Vol-Con xl - Electrician Talk - Professional Electrical Contractors Forum
Old 07-05-2009, 07:59 PM   #1
Default Vol-Con xl
Is it worth it to have a vol con (wiggy) in your tool box or should I just get a clamp on multi meter?
scott_8222 is offline   Reply With Quote
Old 07-05-2009, 08:00 PM   #2
steelersman's Avatar
Rewards Points: 2,000
Vol-cons are good for determining that something has true power and not ghost voltages. I learned that from this forum by the way.
Old 07-05-2009, 08:20 PM   #3
for construction, vol-con is a great tool.
Old 07-05-2009, 09:03 PM   #4
Richard Rowe's Avatar
I have a selinoid meter not that expensive one, I think if you do control voltage of any kind you need one. I was wondering about the Flouke T+Pro will it replace the wiggy and multi meter???
Richard Rowe is offline   Reply With Quote
Old 07-05-2009, 09:17 PM   #5
I was reading about the T+PRO on the Fluke site and it says that its safer than traditional solenoid meters. Why is that?
Old 07-05-2009, 09:33 PM   #6
Rewards Points: 530
The display turns on at 12 volts which is a safety feature because a traditional wiggy will not detect that low voltage. Wiggys are now not NFPA-70E approved, but the T+pro is, Thats why I have one.
SEU installer
electro916 is offline   Reply With Quote
Old 07-06-2009, 12:11 AM   #7
Larry Fine's Avatar
Rewards Points: 150
I like the Knopp K-60, which is CAT-III rated.
I laid in bed last night, looking up at the stars, and
I said to myself, "Where the hell is my ceiling?!"
Larry Fine, Master Electrician and
Electrical Contractor, Richmond, Va
Larry Fine is offline   Reply With Quote
Old 07-06-2009, 04:39 PM   #8
Tabihu Juhar
76nemo's Avatar
Look into dual impedance meters, like the Fluke 116:
http://us.fluke.com/usen/products/Fluke+116.htm
Old 07-06-2009, 05:46 PM   #9
Zog
Zog's Avatar
Rewards Points: 1,096
CATIII rating, based on how much fault current the meter can handle if misused without failing. (Among other things)
Old 07-06-2009, 08:50 PM   #10
Master Electrician
electricalperson's Avatar
Rewards Points: 2,002
the knopp k60 is cat3 get that one
Old 07-06-2009, 09:01 PM   #11
Tabihu Juhar
76nemo's Avatar
Question
Why do you perfer this over Flukes T+Pro? I thought you had one.
Old 07-06-2009, 09:03 PM   #12
Master Electrician
i have a t+pro and a k-60 if he wants a real solenoid tester he can get that one
Old 07-06-2009, 09:17 PM   #13
Tabihu Juhar
76nemo's Avatar
Arrow
A "real solenoid tester"? Is there a real need besides what the T+ can do?
Old 07-06-2009, 09:23 PM   #14
Master Electrician
not really i just like the way it feels
Old 07-06-2009, 09:29 PM   #15
That's what she said.
Old 07-06-2009, 09:29 PM   #16
Semi-Retired
BryanMD's Avatar
Getting back to the original post...
When someone asking if they need a multi-meter or not is a real good sign that they don't.
If they actually needed one they would already have enough experience of using one to be asking the other type of multi meter questions (analog: digital and fluke:greenlee and ModelX:ModelY) ... ya know?
November 2011: Relocated to Winston-Salem.
May have to change the username suffix.
Old 07-06-2009, 09:34 PM   #17
You should have both as both have their purpose.
Old 07-06-2009, 09:42 PM   #18
Master Electrician
he needs to get a wiggy learn more then buy a clamp on
Old 07-06-2009, 11:11 PM   #19
Toronto Sparky's Avatar
Rewards Points: 1,008
Have had two amprobes analog (500A) + a (2000A) Then I got a Hioki 3261 Digital and it worked fine for me over the years.
Don't fight .. Play nice!
Old 07-07-2009, 11:27 AM   #20
Rewards Points: 19,255
Knopp testers shake when voltage is present. I'm used to that shake after 30 years of using one. When I use my Fluke volt tester I have to remember that there will be no shake, which is to me an increased risk that I will make the mistake that something is de-energized when it is not. I have to tell myself to be careful each time I get the Fluke out. I do not have to tell myself that same thing when using my Knopp tester. Old habits die hard.
