Reuseable Wagos - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree43Likes
Old 11-18-2018, 02:54 PM   #21
Rewards Points: 16,558
stuiec.,
Thanks for the link on that and I have see different verison but seems it is more promising for me for that item I been looking for.
I will concant them and see what I can order it and try it out.
Again., thanks for the link.
stuiec likes this.
Old 11-18-2018, 07:03 PM   #22
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 1,974
I have @HackWork to thank as well for introducing me to these little doodads.
I got my free samples last year around the same time as E-nut.
Nice stuff.
Old 11-18-2018, 07:49 PM   #23
Rewards Points: 2,490
I wish I had them in my early years. I have not used the lever nuts. Only the push in Wago's.
Every wirenut I twisted in my whole life has been with my hands. Not good.
The industry has improved big time. Evolved.
Old 11-19-2018, 11:48 AM   #24
Rewards Points: 2,888
Originally Posted by emtnut View Post
I ordered the sample last year. They shipped to Canada too
I got 1-2 port , 1- 3 port , and one 5 port connector.
I liked them, so I ordered a bunch of them.
I especially like them for lighting fixtures (with stranded wires).
I don't feel confident enough to use them on a heavy loaded circuit yet .... I'm just sketchy that way
I got six different ones some for a larger gauge wire.
Old 11-19-2018, 11:57 AM   #25
sbrn33's Avatar
Rewards Points: 3,176
Looks expensive...
John Valdes likes this.
Old 11-19-2018, 11:59 AM   #26
cog
stuiec's Avatar
Rewards Points: 998
Looks expensive...
I thought you liked fancy.
Old 11-19-2018, 12:34 PM   #27
Rewards Points: 691
Looks expensive...
They make up for their price in speed. Even if they didn't, they are worth it in many situations to save frustration.
Just one example of where they really work well is putting lights up. Whether it be ceiling fixtures, wall sconces, or even lamppost heads. You simply let the wires hang down from the ceiling (or wall, or pole) ready to go, then you put the lever nuts on the ends of the fixture wires. How you hold the light with 1 hand and clip the lever nuts onto the romex wires with the other hand. That's it, you're done. 2 seconds later the light is up. No more trying to hold the light while needing both hands to install wirenuts.
You will find many instances like this in which lever nuts work great.
TGGT (11-19-2018)
Old 11-19-2018, 12:39 PM   #28
Rewards Points: 1,874
I watched a video where a guy overloaded a circuit until the plastic on the wago melted off. The metal clamping the wires held true until he physically broke them off. He sent like 800 Amps or something crazy high through them. Satisfied my doubts, anyway.
emtnut and MikeFL like this.
Old 11-19-2018, 04:16 PM   #29
sbrn33's Avatar
Do I have to strip the wires?
Old 11-19-2018, 04:21 PM   #30
Rewards Points: 691
Of course.
Old 11-19-2018, 04:25 PM   #31
Band Member
emtnut's Avatar
Rewards Points: 560
WTF ??? The bastids only sent me 3
Old 11-19-2018, 04:30 PM   #32
Rewards Points: 691
This new offer that Dennis posted probably comes with 6, 3 of the old models and 3 of the newer ones that do #10.
Old 11-19-2018, 04:50 PM   #33
Band Member
emtnut's Avatar
Rewards Points: 560
Nice stuff.
Signal... did you get gyped like me and only got 3 ??
Or are you on the "let's send this guy 6 of 'em list" ??
Old 11-19-2018, 07:02 PM   #34
Signal1's Avatar
Gyped.
1- 2 port, 1- 3 port, 1- 4 port.
I liked them though and bought the 100 pack of 2 port ones.
They are also nice for troubleshooting too. They have a test port that you fit your meter lead in without taking the splice apart, if you need to isolate something, you can just unclip a wire, do what you need, and put it back together easily without twisting.
John Valdes, HackWork and stuiec like this.
Old 11-19-2018, 07:15 PM   #35
Rewards Points: 691
Gyped.
I believe you mean 5-port.
I wish they made a 4-port. I would use it all the time. I'd like it to be stacked, 2 with the levers facing one way and the other 2 with the levers facing the other way. This would be square shaped and a similar size to a typical wirenut and fit nicely into boxes.
Speaking of testing, they work great for when you need to connect and disconnect things during testing or troubleshooting. Such as troubleshooting 3-way switch wiring that the stupid homeowner screwed up.
Old 11-19-2018, 07:17 PM   #36
Band Member
emtnut's Avatar
Rewards Points: 560
Gyped.
I liked them too. I guess you and I don't rate thou
I don't like Electricguy anymore
Old 11-19-2018, 07:21 PM   #37
Rewards Points: 691
I don't think they made the #10 models when you guys got the offer!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-19-2018, 07:27 PM   #38
Band Member
emtnut's Avatar
Rewards Points: 560
Doesn't matter ... I'm still butt-hurt
Old 11-20-2018, 10:56 AM   #39
Signal1's Avatar
Yes it is a 5 port.
I like this idea though. It would make a nice compact connector.
HackWork likes this.
Old 11-20-2018, 11:00 AM   #40
Rewards Points: 691
Yes it is a 5 port.
The reason I asked about the 4-port is because they do make them, but not for our country. If you look closely, you can see the 32A rating on the side where our's say 20A:
Wagos causing arcfault/gfi breakers to trip dham206 General Electrical Discussion 41 02-02-2018 08:58 PM
Built-in Wagos 99cents General Electrical Discussion 25 04-16-2017 08:31 PM
Failed Wagos? TheLivingBubba General Electrical Discussion 65 07-08-2016 06:31 PM
