Wiggy - Electrician Talk - Professional Electrical Contractors Forum
Old 08-31-2009, 07:15 PM   #1
Default Wiggy
What model do you use? What's the best one to use?
Dennis is offline   Reply With Quote
Old 08-31-2009, 07:16 PM   #2
william1978's Avatar
Rewards Points: 2,000
I quite using a wiggy about 10 years ago.
Old 08-31-2009, 07:32 PM   #3
I used one for the first time today and it saved me alot of headache and time. I was testing a solenoid that would not turn on. I took my greenlee
meter and measured 120vac between Line and Nuetral. I went back to the PLC output card to see if its good and it shows ok. Finally an old Jman
lend me his wiggy and I measured 120vac at the ouput card but nothing on the solenoid and yet my greenlee meter says it has 120vac on it. Ghost voltage??? I think it's a wiring issue from plc to the solenoid, I guess I'll find out tomorrow.
Old 08-31-2009, 07:36 PM   #4
I glad you had a good use for it. I love my Fluke T1000.
Old 08-31-2009, 07:41 PM   #5
Rewards Points: 2,268
I use a Ideal Volt-Con with resistor probes and a Knopp.
The Ideal Is the Volt-Con full size not the Volt-Con Lite.
The plants in Freeport TX required resistor probes on the Ideal Wiggys
I bought my Volt-Con in 1984 when I was in Freeport it has served me well.
The Knopp I bought about 3 years ago.
LC
Old 08-31-2009, 07:52 PM   #6
I used an Ideal volt-con when I used to use one.
Old 08-31-2009, 07:57 PM   #7
ideal volt-con. for construction, its the way to go.
Old 08-31-2009, 08:13 PM   #8
Senior Moment
drsparky's Avatar
Rewards Points: 214
The output cards in AB PLCs leak, it is not really a relay card it is a semi conductor turning on and off. There is not enough current available to run the solenoid but enough to read on a digital meter.
Old 08-31-2009, 08:39 PM   #9
EBFD6's Avatar
Rewards Points: 1,014
Fluke T+ Pro
EBFD6 is offline   Reply With Quote
Old 08-31-2009, 08:50 PM   #10
Good point! do you think it is a card issue, and yes it is an AB PLC-5 (old).
Old 08-31-2009, 08:58 PM   #11
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Why did you stop using a wiggy?
I know you didn't switch to a volt stick piece of
Old 08-31-2009, 09:05 PM   #12
Senior Moment
drsparky's Avatar
Rewards Points: 214
double
Old 08-31-2009, 09:06 PM   #13
Senior Moment
drsparky's Avatar
Rewards Points: 214
I don't think it is a card issue. Here is what I would try.
Jumper the output with a short length of wire. If solenoid works, look at the PLC, if not look to the solenoid end.
Old 08-31-2009, 09:07 PM   #14
I found a T-1000 on the top of a walkin cooler and have been using it ever since.
Old 08-31-2009, 09:19 PM   #15
mikeg_05's Avatar
Rewards Points: 258
me too But Ive been thinking about switching to a fluke t pro because of the digital reading, but does it have the option of switching the beeping off?
Old 09-01-2009, 03:26 PM   #16
Rewards Points: 178
You can switch OFF the beeping but not the vibrating feature.
Bill
wptski is offline   Reply With Quote
Old 09-01-2009, 05:05 PM   #17
Chris Kennedy's Avatar
Originally Posted by EBFD6 View Post
Fluke T+ Pro
I use the T+, very happy with it.
Old 09-01-2009, 06:09 PM   #18
Rewards Points: 6,421
I have a really old Wiggy that's made out of metal ! I don't use it, though. I use the T5 pretty much every day in its place for most things.
Old 09-01-2009, 06:28 PM   #19
mikeg_05's Avatar
Rewards Points: 258
That is so cool, I want one
wiggy electricalperson Tools, Equipment and New Products 19 06-01-2009 03:07 PM
new wiggy mikewardjr General Electrical Discussion 4 08-11-2007 06:22 PM
