I need a new hammer drill. - Electrician Talk - Professional Electrical Contractors Forum
Old 09-14-2009, 03:11 PM   #1
Bababoee
captkirk's Avatar
Rewards Points: 2,030
Default I need a new hammer drill.
I am looking to get a New Hilti drill. I would like to be able to drill 2 inch core holes and drive ground rods with it. Which model would be best for this. I feel that the TE 70-ATC is a little to big for my needs. What would some of you recomend...? I was also considering a Metabo KHE56 but im not sure if it is strong enough for the rods. Any help would be appreciated.
Old 09-14-2009, 03:23 PM   #2
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
480Sparky has a Hilti.. you should get in touch with him
He uses it for ground rods also
I have a Makita, but will go the Hilti route some day also
Old 09-14-2009, 03:30 PM   #3
Mad Skills
Celtic's Avatar
Rewards Points: 2,050
I would go with a
TE 50 Combihammer
Drilling range: 1/2" - 2".
Optimum drilling range: 5/8" - 1".
The:
TE 70-ATC Combihammer
Drilling range: 1/2" - 6".
Optimum drilling range: 7/8" - 1-3/4".
Active Torque Control provides added operator protection.
....is probably too much tool for a typical EC.
póg mo thóin
Old 09-14-2009, 04:06 PM   #4
DGFVT
John's Avatar
Rewards Points: 172
Go with the Hilti 50.
My TE17 is 30 + years old and still is going. The Ramset is god only knows how old ....and it's still going.
Attachment 1838
Old 09-14-2009, 04:13 PM   #5
I own stock in FotoMat!
Rewards Points: 6,520
Mine isn't a hammerdrill. It's a demo hammer.
Old 09-14-2009, 04:19 PM   #6
Mad Skills
Celtic's Avatar
I've got a TE 22 [like your 17] "full metal jacket".....it died.
póg mo thóin
Old 09-14-2009, 04:44 PM   #7
mattsilkwood's Avatar
Rewards Points: 2,006
we have a te-56, so far it does everything its needed to do.
it will run a 2" core no problem.
most definately get the ground rod driver, that thing is great.
Old 09-14-2009, 05:34 PM   #8
DGFVT
John's Avatar
Rewards Points: 172
To get a ground rod driver take a old sds dirll, cut the drill part off, weld a 3/4" piece of pipe to it....and now you got a ground rod driver. See posted picture.
Old 09-14-2009, 05:38 PM   #9
DGFVT
John's Avatar
Rewards Points: 172
I have had it repaired a couple times, and it still works like new. New plastic tools suck.
Old 09-14-2009, 06:42 PM   #10
Mad Skills
Celtic's Avatar
I've done that with my RA drill...while it was laid up, bought another
póg mo thóin
Old 09-14-2009, 08:06 PM   #11
Rewards Points: 6,421
My "every day" hammer drill is a Milwaukee 5321-21. Does 90% of what I need it to. I regularly core 5" holes and drive ground rods with it. It's usually about 500 bucks wherever you buy it.
Product Description
This 2in. rotary hammer delivers outstanding drilling performance in a lightweight package. The on/off switch is coupled with a speed dial so that the speed and blow energy can be correctly matched to the application or accessory. The bit locking system features one-handed click-in bit insertion. U.S.A. Cordless: No, Rated RPM: 190 - 385, Amps: 13, Variable Speed: Yes, Solid Bit Capacity (in.): 2, Core Bit Capacity (in.): 6, Hammering Modes: Hammering Only, Hammering with Rotation, Blows Per Minute (BMP): 17,000 - 34,000, Case Included: Yes
Product Details
Old 09-14-2009, 08:28 PM   #12
DGFVT
John's Avatar
Rewards Points: 172
Product Description
Product Details
After 100 hours of use a service light will come on, and you will have about 8 hours of use left before the tool shuts down, and the tool will need to be serviced by a Milwaukee service center.
How many times has this happened to you?
Old 09-14-2009, 08:32 PM   #13
Not yet, but that's a pretty common feature on the bigger drills. They have a switch on the carbon brush holder. Pretty nice idea. Keeps you from running the drill on the carbon brush springs. It will be a pretty cheap repair when the light comes on. It gives you a good excuse to have the gearbox refilled with grease, have all the concrete dust blown out of it, and so fourth.
Old 09-14-2009, 10:56 PM   #14
Rewards Points: 518
Te-55
crazyboy is offline   Reply With Quote
Old 09-15-2009, 11:31 PM   #15
Bababoee
captkirk's Avatar
Ive decided to go with the Metabo. My supply house gave me a great price on the KHE 56. For the money I got a lot more drill than the same amount spent on a Hilti. They even threw in the ground rod driver and a 13" bit all for 650. I would have been silly to turn it down.
Old 09-16-2009, 05:52 PM   #16
Mastertorturer's Avatar
This looks very nice to me.
http://makita.ca/index2.php?event=tool&id=823&catid=2
Mastertorturer is offline   Reply With Quote
Old 09-16-2009, 06:01 PM   #17
B4T
B4T's Avatar
That is a good price.. they were listed for $735.00 on Google
Here is a specs page:
http://www.metabo.us/Product-catalog...62403cf.0.html
Old 09-16-2009, 06:29 PM   #18
Power Engineer
Rewards Points: 25
I have a TE7A
and an TE60
Both great to work with! Plus Hilti has a great service dept.
JvH87 is offline   Reply With Quote
Old 09-16-2009, 08:39 PM   #19
Bababoee
captkirk's Avatar
Originally Posted by JvH87 View Post
I have a TE7A
and an TE60
OOOOO the TE 60 is the one I wanted but a little more money than I wanted to spend on a drill. Looks like a real nice machine..
Old 09-17-2009, 05:25 AM   #20
Power Engineer
Rewards Points: 25
Over here in the Netherlands they have a Hilti leasing program. You lease the machines for 4 years, after 4 years you get a new machine for 4 years and so forth.
But, TE 60 is worth the price. Had an TE 50 before, also a great drill!
Hammer Drill Recomdations Chris Simms Tools, Equipment and New Products 28 02-07-2009 09:21 PM
cutler hammer Louieb General Electrical Discussion 6 11-08-2008 08:59 AM
My New Hammer Drill (pictures!) Frasbee Tools, Equipment and New Products 31 09-29-2008 10:56 PM
DeWalt Hammer drill Chris Simms Tools, Equipment and New Products 8 08-11-2008 11:29 PM
funny looking hammer paul d. Off Topic (Non Trade) 14 07-17-2008 05:50 PM
