Wago 222 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree15Likes
Old 11-05-2019, 04:52 PM   #1
MikeFL's Avatar
Rewards Points: 840
Default Wago 222
Boy these WAGO triple deuces are awesome.
Shove anything you want in them.
We use 22 AWG hookup wire when landing it on a pcb. The 222's will accept as small as 28 AWG.
Tried some breadboard jumpers too. No problem. We solder them on a small plated through hole when we need to capture a signal waveform.
DMM probes. No problem.
Up to 10 AWG I think. We use 14 AWG for line voltage.
And unlike some other products out there, insert anything that will fit, then insert anything else and it still works, whereas with some other products you can only go bigger but never smaller on subsequent insertions.
I got the 140 pc kit on Amazon.
50 x 2 port
50 x 3 port
40 x 5 port.
YouTube video:
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 11-05-2019, 05:13 PM   #2
Rewards Points: 1,299
Those are the original lever nuts. They go to 12 gauge.
The 221 series are newer and smaller and clear.
Old 11-05-2019, 05:21 PM   #3
MTW
Rewards Points: 11,356
I still won't use them.
Old 11-05-2019, 06:02 PM   #4
460 Delta's Avatar
Rewards Points: 1,718
Is that so?
micromind for moderator- make ET more industrial
Old 11-05-2019, 06:10 PM   #5
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,538
I like them.
Old 11-05-2019, 06:20 PM   #6
Rewards Points: 26,836
They are awesome.
Especially for short taps.
The stuff that results from pre-twisting -- and cutting them back.
Old 11-05-2019, 06:42 PM   #7
joe-nwt's Avatar
Rewards Points: 1,808
They are awesome.
Really? You make that many mistakes wiring that you have to cut them back that many times? I find that hard to believe.....
Kevin_Essiambre likes this.
Old 11-05-2019, 06:56 PM   #8
zac
Rewards Points: 826
No it's the 3 previous times a handyman or homeowner changed out their devices. I'm always dealing with short wire.
telsa and splatz like this.
zac is online now   Reply With Quote
Old 11-05-2019, 06:56 PM   #9
His splices would leave you breathless.
Old 11-05-2019, 07:04 PM   #10
Bird dog's Avatar
Rewards Points: 2,072
Even before lever nuts, wagos were the way to go for extending short wires in the back of the box.
HackWork and telsa like this.
Old 11-05-2019, 07:12 PM   #11
I was the REPAIR man.
Such short taps were NEVER my work
You guys are such a bunch of kidders.
My poor lot in life was to CORRECT every bozo.
I was consigned to the CLEANUP detail.
I had to wipe the azz about 100 'electricians.'
I use that term VERY usely.
Yeah, I QUIT.
Old 11-05-2019, 07:25 PM   #12
Rewards Points: 2,390
The original lever nuts are great, but I really like the clear ones because you can visually confirm the strip length is just right, the wire is seated just right.
telsa likes this.
This too shall pass.
Old 11-05-2019, 07:38 PM   #13
When I first bought the newer model 221 I still liked the older 222 a bit better because I was used to it.
But now I don’t know of any reason why the older model would be better than the new one. The clamp inside is the same in both models. The new model is clear so you could see the conductor, it’s smaller, the levers work easier since they don’t need to be clipped down, and there is a test port on both sides.
Old 11-05-2019, 09:22 PM   #14
Rewards Points: 2,915
You will when the pricing on them hits $x.03 or $.01 at your local Home Depot
Old 11-05-2019, 10:13 PM   #15
MTW
Obviously.
Old 11-05-2019, 10:16 PM   #16
MTW
Originally Posted by 460 Delta View Post
Is that so?
It is so.
Once upon a time I installed a bunch of LED wall packs from Eaton/Lumark. They had genuine Wago Levernuts installed from the factory. I cut them all off and used regular wire nuts. I saved the lever nuts and I still have them to this day. I have never found a place where I would trust them.
Old 11-06-2019, 04:46 AM   #17
460 Delta's Avatar
It is so.
I see.
Old 11-06-2019, 07:49 AM   #18
MTW
I see.
Old 11-06-2019, 09:09 AM   #19
Watt Pusher
B-Nabs's Avatar
Rewards Points: 480
Yeah, I QUIT.
Do you have a lone violinist follow you around to accompany your sob stories?
99cents likes this.
Old 11-08-2019, 09:08 AM   #20
