Outlet tester with buzzer - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
Old 01-13-2019, 09:24 AM   #21
Mensa Player
Rewards Points: 1,333
I am looking for something like this:
Attachment 129250
That particular model is discontinued and it also looks junky, definitely not worth $50.
I want an outlet tester with a buzzer for both circuit identification as well as troubleshooting. I want it small and compact so I will always have it with me.
Ultimately I would like it to also have a load built into it, something that I can turn on when I want to put a load on the circuit, but I doubt I would ever find that, at least not in a small package.
Still looking for this.
Old 01-13-2019, 09:29 AM   #22
Rewards Points: 4,712
https://www.electriciantalk.com/f14/...8/#post5086696
Old 01-13-2019, 09:32 AM   #23
http://www.etcon.com/ct105.htm
MechanicalDVR (01-13-2019)
Old 01-13-2019, 10:18 AM   #24
Rewards Points: 1,926
Originally Posted by Southeast Power View Post
How about a heat gun and a kazoo?
LOL!
Only you bro!
Old 01-13-2019, 10:21 AM   #25
That sure beats a kazoo!
HackWork and splatz like this.
Old 01-13-2019, 11:34 AM   #26
Rewards Points: 1,110
Attachment 129250
Here is a 2 in 1 tester from Commercial Electric.
Maybe?
The description makes it unclear if it beeps when plugged in or just as a voltage detector
https://www.homedepot.com/p/Commerci...4GFI/300254856
bostonPedro is offline   Reply With Quote
Old 04-14-2019, 02:53 PM   #27
joe-nwt's Avatar
Rewards Points: 776
I needed a live cct tester to identify ccts without turning breakers off in phone exchange. I ran 3 100W lightbulbs through a timer set to cycle off and on every 2 seconds. Easy to find the breaker from there with a clamp-on.
Old 04-14-2019, 03:00 PM   #28
Mensa Player
In that situation I would just use my Ideal breaker finder. The point of this thread was to have the device with me at all times in order to save the trip out to the truck when I find that I will need to identify a breaker.
FWIW, your system has been used for a long time by using one of those little flasher disks (looks like a coin) inside of a standard edison base bulb holder with a 100W light bulb.
Perfection is the enemy of perfectly adequate.
Old 04-14-2019, 03:16 PM   #29
MikeFL's Avatar
Rewards Points: 3,180
IIRC it's the Christmas light flasher.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 04-14-2019, 06:15 PM   #30
joe-nwt's Avatar
Rewards Points: 776
I have a greenlee circuit finder. I didn't trust it in that particular situation, it seemed to pick up a lot of interference from all of the radio gear. Maybe the ideal one is better.
Need help. Iím baffled - dead outlet E-Rack Residential Electrical Forum 7 09-14-2018 11:06 PM
Knob + tube and non-contact voltage tester false positives MSW General Electrical Discussion 15 08-20-2018 08:22 PM
Old outlet stuck to plate rant bostonPedro General Electrical Discussion 3 05-19-2018 12:43 PM
adding an outlet off a Dimmer switch iluvspl General Electrical Discussion 2 01-19-2018 09:14 PM
Running outlet off exsisting one COwboys518 General Electrical Discussion 5 03-02-2017 07:55 PM
