Ideal 61-732 clamp meter - Electrician Talk - Professional Electrical Contractors Forum
Old 07-02-2009, 03:35 PM   #1
Rewards Points: 50
Default Ideal 61-732 clamp meter
Hey does anyone else have one of these meters? Does your NVC button make a loud screech or does it beep? I'm also at a loss when it comes to using this thing to read amps using the clamp. How exactly do I get a reading? Do I have to set it to Amps? Will it also detect voltage using the clamp or only amperage?
I wish this thing came with a manual
Toronto is offline   Reply With Quote
Old 07-02-2009, 04:31 PM   #2
Master Electrician
electricalperson's Avatar
Rewards Points: 2,002
usually it will only read amps if its in the amp mode
Old 07-02-2009, 08:26 PM   #3
Richard Rowe's Avatar
Set it to amps chose the aprox ampage place the wire(only the hot wire no ground and only one wire) then you should get a reading. The leads will be used to check voltage and set it to volts first. If you look on their web site you should be able to get instructions,
Richard Rowe is offline   Reply With Quote
Old 07-02-2009, 10:54 PM   #4
gilbequick's Avatar
Rewards Points: 1,000
Set the dial to the Amperage setting, which is the "A", and put the clamp around the neutral (white). Remember, if there's no load there will be no reading. There has to be current pulling through.
Old 07-02-2009, 11:29 PM   #5
Rewards Points: 50
Alright thanks. I understand how to read amperage with the clamp but this NCV button is still a mystery to me. I sounds like a dying birds last screech. The manual on the Ideal site says it should beep when I press it.
Old 07-02-2009, 11:40 PM   #6
Rewards Points: 27
The "dying bird" sound is normal for this Ideal clamp. I know it sounds bad, but that is how it is designed. It is not really a beep.
How much did you pay for it? Lowes has the 61-746 (True RMS Version) on sale for only $69.
Bruce Wayne is offline   Reply With Quote
Old 07-02-2009, 11:45 PM   #7
Rewards Points: 50
Thanks for clearing that up. I thought the speaker may have been defective. The online manual says the ncv button allows the meter to be used like a pen tester, reading non-contact voltage.
I got this meter and a bunch of other tools from a friend, payed way less than retail.
Btw what does True RMS mean anyway?
Old 07-02-2009, 11:59 PM   #8
Rewards Points: 27
True RMS is a more accurate meter. If a meter is not TRMS, it just does a peak-to-peak reading. This is fine for probably 90% of the time. But, when reading noisy signals, square waves, offset waveforms, etc, then TRMS gives a better reading.
If you bought it used, then I know you paid less than $69. The 732 is actually an older model, and has been replaced by the 61-744.
Old 07-03-2009, 12:02 AM   #9
Rewards Points: 27
BTW,
You can print out a pdf of the 61-732 manual here:
http://idealindustries.com/support/instructions.do
Old 07-03-2009, 09:40 AM   #10
Rewards Points: 178
Not so. Many are average reading AC meters and as far as peak to peak, many TRMS meter don't have that function built in but you calculate it, RMSx1.414=PP.
On top of that many meters are AC-coupled TRMS which isn't "really" TRMS. The "real" TRMS function will say AC+DC. In Fluke DMMs, only the high end meter have that function.
Bill
wptski is offline   Reply With Quote
Old 07-03-2009, 10:36 AM   #11
Chris Kennedy's Avatar
Rewards Points: 2,000
root mean square
Old 07-03-2009, 11:03 AM   #12
Rewards Points: 27
I was trying to give a short and simple answer, without going into a lot of detail. I wasn't trying to say that a TRMS meter gave a peak-to-peak reading (RMSx1.414). I was trying to say that a averaging meter (which is a non-TRMS meter) only looks at the total peak-to-peak signal, and just gives a average RMS reading. In other words, it does not take into account a DC offset, or noise on the signal, or a distorted waveform, square wave, etc. A TRMS meter will sample the waveform at many points, and a non-TRMS will just take a average reading (based off the peak-to-peak signal).
Old 07-03-2009, 11:18 AM   #13
Rewards Points: 27
For "pure" waveforms, simple conversion coefficients exist for equating Peak, Peak-to-Peak, Average (practical, not algebraic), and RMS measurements to one another:
Bear in mind that the conversion constants shown here for peak, RMS, and average amplitudes of sine waves, square waves, and triangle waves hold true only for pure forms of these waveshapes. The RMS and average values of distorted waveshapes are not related by the same ratios:
This is a very important concept to understand when using an analog meter movement to measure AC voltage or current. An analog movement, calibrated to indicate sine-wave RMS amplitude, will only be accurate when measuring pure sine waves. If the waveform of the voltage or current being measured is anything but a pure sine wave, the indication given by the meter will not be the true RMS value of the waveform, because the degree of needle deflection in an analog meter movement is proportional to the average value of the waveform, not the RMS. RMS meter calibration is obtained by "skewing" the span of the meter so that it displays a small multiple of the average value, which will be equal to be the RMS value for a particular waveshape and a particular waveshape only.
Old 07-03-2009, 11:32 AM   #14
Senior Moment
drsparky's Avatar
Rewards Points: 182
Get a O'scope never worry if the waveform is deformed again!
Old 07-03-2009, 11:52 AM   #15
Rewards Points: 27
I'd like to see the tool belt that unit fits in.
Old 07-03-2009, 12:10 PM   #16
Rewards Points: 178
I've seen a Fluke T5 measure incorrectly on a sine wave signal that wasn't really distorted that much!
Bill
Old 07-03-2009, 12:25 PM   #17
Rewards Points: 27
A Fluke T5 is not TRMS.
Old 07-03-2009, 01:31 PM   #18
Senior Moment
drsparky's Avatar
Rewards Points: 182
I bought one of these a few years ago at a government surplus sale for $75. It is a very good scope and has about every function available when it was made in the late 70s. Yes it does not fit in my tool bag.
Old 07-03-2009, 03:33 PM   #19
heavysparky's Avatar
Rewards Points: 614
I have the 61-766 and it does the same thing.
does the 61-732 have "tight sight"
heavysparky is offline   Reply With Quote
Old 07-03-2009, 03:52 PM   #20
Rewards Points: 178
Yes, I know that but the pont is that it didn't take very much to fool it!
Here's good page about the AC-coupled TRMS meters: http://www.enginova.com/true_rms_volts.htm
Bill
Fluke 322 clamp meter twintask Tools, Equipment and New Products 8 06-02-2009 05:02 PM
For Sale: 400 AAC IDEAL Clamp Meter (NEW) CraneTech Electrician Swap 3 05-10-2009 05:44 PM
The uses of a clamp on meter msrjony General Electrical Discussion 6 11-21-2008 12:30 PM
Ideal clamp meter randomkiller Tools, Equipment and New Products 27 10-07-2008 10:47 PM
Clamp Meter Littlejim82 Tools, Equipment and New Products 51 09-26-2008 07:12 AM
