Power driver tip bits - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
Old 05-15-2016, 12:52 PM   #1
Rewards Points: 21,884
Default Power driver tip bits
I know it may be a common item..
But I am looking for a very good driver tip due I done alot of screwing with power driver..
And what brand you like to use on it ?
Yuhh... Philips and square drivers is most common one I do use ( #2 size most case )
The reason why I ask because some of the driver tips are not really strong and can get worn out too quick..
Old 05-15-2016, 12:54 PM   #2
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 6,152
The Dewalt impact bits seem to hold up well. The newer flex ones haven snapped for me yet.
http://www.dewalt.com/flextorq-impact-drill-bits.aspx
telsa likes this.
The Following 3 Users Say Thank You to Wirenuting For This Useful Post:
CADPoint (05-15-2016), frenchelectrican (05-15-2016), theJcK (05-15-2016)
Old 05-15-2016, 01:13 PM   #3
2 + 2 ≠ 5
derit's Avatar
Rewards Points: 360
Gold magnetic Makita bits bring home the gold
U Mirin? likes this.
derit is offline   Reply With Quote
The Following User Says Thank You to derit For This Useful Post:
Old 05-15-2016, 02:25 PM   #4
Freelance Member
AllWIRES's Avatar
Rewards Points: 1,192
http://www.irwin.com/tools/impact-ac...-bits-phillips
"The best master is the best apprentice."
AllWIRES is offline   Reply With Quote
The Following User Says Thank You to AllWIRES For This Useful Post:
Old 05-15-2016, 02:38 PM   #5
CADPoint's Avatar
Rewards Points: 1,838
I believe I need to go to the local big box and get me a some of these!
I have never been that much into an impact and basicially never had the need
to have or use one. I'm warming up to them but truly have done a lot without
one.
Thanks for the links
If you are even thirsty, you are two quarts low.
Old 05-15-2016, 02:48 PM   #6
Rewards Points: 162
Buy a 100 pack of el cheapos and toss them when they get ruined.
Just a suggestion.
Flyingsod likes this.
Old 05-15-2016, 03:14 PM   #7
ponyboy's Avatar
Rewards Points: 709
Just a suggestion.
I agree. Drill tips are a consumable and should be treated as such.
Old 05-15-2016, 03:32 PM   #8
CADPoint's Avatar
Just a suggestion.
That's fine for new construction, screwing into stud walls or joists.
But, I've also found that an impact on new construction in metal usually reams out the screw hole making the install mostly useless...
Don't carry those cheapo's into existing machinery or where one needs to know that an impact was used to tighten a none torqued screw, but an impact is required to back it out.
Old 05-15-2016, 03:38 PM   #9
Rewards Points: 920
Originally Posted by CADPoint View Post
I have never been that much into an impact and basicially never had the need to have or use one. I'm warming up to them but truly have done a lot withoutone.
I have heard that Apex brand are the best, but I haven't found them locally yet
http://www.apex-tools.com/tools
I'm looking for good quality 3" bits to replace the bits in a PicQic screwdriver, preferably with the groove to stay in the impact quick chuck. I am starting to like the M12 impact, which has a low torque setting, I never really got much use out of the V18 one. I like the PicQic because I like the 3" bits in the impact driver.
Old 05-15-2016, 03:45 PM   #10
Rewards Points: 920
I got curious and googled around a little and found this guy that tested a few common brands:
http://www.protoolreviews.com/tools/...he-money/6447/
If you just looked at the names you might think this was a condom comparison.
InPhase277 and Wirenuting like this.
The Following 2 Users Say Thank You to splatz For This Useful Post:
frenchelectrican (05-15-2016), telsa (05-16-2016)
Old 05-15-2016, 04:18 PM   #11
Rewards Points: 2,924
I have had the best luck with Hilt (multi pack) #2 Phillips bits in a driver and in an impact, Dewalt and Ryobi have blown apart in an impact in the past on me.
Old 05-15-2016, 07:28 PM   #12
Rewards Points: 664
PB Swiss or nothing.
KennyW is offline   Reply With Quote
Old 05-15-2016, 07:31 PM   #13
Sandwich ?
Old 05-15-2016, 07:37 PM   #14
Rewards Points: 285
Just a suggestion.
I've always used this method until impact guns came around. The cheap tips break and send small chunks of shattered hardened steel at your eyes. I have a small scar by my eye from a tip that broke. It hurt, it could have blinded me. But I kept using those tips until more broke and I realized that this wasn't going to work anymore.
Now I only use impact rated tips of decent quality.
Old 05-15-2016, 09:59 PM   #15
UncleMike's Avatar
Rewards Points: 271
Originally Posted by Mech Diver View Post
Sandwich ?
That sounds disgusting.
Seriously though, the Bosch ribbed tip Philips bits cam out much less than others. They're not impact rated, but that really doesn't matter much, as indicated in the review linked by splatz. For impact rated bits, I prefer the Makita Impact Gold.
UncleMike is offline   Reply With Quote
Old 05-15-2016, 10:38 PM   #16
Rewards Points: 52
Funny thing is I had an old Bosch titanium bit (non impact rated) that lasted me forever in my impact. When it finally broke I got some Dewalt impact rated bits and break them fairly often. They are better than the milwaukee Shockwave tho. Those are junk.
Mech Diver likes this.
Old 05-15-2016, 10:52 PM   #17
UncleMike's Avatar
Rewards Points: 271
I have some older Shockwave philips bits (with the silver "shock zone"), and you're right - they're junk. I've head that the newer ones (with the red "shock zone") are much better, but I haven't tried them.
Old 05-15-2016, 10:54 PM   #18
GMD
Wera last a very long time, but are more expensive. irwin are great bang for the buck
GMD is offline   Reply With Quote
Old 05-16-2016, 12:15 AM   #19
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
I have used all the major brands and also find that they aren't very good. Funny how some of us get the same stuff and have so many different experiences.
Old 05-16-2016, 12:19 AM   #20
zac
Rewards Points: 826
May have to due with the hardware one uses. Also being heavy handed probably doesn't help
Sent from my SGH-M919 using Tapatalk
zac is online now   Reply With Quote
Residential Power Problems OneTouch Residential Electrical Forum 48 12-06-2017 08:09 PM
Eastern interconnection power outage AshleyMarie General Electrical Discussion 1 04-10-2016 11:23 PM
Power metering after high amp breaker sanpompon NEC Code Forum 3 03-08-2016 05:56 PM
power loss indicating light te12co2w Lighting Design 5 02-05-2016 10:26 AM
Wind power mpetro PLCs, VFDs, Motors and Controls 13 01-24-2016 11:44 AM
