Help me Design a new Product - Answer 1 simple question - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
View Poll Results: Would you prefer a Solenoid Wiggy trip a GCFI outlet when measuring from Hot to Gnd?
Trip 12 60.00%
No Trip 8 40.00%
Voters: 20. You may not vote on this poll
Old 06-16-2009, 12:23 PM   #21
Rewards Points: 27
Come on all you viewers, how about a few more votes? I would like as many as possible. This thread has gotten 230 views, and only about 11 votes!!!
I have kept it simple.....A 1 or 2 word answer.
Please vote!!!!
Thanks,
Bruce
Bruce Wayne is offline   Reply With Quote
Old 06-17-2009, 09:25 AM   #22
My back hurts
Rewards Points: 25
No trip
John
JES2727 is offline   Reply With Quote
Old 06-17-2009, 07:52 PM   #23
gilbequick's Avatar
Rewards Points: 1,000
Options are good..... trip on command only.
Old 06-17-2009, 07:59 PM   #24
Rewards Points: 300
ditto
Old 06-17-2009, 10:39 PM   #25
Either Trip or a switch option to switch between trip and no trip (load or no load)
user438 is offline   Reply With Quote
Old 06-17-2009, 10:42 PM   #26
mattsilkwood's Avatar
Rewards Points: 2,006
i want an osha approved shock collar for a certain apprentice.
Old 06-17-2009, 11:00 PM   #27
william1978's Avatar
Rewards Points: 2,000
Sounds like you love this apprentice.
Old 06-17-2009, 11:02 PM   #28
Please vote!!!!
Thanks,
Bruce
If your wanting votes why don't you make this thread have a poll?
Old 06-17-2009, 11:14 PM   #29
Rewards Points: 27
Didn't know I could. I am new to this forum.
I'll try to set it up.
Old 06-18-2009, 12:03 AM   #30
Default trip/no trip tester
why don't you make 2 models, so people can choose?
heel600 is offline   Reply With Quote
Old 06-18-2009, 02:57 AM   #31
Trip.
NW Viking is offline   Reply With Quote
Old 06-18-2009, 01:21 PM   #32
Tabihu Juhar
76nemo's Avatar
Question
If you're looking at designing a dual impedance meter, sorry, but they have been out for years. Am I missing something into your intention?
Old 06-18-2009, 02:35 PM   #33
220/221's Avatar
Rewards Points: 4,164
I often utilize the trip "feature". The test button isn't always applicable.
For example, finding out if a downstream recep is on a particular GFCI.
There are cases where it has been an inconvienence like when you test something to ground not knowing it's GFCI protected then scratch your head because you thought it was just hot, but I have learned to work around that.
PS. On your new "wiggy" figure out a way to keep the leads from grabbing every doorknob I walk by. After 30+ years, that schit is getting old.
Old 06-18-2009, 05:34 PM   #34
You did good with the poll. I voted.
Old 06-18-2009, 08:49 PM   #35
Rewards Points: 27
Nemo,
You're not missing anything. I can't tell you exactly what I'm doing, because my competition could be reading too. I have a Idea for a tester that is not available today, and I think it will be welcomed. It will do things that no current tester available today will do. But, in adding these new functions, I also don't want to take away functions that some want.
The way people answer this question will tell me more than you think. It is not just about impedance, and GFCI tripping. This thread has been very helpful. When I have protos, I'll be happy to send some out for testing.
Thanks,
Bruce
Old 06-18-2009, 08:50 PM   #36
Rewards Points: 27
Thanks for the suggestion William!!
Old 06-19-2009, 01:19 AM   #37
Toronto Sparky's Avatar
Rewards Points: 1,008
But to those who did not notice it... go back to the first page and vote!
Old 06-20-2009, 12:32 PM   #38
Def Trip. A tester that trips on active to earth you can test for polarity and if the earth is in the incorrect spot. If it doesn't trip the earth and neutral could be reversed and you wouldn't know. Im talking about circuits on a safety switch here (im an Aussie sparky so im not sure what yank terminoligy is).
Having said that though I think we encounter different problems as your houses (correct me if im wrong) your houses have something like 150v and 240v while our houses only have 230v for everything. When I need to measure voltage and I dont want a trip I use a multimeter
spooky is offline   Reply With Quote
Old 06-20-2009, 12:51 PM   #39
Your welcome.
Old 06-20-2009, 01:40 PM   #40
Nemo,
Thanks,
Bruce
Well Bruce your secret is out once a person or inventor has publicity or exposed or open writings of any kind or meaning the web internet its kinda not a secure place to bring your new invention out or explain how it might work it does not have to be a detailed drawning or a document just the fact that you are talking about this here is not a good thing .
Iam just trying to help you do not take this the wrong way but look at the patent rules to apply for a patent first .
Heres why once you do this its now public knowledge meaning you cant get a patent on you invention or anyone else in your case your new tester .
This means after you have designed it built it went thur the bank to manufacture it your competition can legally make it with out your permission .
Take care
Home Depot sells a lesser grade product then the Wholesaler??? Jeff000 General Electrical Discussion 25 04-12-2009 01:12 PM
Could the industry use this product William Hayden Business, Marketing, and Sales 19 03-15-2009 10:47 AM
hopefully simple question troubleshooter Services and Service Equipment 3 09-02-2008 11:52 PM
simple transformer question hudb General Electrical Discussion 13 06-22-2008 11:51 AM
quick question from new member can someone answer this please! -Andy- UK Electrical Forum 0 10-04-2007 09:54 PM
