Multi Tool - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 09-21-2009, 08:22 AM   #21
Rewards Points: 25
I cut out a receptacle in my own home when I first bought a Rotozip. I actually bought the Dewalt version of a Rotozip since it's beefier and came highly recommended. I used a Rotozip brand 1/8" tile cutting bit since that is what Rotozip recommended for plaster.
That one single gang cut in my kitchen wall put a layer of dust on EVERYTHING in my house, even 3 rooms away. It was unbelievable, definitely the last time I used a Rotozip in a finished house.
Electriad is offline   Reply With Quote
Old 09-21-2009, 06:32 PM   #22
My exact reason I don't care of the Rotozip also is that the dust it makes. Also if you use it to cut in boxes in a siding blocks they take off like a bat out of Hell. I may buy the Craftsman and let you guys know how it is.$100 isn't too bad. Everyone made fun of me when I bought my little Bosch 10v pistol drill for plugging and switching now I see alot of people using them.
Spoolin03 is offline   Reply With Quote
Old 09-21-2009, 07:02 PM   #23
Rewards Points: 150
Originally Posted by Speedy Petey View Post
To say Multimaster blades are expensive is a huge understatement. I thought Rotozip bits were pricey until I saw those things.
Here is a link to an alternate supplier that is less and seems to work according to some people I have talked to. I can not vouch for the blades, I do not own a Fein.
http://www.imperialblades.com/store....des&navt1=7444
2008 NEC
wingz is offline   Reply With Quote
Old 09-21-2009, 08:37 PM   #24
Head Grunt
Rewards Points: 266
I use the Roto-zip for most tasks but i also bought the Dremel multi tool. I dont use the Dremel very often but when i do use it the Dremel seems to be the only option for what i am doing so it does have its place. For the few times i use it dragging around the cord is no big deal, hell the Roto-zip has a cord too.
No free man shall ever be debarred the use of arms.-Thomas Jefferson
woodchuck2 is offline   Reply With Quote
Old 09-21-2009, 09:31 PM   #25
gilbequick's Avatar
Rewards Points: 1,000
The Dremel Mulit-Max and Bosch blades will fit some of the Fein's. They're much less pricey than the Fein brand.
Old 09-21-2009, 10:44 PM   #26
Rewards Points: 300
I have the Dremel Multi-Max. It works great as long as you keep it within it's limitations. I'm personally a Rotozip person myself, but as others have said, the dust can be a problem sometimes.
Old 09-21-2009, 11:45 PM   #27
R.I.P. 2014
randomkiller's Avatar
I think MD is on the right track, the Rotozip is the way to go most often. I tried the Fein vibrator and found out the hard way that on plaster with wood lathe it will shake the plaster loose at the opposite end of the lathe and cause other problems for you.
"One Nation Under God"
Old 09-22-2009, 10:21 PM   #28
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,028
bosch is also making a cordless 12v multi tool
Multi-family dwelling calculations Speedy Petey NEC Code Forum 4 10-05-2010 08:27 PM
multi meter which manufacturer is the best [email protected] Tools, Equipment and New Products 15 10-14-2009 10:13 PM
Multi-trade Inspectors william1978 General Electrical Discussion 12 05-10-2009 07:09 PM
Multi function tester needed davino Electrician Swap 1 08-17-2008 05:11 PM
Service on Multi Family Dwelling romexrocket Services and Service Equipment 6 10-11-2007 10:24 PM
