Outlet tester with buzzer - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
Old 09-28-2018, 08:28 AM   #1
Rewards Points: 1,373
Default Outlet tester with buzzer
I am looking for something like this:
That particular model is discontinued and it also looks junky, definitely not worth $50.
I want an outlet tester with a buzzer for both circuit identification as well as troubleshooting. I want it small and compact so I will always have it with me.
Ultimately I would like it to also have a load built into it, something that I can turn on when I want to put a load on the circuit, but I doubt I would ever find that, at least not in a small package.
Old 09-28-2018, 08:34 AM   #2
Rewards Points: 10,943
I use a heat gun to test under load. A jobsite radio turned up full blast works if you want to make noise .
MechanicalDVR and telsa like this.
Old 09-28-2018, 08:43 AM   #3
Dark Knight's Avatar
Rewards Points: 120
Why do you need it to have a buzzer? For IDing the circuit from downstairs flipping breakers?
Dark Knight is offline   Reply With Quote
Old 09-28-2018, 08:46 AM   #4
Rewards Points: 2,172
For identification I use a 120 volt Sonalert on a 18' piece os 18/2 SO cord. The one I use has screw terminals that I have doubled up some heat shrink on also used ring lugs for the connection. I also have a a 2 wire female cord end with insulated alligator clips for attaching the sounder to wires.
I have been using this set up for years and it works fine.
You can get the Sonalert from Newark or Allide Electronics.
LC
Old 09-28-2018, 09:01 AM   #5
The heat gun and jobsite radio are two separate devices that are very large and not something I would bring into a quick troubleshooting service call and carry with me all the time. They are the exact opposite of what I asked for, but I figured you would be trolling the second I saw your name.
Possibly. More importantly it works well too leave plugged into a dead outlet while working on other parts of the circuit.
The_Modifier likes this.
Old 09-28-2018, 09:18 AM   #6
Rewards Points: 120
I’ve thought about something like that very often, but have never seen anything. Haven’t really looked either. I just use my NCVD and rig it to stay in the right place while I do my thing. If the house isn’t too big and is quiet I can usually hear it from the panel too.
HackWork likes this.
Old 09-28-2018, 09:35 AM   #7
Iíve thought about something like that very often, but have never seen anything. Havenít really looked either. I just use my NCVD and rig it to stay in the right place while I do my thing. If the house isnít too big and is quiet I can usually hear it from the panel too.
Yeah, Iíve done that too. And half the time it ends up falling out just enough not to make contact LOL.
I saw a little plug-in buzzer at my supply house for $25. If Iím going to carry it Iíd rather have it be an outlet tester as well.
Old 09-28-2018, 09:53 AM   #8
Rewards Points: 120
Yeah, I’ve done that too. And half the time it ends up falling out just enough not to make contact LOL.
I saw a little plug-in buzzer at my supply house for $25. If I’m going to carry it I’d rather have it be an outlet tester as well.
Not to mention the 30 frustrating seconds it takes to get it to sit just right and then half the time it moves anyway.
I’ve never seen even just a buzzer. If I saw one for $25 I’d probably grab it. But I agree, ideally it should be all in one, otherwise it’s just one more tool to carry around, which probably means another trip back to the truck when you realize you need it.
Old 09-28-2018, 11:33 AM   #9
Rewards Points: 15,351
Attachment 129250
I never knew they had that. Now that I have seen it I want one badly, but alas even Ebay didn't come up with anything......
Old 09-28-2018, 11:54 AM   #10
Rewards Points: 3,376
Reliance THP109
http://www.reliancecontrols.com/Prod...il.aspx?THP109
The Following 2 Users Say Thank You to splatz For This Useful Post:
macmikeman (09-28-2018), niteshift (09-28-2018)
Old 09-28-2018, 12:17 PM   #11
Nice! A little big, but it will work just fine.
No you need to help me wire a 500W load inside of it
Old 09-28-2018, 03:42 PM   #12
MikeFL's Avatar
Rewards Points: 2,376
Plug your load into the receptacle below.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 09-28-2018, 03:50 PM   #13
I don't want to have to carry a second item.
Old 09-28-2018, 05:03 PM   #14
86 45 20
Southeast Power's Avatar
Rewards Points: 7,706
How about a heat gun and a kazoo?
MechanicalDVR, daks and Max C. like this.
Old 09-28-2018, 05:36 PM   #15
I'm always willing to share my immense knowledge and wisdom, Hack.
Old 09-28-2018, 05:39 PM   #16
MikeFL's Avatar
Tie them together with a string and you only have to carry one.
GPS Timers
(833) GPS-TIME
Old 09-28-2018, 05:42 PM   #17
Learn how to balance a bucket on your head .
MikeFL likes this.
Old 09-28-2018, 05:50 PM   #18
You two should get a room together in the Icantread hotel.
MikeFL likes this.
Old 09-28-2018, 06:01 PM   #19
You should put a cord end on a fire horn.
MikeFL likes this.
Old 09-28-2018, 06:21 PM   #20
Rewards Points: 880
i have always used a tracer. Mine has 2 sender units one for power, one for dead. If i use the live one once i turn the breaker of the sender dies and confirms i have the right circuit.
Now a buzzer comes in useful to hook between a breaker and the wire when you are playing find the short.
Need help. Iím baffled - dead outlet E-Rack Residential Electrical Forum 7 09-14-2018 10:06 PM
Knob + tube and non-contact voltage tester false positives MSW General Electrical Discussion 15 08-20-2018 07:22 PM
Old outlet stuck to plate rant bostonPedro General Electrical Discussion 3 05-19-2018 11:43 AM
adding an outlet off a Dimmer switch iluvspl General Electrical Discussion 2 01-19-2018 08:14 PM
Running outlet off exsisting one COwboys518 General Electrical Discussion 5 03-02-2017 06:55 PM
