Klein PVC cutter - Electrician Talk - Professional Electrical Contractors Forum
Old 08-13-2009, 03:05 PM   #1
mikeg_05's Avatar
Rewards Points: 258
Default Klein PVC cutter
Anyone used the klein pvc cutter for 1/2'' upto 2''? Do they work well? I can't imagine spending 150 bucks on them, maybe there is a knock off that works as well or better for cheaper?
Old 08-13-2009, 03:19 PM   #2
Rewards Points: 2,002
I have one. I'm not very impressed with it and I have never used it. A sawzall is better and quicker IMO.
Old 08-13-2009, 03:22 PM   #3
Speedy Petey's Avatar
Rewards Points: 610
I have the 1/2 to 1-1/4" version and it is excellent quality. The only thing that comes close is the Lenox version, which if I am not mistaken only does up to 1".
I have never used the 2" model, but it look very big.
Old 08-13-2009, 03:34 PM   #4
Electrical Savant
lectricboy's Avatar
Rewards Points: 250
This is as cheap as I could find. I don't know if it's Chinese junk or not. Might be worth a look.
http://www.flexpvc.com/cart/agora.cg...s-Pipe-Cutters
lectricboy is offline   Reply With Quote
Old 08-13-2009, 04:38 PM   #5
gilbequick's Avatar
Rewards Points: 1,000
Ditto on that, I have the same one. It cuts smooth and I would take it over a sawzall any day.
Old 08-13-2009, 07:26 PM   #6
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
I've got the same one and I love it,,,but I see two problems with it 1) it won't work on cold pipe,,,only warm 2) My helper tightened it up until the blade contacted the pipe, realizing he was off the mark slightly and no way to release the blade, he twisted it,,,,CRACK!! 80 dollar blade broke.
Old 08-13-2009, 07:32 PM   #7
Rewards Points: 610
What??? You can't just pull the big one open like you can with the small one?
What a dumb design.
Old 08-13-2009, 08:53 PM   #8
mikeg_05's Avatar
Rewards Points: 258
That seems like a deal breaker at 150+ dollars
Old 08-13-2009, 10:03 PM   #9
Rewards Points: 530
After going through 2 brasscraft PVC cutters, I got the Klein version that does 1/2" to1 1/4" for $70. Ive had it for the past 3 years and it has cut more pipe on the original blade than both my brasscrafts did combined including a replacement blade on the first one.
SEU installer
electro916 is offline   Reply With Quote
Old 08-14-2009, 02:48 AM   #10
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
Brasscraft is cheap HD junk
~Matt
Old 08-14-2009, 05:34 AM   #11
Master Electrician
electricalperson's Avatar
i use a hacksaw
Old 08-14-2009, 10:10 AM   #12
Originally Posted by electricalperson View Post
i use a hacksaw
You also enjoy taping split bolts and use a hawkbill knife, so I guess I shouldn't be surprised.
Old 08-14-2009, 12:22 PM   #13
william1978's Avatar
Rewards Points: 2,000
I use the klein 1/2--1 1/4 perfect for cutting pvc when watching masons.
Old 08-14-2009, 04:52 PM   #14
R.I.P. 2014
randomkiller's Avatar
I have the small Klein and love it. I have a Ridgid that goes to 2" and find it faster and cleaner than a saw, no deburring and no sweeping up in a finished space. I got it on Ebay for @$55 with shipping, in the business section.
"One Nation Under God"
Old 08-14-2009, 05:22 PM   #15
Rewards Points: 300
I have a Lenox that I use up to 1'', and a Ridgid for the bigger stuff. I can't remember what I payed for the Ridgid, but it wasn't enough to make me want to use a hacksaw.
Old 08-14-2009, 09:40 PM   #16
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,028
i have a cheap (50$) chineese knockoff of the greenlee that goes up to 2.5 inch and i like it
Old 08-15-2009, 02:24 PM   #17
Rewards Points: 524
Buy the plumbers Ridgid pvc cutter its far nicer and much cheaper.
Jeff000 is offline   Reply With Quote
Best Bx/Mc cable cutter Chevyman30571 Tools, Equipment and New Products 111 08-24-2014 10:04 PM
Blue handle and Red Handle Klein Diagonal cutter? Chevyman30571 Tools, Equipment and New Products 19 07-20-2009 09:05 PM
TKO hole cutter mikeg_05 Tools, Equipment and New Products 11 06-26-2009 01:49 PM
KO cutter brian john Tools, Equipment and New Products 28 02-20-2009 06:43 PM
Klein 87904 Tool Belt pad *For you Klein Fans* gatti Electrician Swap 2 05-03-2008 10:56 AM
