Knipex pliers (Channel locks) - Electrician Talk - Professional Electrical Contractors Forum
Old 09-30-2009, 06:07 PM   #1
mikeg_05's Avatar
Rewards Points: 258
Default Knipex pliers (Channel locks)
What is the difference between the cobra pliers (channel locks), and the alligator pliers?
Old 09-30-2009, 06:41 PM   #2
mattsilkwood's Avatar
Rewards Points: 2,006
The adjusting mechanism. The alligator is a slip joint design and the cobra actually locks in place.
Old 09-30-2009, 06:47 PM   #3
mikeg_05's Avatar
Rewards Points: 258
which would you recommend?
Old 09-30-2009, 06:53 PM   #4
I personally like the cobras. I like the fact that if I'm say running 3/4 pipe I don't have to mess with them, I set them once and they're set for all day.
Some guys don't like the fact that you have to press the button to adjust them (too many moving parts I guess) but after useing them for about 5 years now I won't use anything else.
Old 09-30-2009, 07:19 PM   #5
Speedy Petey's Avatar
Rewards Points: 604
100% agree!
Now, that said, I also have the new self-adjusting SmartGrip. They are awesome.
You also HAVE to get a Pliers-Wrench.
Old 09-30-2009, 07:33 PM   #6
Originally Posted by Speedy Petey View Post
100% agree!
I saw the smartgrip the other day. Coming from knipex I'm sure they are top of the line. Have you had them long enough to put them through the paces?
I've got two pairs of the 16" cobras which have replace my old 460s, and I've also got a pair of 22" cobras, they are bad*ss.
Old 09-30-2009, 07:57 PM   #7
Rewards Points: 604
I can't say I've used/abused them real hard yet, but I do use them pretty much every day. They are holding up real well. They had better for what they cost.
Old 09-30-2009, 08:18 PM   #8
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Did Channel locks sell out?
I never heard of "Knipex" till there was a thread running here for the past few days
Old 09-30-2009, 09:55 PM   #9
Rewards Points: 604
Seriously?
German made and only the best there is.
Old 09-30-2009, 09:59 PM   #10
Rewards Points: 2,256
In my opinion and I have run a lot of rigid in my time Knipex are the best for running rigid. Channellocks the teeth will only last about 6 months and thin I would sharpen them with a file and they might last about 4 more months if you are lucky.
If all you are running is EMT the Channelllocks will last several years and they are not as expensive.
I use both and what ever comes out of the bucket first is what I use.
Old 09-30-2009, 10:09 PM   #11
Rewards Points: 2,000
Honestly?
I really like Channel lock, I feel like they're less fickle than the Alligator pliers.
My only complaint against Channellock are the few times I've pinched my fingers when torquing the tool. Plus, Knipex doesn't have the big ones Channellock, does.
Today, I had the best of both worlds, using both the 12'' Alligators, and the 12'' channellocks (which actually open up larger). Alligators are nice because they can cradle the shape of the coupling, but really, between the two, it's a toss up. I keep them both on me because I feel as if they're comparable.
Never had an issue with channel's teeth, either, and I've had mine for 2 years now.
Old 09-30-2009, 10:16 PM   #12
Originally Posted by Frasbee View Post
Honestly?
I have a pair of 22" knipex cobras, that's pretty damn big. I don't think I've ever seen a pair of chanel locks that big.
Just because I've never seen them doesn't mean they don't exist.
Old 09-30-2009, 10:28 PM   #13
That is pretty damn big.
But they're not alligators.
There is a slightly larger pair of alligators that I don't own, so I'm assuming they're comparable to what my 12'' channels are already able to achieve.
Old 09-30-2009, 10:28 PM   #14
B4T
B4T's Avatar
Seriously?
Now I have a good reason to go shopping and buy some tools
Old 09-30-2009, 10:31 PM   #15
I own stock in FotoMat!
Rewards Points: 6,520
Christmas is only 85 days away!
Old 09-30-2009, 10:42 PM   #16
B4T
B4T's Avatar
Everyday is Christmas when you work for yourself, I bet you agree
Old 09-30-2009, 10:45 PM   #17
Yea it looks like in the alligators they make a 250mm and a 300mm. Thanks to google I know that is 10" and 12".
Old 09-30-2009, 10:49 PM   #18
Darn tootin!
Old 10-07-2009, 09:48 PM   #19
Rewards Points: 31
Default Knipex Cobra
Honestly?
Actually Knipex has a 22" version that has a bigger capacity than the Big Ass from Channellock almost 5" pipe
Tulbox is offline   Reply With Quote
Old 10-07-2009, 09:59 PM   #20
I just discussed this with the other guy.
I'm referring to the Alligators, not the Cobras, which is what you're referring to.
If this is incorrect, link please.
knipex lineman pliers 481apprentice Tools, Equipment and New Products 96 11-28-2013 02:22 PM
Re: 'Pump Pliers'. Reasons I prefer Knipex to ChannelLock brand BP_redbear Tools, Equipment and New Products 24 05-01-2010 10:48 PM
Sweet Knipex Pliers & Wrench In One Aiken Colon Tools, Equipment and New Products 35 10-22-2008 12:25 AM
Locks on Main Service Disconnect. pudge565 NEC Code Forum 2 07-29-2008 11:38 PM
Use for channel locks/pump pliers? iAmCam Tools, Equipment and New Products 29 05-27-2008 03:03 AM
