new tool - Electrician Talk - Professional Electrical Contractors Forum
Old 01-27-2009, 07:36 PM   #1
Shunt trip
Default new tool
I am looking for feedback on this new tool design. Thank you
Dave from Spokane
Check out the new conduit reamer
shunt trip is offline   Reply With Quote
Old 01-27-2009, 08:11 PM   #2
mattsilkwood's Avatar
Rewards Points: 2,006
i wouldnt pay that for it.
it looks like it will work, but im not sure it would be any faster. i mean how long does it take to ream a small pipe.
the one for bigger pipe might be alright though.
Old 01-27-2009, 09:10 PM   #3
I own stock in FotoMat!
Rewards Points: 6,520
An old-fashioned Klein reamer is a whole lot lighter and compact than a cordless with something that unweildy hanging out the business end of it.
Magnet to reduce filings in the pipe? Fine, but how do you clean it? and how often?
Old 01-27-2009, 09:12 PM   #4
Rewards Points: 6,421
I sometimes keep a mostly worn out unibit in a drill when I have a lot of pipe to cut and debur. I don't worry too much about deburring the O.D. as long as it goes in the fitting.
Old 01-29-2009, 08:56 PM   #5
Shunt trip
Default New tool design
Thanks for the feed back guys. Yea, I've heard a lot of those responses. Most electricians are skeptical of it at first, then I let them use it for a week.
So far, 90 % of the testers like it,
50% buy one, The other 50% just want to keep the one I gave them to test.
Dave from Spokane
Old 01-29-2009, 09:09 PM   #6
Originally Posted by shunt trip View Post
.....Any body want to test one???
Can you get me a big enough commercial job that would force me to want to use one?
Old 01-29-2009, 09:32 PM   #7
jbfan's Avatar
Rewards Points: 226
Same here!
"The problem isn't that Hillary Clinton lies. We all know she lies. The problem is that her supporters don't seem to care"
jbfan is offline   Reply With Quote
Old 01-29-2009, 09:54 PM   #8
gilbequick's Avatar
Rewards Points: 1,000
I'll try one.
I'm on a very big commercial job right now and all I do is run pipe all day long, mostly 3/4''. With the Ideal hand reamer you can pull out the reamer end and chuck it in a drill, that's what I do. I'd love to try your reamer and compare it.
I've got a lot of guys I work with and if you send me one to try I'll pass it around and get their feedback too. Let me know.
Old 01-29-2009, 10:11 PM   #9
Shunt trip
Default big comm job
OK, but you only get one big job each.
That is where it shines, on Big comm jobs, then it really shines.. you get used to it quick then you start to see how versatile it is, No packing & changing tools, (just tips) Way faster, No putting away the klien and grabing the drill to mount the pipe, its the same tool, it eliminates tools & steps, Hexagonal drive allows the body to slip right off the magnetic tip holder shank, Its smaller in your toolbox than the old Klien. No wrist wrenching, Tuff, in 2 years of testing we never broke or destroyed a blade. The future is scary...way more high tech stuff coming..
I hate change... Thats why i always challenge it.
Dave from Spokane
Old 01-29-2009, 10:22 PM   #10
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
I looked at your site twice. I think I would like to try it. Will it fit in a 1/4" quick connect?
~Matt
Old 01-29-2009, 10:54 PM   #11
Mighty Rat
Minuteman's Avatar
Rewards Points: 250
I'll try it!
Proud dad of Sgt. Mickey, USMC 0311
"The Few, the Proud, the Infidel."
Battalion Landing team 2/4, 11th MEU
Minuteman is offline   Reply With Quote
Old 02-01-2009, 09:41 PM   #12
Shunt trip
Default New tool
Thanks for the feed back,
A small pipe? One? not much time difference. But if you got a pipe rack or stubs coming out of the slab, and lots of them, You would be amazed at the time difference. Remember, you are not packing several screwdrivers Just a few tips. You also do not have to change tools, As soon as you ream the pipes(1/2",3/4" & 1") you can assemble, same tool, also screw your straps down & tighten fittings.
Are Screw guns faster than wrists?
Tool slips on/off hexagonal Magnetic tip holder shank.no tools required. More versatile, just change tips if needed.
No wrist wrenching. no tool bags of screwdrivers hanging off your hip.
This tool is designed for commercial use, it shreds conduit clean, quick, in & out, ensuring a better ground also. Blade is hardened to Rockwell +60
Dave from Spokane
Old 02-01-2009, 09:44 PM   #13
Fair warning... if the guys who have indicated that they want to test one don't get one, this thread and any signs of anything you ever posted will evaporate.
Old 02-01-2009, 09:47 PM   #14
Shunt trip
Default New tool
~Matt
Thanks for the feed back.
Yes it will fit in a quick connect, It will also accept any 1/4' hex shank bits/tips.
Dave from Spokane
Old 02-01-2009, 10:07 PM   #15
Shunt trip
Default new tool
Thanks for the input.
I clean it with a swipe of a cloth or glove.
On a commercial job (rough in) I use a cordless all day, for drilling, screwing boxes, tightening fittings, etc. This tool allows constant assembly with out changing tools. It is there when you need it, & rarely interferes with other work, or better yet, slips off if you need more clearance. More versatile, accepts any 1/4" hex tip. (less stuff hanging off your hips.)
Also, in 2 years of testing we have never broke or wore out a blade.
All tools can be dangerous. Use with care.
Dave from Spokane
Old 02-01-2009, 10:20 PM   #16
Ambassador of Amps
TOOL_5150's Avatar
Ok I do want to try it then. I am not in comercial work, but being able to ream and strap the pipe with the same drill does sound usefull.
~Matt
Old 02-01-2009, 10:24 PM   #17
Master Electrician
electricalperson's Avatar
Rewards Points: 2,002
slap a 5/16 chuck in one of those and you got yourself a nice conduit tool
Old 02-01-2009, 11:01 PM   #18
Shunt trip
Your point is well taken, I only send out 1 tester at a time for 30 days, first come, first served. Gilbequick is first. then 5150.
That is enough testers for now,
Thank you to everyone who responded.
Minuteman I sent your part yesterday.
Dave from Spokane
Old 02-01-2009, 11:27 PM   #19
Shunt trip
Default 5/16" chuck
Are you refering to a nut driver?
Dave from Spokane
Old 02-02-2009, 05:36 AM   #20
gilbequick's Avatar
I think he is, and with your setup that shouldn't be a problem at all.
Name this tool John Tools, Equipment and New Products 11 09-30-2012 02:37 AM
Paging all tool hounds, tool **** inside NC_Electrician Tools, Equipment and New Products 128 09-11-2010 02:08 PM
new tool nick Tools, Equipment and New Products 8 07-09-2008 05:02 AM
New Tool Mike228 Tools, Equipment and New Products 5 06-17-2008 10:05 PM
Help! I need a tool bag. shotdown General Electrical Discussion 2 07-06-2007 07:14 PM
