Klein lineman - Electrician Talk - Professional Electrical Contractors Forum
Like Tree90Likes
Old 12-31-2018, 02:52 PM   #1
Default Klein lineman
Best way to break in new pliers
Julian65 is offline   Reply With Quote
Old 12-31-2018, 02:57 PM   #2
Rewards Points: 1,509
Return them and buy Knipex. They come smooth as glass from the factory.
Old 12-31-2018, 02:59 PM   #3
Rewards Points: 14,229
Take them back to the store. Even Milwaukee pliers work straight out of the package and they’re half the price.
0day likes this.
Old 12-31-2018, 03:09 PM   #4
MTW
Rewards Points: 10,228
I've tried all the methods suggested here on the forum and have concluded that nothing works all that well. Return them if they are too tight and always take them out of the package first and test the tightness of the rivet before buying. Or buy any of the other brands out there - Milwaukee, Knipex, Greenlee, Channelock, Ideal, etc.
jelhill and Mr. Lacarno like this.
Old 12-31-2018, 03:16 PM   #5
IMO, the best method is to spray them with brake cleaner to remove all the grease/oil and then exercise the crap out of them. That helps smooth out the internal surfaces that rub together. Then afterwards re-apply good oil and you're done.
But it takes a lot of work, like sitting there opening and closing them for hours.
glen1971 likes this.
Old 12-31-2018, 03:16 PM   #6
Rewards Points: 3,994
I've had good success over the years using Hilti Spray lubricant in the joint, then work them open and closed to flush out any grease.. I don't think it took that long to do, if memory serves. Once they're loose, maintain them.. When (not if) you use them as a beater, use the right side to beat with.. If you use the side that you can see the center pin moving, eventually you'll wind up mushrooming it and they'll be stiff again..
HackWork (12-31-2018)
Old 12-31-2018, 03:21 PM   #7
This is SOOO damn true.
Most people use the side with the cutters because the entire face of it is solid, but that side is where the center pin comes thru. When you hit something you "stake" the metal, which makes it harder to open/close.
You have to use the side with the opening, there is less meat on that side to hit with, but the pin is solid there so no worries about making them harder to operate.
Here is an example of staking something. It's an extreme example, but it shows what happens with pliers if you hit with the wrong side:
Old 12-31-2018, 07:20 PM   #8
Rewards Points: 1,961
I know this is an unpopular opinion among electricians, but Estwing makes a tool to keep from mushrooming your linesmans pliers
Old 12-31-2018, 07:28 PM   #9
Rewards Points: 2,236
Valve grinding compound does a nice job breaking in pliers. Apply it to the joint betwen the 2 halves of the pliers and work it up through the joint.
When it is lose enough wash it out with a lubricant. I use SLICK50. make sure you get it all out. Best of luck and happy new year.
LC
Old 12-31-2018, 07:29 PM   #10
And it works well, when you have it nearby.
Old 01-01-2019, 12:17 AM   #11
Rewards Points: 1,260
I can't believe you people whack things with the flat of the pliers. That's totally awkward. You hammer with the narrow edge.
stuiec and jelhill like this.
Old 01-01-2019, 12:21 AM   #12
Estwing makes the BEST non-mushrooming implement .
MechanicalDVR and glen1971 like this.
Old 01-01-2019, 07:15 AM   #13
Elderly Member
jelhill's Avatar
Rewards Points: 1,090
Ideal
jelhill is offline   Reply With Quote
Old 01-01-2019, 07:18 AM   #14
Elderly Member
jelhill's Avatar
WD-40 has worked for me before. Sad... Klein used to never have these problems... seemed to start around the late 90s.
Old 01-01-2019, 08:05 AM   #15
Elderly Member
jelhill's Avatar
Stamping says "M. Klein & Sons - Chicago, Ill U.S.A." Belonged to my wife's grandfather... looks like he was whacking a lot of things with the flat side!
Old 01-01-2019, 08:23 AM   #16
Southeast Power's Avatar
Rewards Points: 8,716
What if you just are not ready for that kind of professional leap?
I can only seem to buy Klein Klein's and Channellock Channellock's
MechanicalDVR and jelhill like this.
The Following 2 Users Say Thank You to Southeast Power For This Useful Post:
jelhill (01-02-2019), MechanicalDVR (01-01-2019)
Old 01-01-2019, 09:00 AM   #17
Originally Posted by jelhill View Post
Ideal
And Channellocks. I think Channellocks made the linemans for Ideal at one point. The Channellocks are like ten dollars less and really nice...
jelhill likes this.
Old 01-01-2019, 09:37 AM   #18
I always hammer with the broad side, not the edge. But you have to hammer with the broad side that has the big cut-out in the cutter area, not the completely flat side.
Old 01-01-2019, 09:48 AM   #19
I never looked, I take it that's always the side that has the pin staked / peened in the hole, and not damaged because it doesn't rotate anyway...
But but but that's like slapping things instead of chopping them, or throwing like a girl, you aren't - I don't know - you can't wind up or something.
jelhill likes this.
Old 01-01-2019, 09:51 AM   #20
Yes, exactly.
I was taught that you never hit the little lineman guy (who is on the side with the cut-out in which the pin rotates on Klein pliers).
It's the same amount of force, but a broader head. The edge is rounded and more likely to slip off and hit your hand.
Private non union Lineman schools offshoredreaming Linework 13 03-04-2018 08:47 PM
I want to be a lineman... NavyVet88 Linework 4 11-02-2016 10:47 AM
Albat or lineman school linecall Linework 1 06-12-2016 12:58 AM
Union j-man's tool list MechanicalDVR Tools, Equipment and New Products 57 05-27-2016 11:59 AM
