Solenoid testers?? - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 09-06-2009, 10:46 PM   #41
So all in all, which would be a better choice for troubleshooting in an industrial setting a solenoid tester or a vol-con or both?
scott_8222 is offline   Reply With Quote
Old 09-07-2009, 08:13 AM   #42
Rewards Points: 2,410
I HATE THE VOLT-CON and would not use it for a door stop.
Old 09-07-2009, 08:18 AM   #43
EXACTLY why ??????
Old 09-07-2009, 10:24 AM   #44
Rewards Points: 6,421
Originally Posted by paul d. View Post
EXACTLY why ??????
Because it would make a terrible door stop. I wouldn't use a Vol-Con for a door stop either.
Old 09-07-2009, 10:37 AM   #45
Rewards Points: 150
What don't you like about the Vol Con? I like the Vol Con above my Klein/Square D Wiggy because it has a continuity tester in it.
BadSplice is offline   Reply With Quote
Old 09-07-2009, 10:38 AM   #46
It's yellow. That's an awful color for a solenoid tester.
Old 09-07-2009, 10:39 AM   #47
Rewards Points: 150
It's ok for a DMM tho, right? I sure hope so or else I threw out a LOT of money.
Old 09-07-2009, 10:43 AM   #48
Yes, yellow is the preferred color for a DMM.
Old 09-07-2009, 06:09 PM   #49
Master Electrician
electricalperson's Avatar
Rewards Points: 2,002
get a knopp k60 best solenoid tester on the market
Old 09-07-2009, 06:13 PM   #50
Rewards Points: 150
What do you like about it better than the Vol Con or the Klein Wiggy?
Old 09-07-2009, 06:20 PM   #51
Master Electrician
the k60 is cat 3 rated the vol con and wiggy isnt
Old 09-07-2009, 06:23 PM   #52
Comparison.
http://www.knoppinc.com/voltage_tester_comparison.htm
Old 09-07-2009, 06:54 PM   #53
Rewards Points: 150
It doesn't use batteries like the Klein Wiggy, but that's a negative since it won't do continuity testing like the Vol Con.
So the only benefit is that it's Cat 3 rated.
Old 09-07-2009, 07:04 PM   #54
Made in the USA is important to some people.
Old 09-07-2009, 11:08 PM   #55
Rewards Points: 178
The Vol Con is Cat III-1000V rated.
Bill
wptski is offline   Reply With Quote
Old 09-08-2009, 10:33 AM   #56
I want my solenoid tester to be a voltage tester ONLY, I do not want continuity on a voltage tester.
Old 09-08-2009, 10:34 AM   #57
Rewards Points: 23,298
Then stick with the real "Wiggy", it's a one trick pony.
Old 09-08-2009, 01:45 PM   #58
Rewards Points: 178
Originally Posted by Voltage Hazard View Post
The T5 is a great tool, BUT it still can't do a few tests that the wiggy (or traditional solenoid tester) can do.
A ghost voltage can occur when several wires are ran together for a distance. If a live wire is ran together with a dead wire in a conduit run, that dead wire will pick up voltage from the live wire. Those wires ran together act like a big capacitor, and the voltage couples into the dead wire. If you put a Fluke T5, or any DMM, on that dead wire, you will read voltage. That is because DMM's , and the T5, have a very high input impedance, and draw almost no current from the voltage they are measuring. Since you draw no current, you read that coupled (ghost) voltage on the "dead" wire. The solenoid tester has a input impedance of around 10,000 ohms, so it will draw about 12 milliamps off the voltage it is measuring. It puts a good "load" on the circuit. Since that ghost voltage has no ability to supply the current the solenoid tester needs, you will not measure that ghost voltage. That is why a solenoid tester is a good tool to determine live circuits, and is still used by so many people.
The many references to construction is because you have ghost voltages all over the place. When you are pulling new wire, and looking for live wires, there are good chances there are a few dead ones in the group. I want to know for sure which are live, and which are not, and the T5 will not do that for me. Some DMM's like the Fluke 117 have a low Z setting to eliminate ghost voltages, and those can be used. But, it easier to use the wiggy.
Another advantage of a wiggy is testing GFCI outlets. Since they draw about 12 mA, they will trip a good GFCI outlet if you measure between hot and ground. If the outlet does not trip with a wiggy, it is defective.
So, solenoid testers DO have their place in construction. It not about how much money you spent, or how big your tool is.
The manual states that the input impedance of a Ideal Vol Con is 1M.
The input impedance of the T+ and T+PRO is 20K at low voltages and goes up to about 240K when 600 volts is applied, so says Fluke.
Is that 1M for the Vol Con a bit too high or not to eliminate ghost voltages? Ideal's description is that it has a low impedance to eliminate ghost voltages. That's much lower that a typical DMM but I've never used one.
Bill
Old 09-08-2009, 02:50 PM   #59
Rewards Points: 150
How do you tighten lock nuts or remove knock-outs? Just curious.
Old 09-08-2009, 05:36 PM   #60
Rewards Points: 300
He uses this.
Tick Testers? NevadaBoy Tools, Equipment and New Products 46 06-30-2009 11:08 AM
Solenoid testers randomkiller Tools, Equipment and New Products 33 09-01-2008 09:43 PM
Portable Appliance Testers. Ecopat General Electrical Discussion 3 05-01-2008 09:40 AM
Amp testers calimurray General Electrical Discussion 1 08-05-2007 09:59 AM
