Knipex 10" channel locks... gotta be a joke. - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree25Likes
Old 10-14-2018, 09:07 PM   #41
Rewards Points: 973
I've been using the same set of non-quick adjust 10" cobras for 30 years. They really are the best channys you can buy and I've tried all the major brands. I've been thinking about getting a new pair because mine are just now starting to lose the edges on the jaws.
Old 10-14-2018, 09:20 PM   #42
Rewards Points: 1,914
Those are a different model than the OP has, TGGT. Yours function more like the RoboGrip, if you remember that. Bob Villa
I just got them and wanted to show them off. I'm looking forward to using them tomorrow. I said they were $50 earlier, really closer to $60, but they'll make work much easier on this job.
I didn't figure their capacity would be larger than the 10" cobras if you can see it in the comparison photo, but it was a pleasant surprise.
HackWork likes this.
Old 10-15-2018, 06:54 AM   #43
HVAC
Tortuga's Avatar
Rewards Points: 76
I said something about using the same pair of Alligators for 10+ years on the HVACtalk forum. I was told that must be because I don't actually do any work with them. Idiots. Best pair of pump pliers I've ever owned.
Tortuga is offline   Reply With Quote
Old 10-15-2018, 09:11 AM   #44
Cow
Rewards Points: 5,262
I love internet forums.
Because there is always someone out there who has to act smarter than you....
Old 10-15-2018, 02:05 PM   #45
Rewards Points: 3,084
I am definitely going to look into these red button Knipex. I wanted something like the cheesy Robogrips for compression fittings. To me not having to fiddle with the pliers is better than any other feature, I don't really need a kung fu grip on the fitting.
I have a set of the cheaper knipex, the ones with the groove adjustment not the button. I like the shape of the jaws but I never got them to do that automatic lock thing they show you in the videos. I like the box joint, and I like that they are light and narrow, and don't pinch you. However I do seem to get a better grip on pipe with Channellocks and Channellocks pricing is like half Knipex these days. I like the fatter handles of the Channellocks when squeezing as hard as possible. I have had more than one occasion where Channellocks on the pipe and knipex on the coupling, or vice versa, and the knipex was the first to slip. The handles on the knipex don't lend themselves to reaming pipe, that's a small advantage for the Channellocks.
After a few real piss me off hand pinching incidents this last year I have been using the Knipex unless there's really a need for the grip power of the Channellocks. Since both are perfectly fine for 95% of tasks, I have been using the one that doesn't bite.
#HACKLIVESMATTER
Old 10-15-2018, 03:16 PM   #46
No Longer Here
Rewards Points: 578
The ones that the OP posted with the red button still need to be adjusted by hand, the only difference is that you don't have to press the button to close the jaws, only to open them. The model that TGGT posted is like the RoboGrip.
splatz (10-15-2018)
Old 10-15-2018, 03:34 PM   #47
Now I remember I looked at those but didn't buy them because they only made one size and they weren't big enough for 1" compression fittings.
#HACKLIVESMATTER
Old 10-15-2018, 04:46 PM   #48
Did you see my photo? That's the jaws fully extended to 2". Though $120 for a pair is a bit much.
The Following User Says Thank You to TGGT For This Useful Post:
splatz (10-15-2018)
Old 10-15-2018, 04:54 PM   #49
I did not notice that ... can you get a good grip on 1" fittings with one hand? I can't see if the handles are too far apart.
I don't care about a super strong grip installing compression fittings, just strong enough to get them reasonably tight, the main thing is a pliers that auto adjusts with one handed operation.
#HACKLIVESMATTER
Old 10-15-2018, 05:00 PM   #50
I can easily operate them with one hand. I'll take pictures tomorrow.
YouTube them, there's a video of a guy using them.
splatz (10-15-2018)
Old 10-15-2018, 05:09 PM   #51
No Longer Here
Rewards Points: 578
For such a specific use, why not just use the RoboGrips?
Old 10-15-2018, 05:28 PM   #52
I have been using them. I hate them. The junkiness bugs me. They are laminated from sheet metal, weak as hell if you twist them. They are gigantic and clunky.
#HACKLIVESMATTER
Old 10-15-2018, 07:07 PM   #53
Rewards Points: 341
They definitely fit 1 compression.
With slipping OP are you taking slipping off pipe or slipping close when they are opened to a certain point? The quick slide ones do suck. After they are well worn they do slide way too easy but IMO the regular ones are the best channel locks around
Smid is offline   Reply With Quote
The Following User Says Thank You to Smid For This Useful Post:
splatz (10-15-2018)
Old 10-15-2018, 08:20 PM   #54
Rewards Points: 431
Originally Posted by soc_monki View Post
Cobras are amazing. I had channellocks and never liked the slip joint on anything. Used the Irwins but they wear out too fast and are clunky. Knipex know what they're doing. I swapped to Knipex linemans, a whole set of Cobras from 5 inch to 12 inch, the cable shears, and the 7 inch pliers wrench. All of them have performed and never left me feeling I've paid too much. However, I prefer channellock e338 diagonals to the knipex variety, they seem to cut easier.
If I got a bad set of anything I'd just warranty them. It happens.
I feel pretty much the same way. Mostly preference but Knipex has never let me down and I prefer their combination pliers to more traditional NE nose linesmans. The only exception is that like you, I do not prefer their diagonal pliers. I had both 8 and 10 inch angled head models. I actually think their dipped grips are far superior to others in feel and adhesion to the metal handles. They just didn't fit my hand quite the way I wanted and the angle was just a bit different to the Kleins. This is one tool where I think Klein is the perfect example. Head size, angle, sharpness, etc. The D2000-48 with dipped grips are the best for me. No knock on the Channies or Knipex. Quality is great.
Satch is offline   Reply With Quote
Old 10-16-2018, 10:03 AM   #55
Here's photos of a 1" locknut. I got small hands and its effortless to apply the locking pressure, in fact I accidentally deformed the locknut taking the picture.
splatz (10-16-2018)
Old 11-28-2018, 05:28 AM   #56
3rdUserName's Avatar
Rewards Points: 14
****ADMIN**** I am the original poster on this thread, (woot) if an admin can send me a link to reset the password I would appreciate it. If that's not possible, or against forum rules, that's fine as well. Thanks anyway.
3rdUserName is offline   Reply With Quote
Old 11-28-2018, 05:46 AM   #57
Rewards Points: 14
Knipex sent me an email for a new design a few weeks back... intreasting. I cant seem to post the screen shot. But it Looks cool. I gotta run. Check in and try again at lunch. But I'm sure other guys got the same email that are more fluent on here then I am, if u could drop the pic, or link another thread if it's been addressed, that would be great.
Old 11-28-2018, 06:16 AM   #58
daveEM's Avatar
Rewards Points: 2,382
Admin will never see your post likely. Putting a '@' sign in front of a user name will flag the user that they have been mentioned in a post. Curiosity takes over.
@Cricket < She will now see this and hopefully take care or your problem.
MechanicalDVR and Cricket like this.
I like perfect.
Old 11-28-2018, 10:24 AM   #59
Administrator
Cricket's Avatar
Rewards Points: 6,006
I sent you a PM with my contact information. There is also a contact us link at the bottom of every page.
"Show respect even to people who dont deserve it, not as
a reflection of their character, but as a reflection of yours."
Cricket is offline   Reply With Quote
The Following User Says Thank You to Cricket For This Useful Post:
John Valdes (11-28-2018)
Old 11-30-2018, 06:02 AM   #60
Rewards Points: 14
Thanks, I emailed u back bud. I seem so lost on here with posting pics and notices I receive or dont receive. Have things changed or am I under some "newbie" posting restrictions or something?
Big A** channel locks vs knipex 22 cobra? Smid Tools, Equipment and New Products 16 03-08-2018 10:34 PM
Knipex 10" 8702250 cobra pliers with comfort grip JRelectrician Tools, Equipment and New Products 40 05-26-2016 01:17 PM
