Protecting your old pliers - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
  • 2 Post By John Valdes
  • 1 Post By MechanicalDVR
  • 3 Post By B-Nabs
  • 3 Post By 99cents
  • 3 Post By wcord
  • 1 Post By joebanana
  • 1 Post By Electricaljunkie
Old 05-15-2019, 05:10 PM   #1
Electricaljunkie's Avatar
Rewards Points: 40
Default Protecting your old pliers
I saw a nice youtuber that do tools restoration and he uses shellac after the work is done. What you do after cleaning and removing the rust of your pliers?
1. Use WD-40?
2. Oil them?
3. Both?
4. Paint them?
5. Use Shellac?
6. Use another stuff like carnauba?
Electricaljunkie is offline   Reply With Quote
Old 05-15-2019, 05:23 PM   #2
Rewards Points: 2,876
I use WD40 or any similar spray lubricant because it's cheap, it's always around, and it works OK. There are things that have more staying power but most of them are messy, WD40 is light and doesn't leave much residue on the tools. I will use it to wipe down tools when they get dirty, which isn't that often, because I am more particular about keeping my tools clean than my silverware. That light coat of oil keeps them rust free. I try to keep it off the handles but I am not sure if it would really bother the plastic of the handles.
I bought some old woodworking tools that a guy cleaned up, he put a coat of varnish on when he was done. It's pretty durable and looks really shiny. Varnish, shellac, or wax, I am sure would keep the tool coated longer than just wiping it with oil, but it's more trouble than I will go to. If I lived somewhere with saltwater where things rusted more, I might do it though.
Old 05-15-2019, 08:33 PM   #3
Rewards Points: 1,052
If you use them everyday and keep them dry, you don't really need to do anything else.
Cow and joebanana like this.
Old 05-15-2019, 09:32 PM   #4
Rewards Points: 24,170
Shellac doesn't hold up in a saltwater environment. Lacquer is th eway to go.
Old 05-16-2019, 09:30 AM   #5
canbug's Avatar
Rewards Points: 2,162
WD or just a light oil when they need it. Usually when they start to get tight or if they got rained on.
Tim.
Old 05-16-2019, 11:08 AM   #6
Watt Pusher
B-Nabs's Avatar
Rewards Points: 484
I use cutting oil in the joint, simply because I always have some and because it doesn't dry out like WD does. Otherwise I don't worry about whatever patina might develop, it's part of the charm of a well used tool.
Old 05-16-2019, 01:36 PM   #7
Rewards Points: 3,029
My strippers had a tight hinge. Yesterday I used them to verify a hot circuit. Now the hinge is nice and loose.
joebanana, B-Nabs and canbug like this.
Old 05-16-2019, 02:22 PM   #8
wcord's Avatar
Rewards Points: 2,206
I was always thought that when your pliers get old, do the above to turn them into strippers
Old 05-16-2019, 03:41 PM   #9
jw0445's Avatar
Rewards Points: 1,980
And now you can strip 8's and 6's.
Old 05-16-2019, 03:54 PM   #10
Rewards Points: 8,105
It works for dykes, but I'm not sure about how it would work for pliers.
Electricaljunkie likes this.
Old 05-16-2019, 06:54 PM   #11
Rewards Points: 40
I bought an acrylic clear spray paint and painted my rusty old linesman plier. I soaked it in vinegar and cleaned it with a microfiber cloth, so it looks like matte gray, not shiny metal. Still I not going to spend $20 buck in stuff to make it shiny. I spray it with the acrylic I will show pictures soon.
Old 05-18-2019, 05:00 PM   #12
Rewards Points: 40
Old 05-18-2019, 05:01 PM   #13
Rewards Points: 40
Braking in linesmans and other pliers Lone Crapshooter Electrician Apprentice Forum 21 06-14-2018 03:02 AM
Bought Gedore Combination/Linesman Pliers Satch Tools, Equipment and New Products 4 03-11-2018 10:17 PM
Anyone Using Knipex Needlenose Combination Pliers? Satch Tools, Equipment and New Products 4 10-09-2017 12:57 PM
NWS/Irwin Pliers Deep Discount At Lowe's Satch Tools, Equipment and New Products 0 09-11-2017 10:04 PM
one thousand dollar pliers socket2ya Tools, Equipment and New Products 19 07-31-2017 04:03 PM
