20
Rewards Points: 2,632
I want a Knopp size tester with long replaceable, flexible leads, solenoid and neon bulb, no trip, no continuity, I WANT a GO NO GO TESTER.
Home Depot sells a lesser grade product then the Wholesaler??? Jeff000 General Electrical Discussion 25 04-12-2009 01:12 PM
Could the industry use this product William Hayden Business, Marketing, and Sales 19 03-15-2009 10:47 AM
hopefully simple question troubleshooter Services and Service Equipment 3 09-02-2008 11:52 PM
simple transformer question hudb General Electrical Discussion 13 06-22-2008 11:51 AM
quick question from new member can someone answer this please! -Andy- UK Electrical Forum 0 10-04-2007 09:54 PM
