What is the point of these screwdrivers??? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 06-22-2009, 04:02 PM   #21
steelersman's Avatar
Rewards Points: 2,000
Originally Posted by Black4Truck View Post
yes.. installing plate screws is very labor intensive. Those 6/32 x 1/4 inch are a real back breaker and need a special tool
It's just plain dumb to use a regular flat blade screwdriver to put plates on. At least use one of those piece of chit "yankees". But these "whirlybirds" or "offset screwdrivers are the best. I keep one in my toolbelt. And I use the phillips one as well.
Old 06-22-2009, 04:08 PM   #22
Originally Posted by Minuteman View Post
So, save your six bucks and don't buy one. I like mine.
I agree with you on this one!
Old 06-22-2009, 04:18 PM   #23
Rewards Points: 300
Are union workers banned from using cordless screwdrivers to install switches and outlets??
Originally Posted by 76nemo View Post
Any workers for that matter? I have a screwdriver with planetary gears that weighs a little less than my small cordless driver. Let the battery do the work far as I'm concerned.
Plates generally have flat head screws, which can be a pain in the butt to try to run in with a cordless drill. Plus, with a drill, it's hard to tell when the screw is getting tight. Good way to crack plates. With an offset, you can feel when the screw is tight enough. I don't use them to put wood screws in or run lags, but as MechDVR said, if it doesn't require a lot of torque, then I use them.
Old 06-22-2009, 04:19 PM   #24
Master Electrician
electricalperson's Avatar
Rewards Points: 2,002
im able to twist the screwdriver shaft between my thumb and finger to make it turn faster so i dont have to buy one of those stupid looking screwdrivers
The Following User Says Thank You to electricalperson For This Useful Post:
Grogan14 (09-24-2015)
Old 06-22-2009, 04:28 PM   #25
And I suppose you use a cordless drill for the device screws?
Old 06-22-2009, 04:28 PM   #26
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Originally Posted by steelersman View Post
GD you're an F ing moron if you use a regular flat blade screwdriver to put plates on. At least use one of those piece of chit "yankees". But these "whirlybirds" or "offset screwdrivers are the best. I keep one in my toolbelt. And I use the phillips one as well.
Yep.. guess I'm a Fing moron because I never needed to buy a bent screwdriver.
I use my fingertips on the square shaft of a Craftsman screwdriver and that is fast enough, I thought till I read the posts
BUT.. since you and other members give it such high marks, I am going to buy one and check it out.
I am on this forum to learn new ideas from other electricians
Old 06-22-2009, 04:38 PM   #27
Master Electrician
nope and i dont let anybody use a cordless drill for those screws.
every time somebody uses a drill to trim out a house the receptacles are set to far back or they keep breaking them. i got one helper that uses an impact gun to tighten up device screws. i never use drills to trim out just a screwdriver. my wrists dont hurt at the end of the day either
Old 06-22-2009, 04:41 PM   #28
Master Electrician
i must be an fing moron too...take my license away before i use a straight blade screwdriver at your house.
im not girly enough to use a whirly bird screwdriver i guess
i see no good use to those screwdrivers. just another tool to spend money on. if somebody is worried about 1 second vs 1.5 seconds using a regular screwdriver then they must not of bid the job right or something
if somebody gave me one of those screwdrivers i would give it back and tell them never to speak to me again until they man up and buy a real screwdriver
Old 06-22-2009, 04:43 PM   #29
Richard Rowe's Avatar
I use a Bosch PS10(I think) for most driving not real fast so you can take care of your screws. I have a set of nutdrivers I use with it but I will have to say my dad can do as well or maybe just a bit better with his 40 year old Yankee. I don't do very much work with small device screws so I can really say about that.
Richard Rowe is offline   Reply With Quote
Old 06-22-2009, 04:46 PM   #30
Master Electrician
im going to put a bit in my magnum drill and use that to put devices in. maybe ill get it done a half second faster than the fancy screwdriver
Old 06-22-2009, 04:49 PM   #31
Mad Skills
Celtic's Avatar
Rewards Points: 2,050
Nope.
Some EC's have one for each man on the job.
póg mo thóin
Old 06-22-2009, 04:57 PM   #32
If you use a regular screwdriver for screwing in the devices then you are wasting a lot of time. A lot more than a half second per screw.
Old 06-22-2009, 05:01 PM   #33
Master Electrician
did you ever break a plate using one of those fancy screwdrivers? i never broken a plate using a regular one. im not worried about how much time you save installing plates. if a job gets bid so tight that using a regular screwdriver will cause lost money then something isnt right. use what you want but you will never see me using one of those stupid screwdrivers.
Old 06-22-2009, 05:04 PM   #34
Mad Skills
Celtic's Avatar
Either way....I don't care..P&S has an "indestructible" plate
I'll stick with my cordless and 10-in-1
póg mo thóin
Old 06-22-2009, 05:08 PM   #35
Master Electrician
ill stick with my straight blade cabinet screwdriver and #2 philips. my boss doesnt buy those rubber plates he buys the cheap leviton plates. surprised we dont have plates from china yet
Old 06-22-2009, 05:12 PM   #36
No it's hard to break the nice metal maxi plates. And earlier you said you use a flatblade for screwing in the device. That is where you will take twice as long and that's probably being considerate.
Old 06-22-2009, 05:15 PM   #37
Master Electrician
im not worried about it that much.
i hope the new england patriots beat the steelers this year
Old 06-22-2009, 05:17 PM   #38
I own stock in FotoMat!
Rewards Points: 6,520
Profit is measured in seconds.
Old 06-22-2009, 05:19 PM   #39
me too. I'm kinda tired of the steelers winning. They need a break from it.
Old 06-22-2009, 05:22 PM   #40
B4T
B4T's Avatar
I spent an hour today trying to sell a service change..( he will let me know after talking to his wife) that was 3600 seconds.. how many plate screws it that??
I think it is really dumb to think your losing money putting plate screws on with a regular screwdriver.
Best Screwdrivers ZONE Tools, Equipment and New Products 143 02-29-2016 12:29 PM
greenlee screwdrivers electrician man Tools, Equipment and New Products 34 01-18-2010 04:21 PM
Witte Screwdrivers Stan Mason Tools, Equipment and New Products 2 11-23-2008 06:25 PM
New Klein screwdrivers randomkiller Tools, Equipment and New Products 49 05-04-2008 05:20 PM
Cordless screwdrivers? twintask Tools, Equipment and New Products 15 07-09-2007 08:50 PM
