To wiggy, or not to wiggy - Page 9 - Electrician Talk - Professional Electrical Contractors Forum
View Poll Results: Do you use a wiggy, or not
Yes, I use a wiggy 32 72.73%
No, I never owned a wiggy 12 27.27%
Voters: 44. You may not vote on this poll
Like Tree137Likes
Old 08-07-2019, 07:20 AM   #161
Rewards Points: 3,686
As for the Klein meters - like Milwaukee, they do have nice combinations of features ON PAPER. In reality, it will be a while before the stink of their recalls drifts away and I'd even consider one. Even then, it's unlikely with rebranded off brands I'd ever buy one. I have had first hand experience with this, which I try to learn from.
A single tail-chasing adventure with a crap meter wastes enough time / money to pay for a better meter. And that's not the worst thing that can happen with a crap meter. It's just not something I'd skimp on, with safety and frustration and time / money involved, it's the LAST thing I'd skimp on.
Old 08-07-2019, 07:20 AM   #162
Rewards Points: 102
That looks like a cool little tester, but $9 scares me lol. I also don't care for Klein products anymore, especially not testers/meters.
They are nothing until they have been banned in factories that are over run with PLC-5s!
HackWork likes this.
Old 08-07-2019, 07:23 AM   #163
Rewards Points: 102
Cheap safety equipment isn't the way to go.
bill39 and splatz like this.
Old 08-07-2019, 07:27 AM   #164
Rewards Points: 355
I still have a Milwaukee tester that was supposed to be the Fluke T5 killer. I remember Big John was eager to get it so I got one too.
It's roughly the same size as the T5, it did 200A in the ampprobe, has LoZ, trueRMS, etc.
But it was very slow to show the voltage. I keep it in my little "basic tools" bag in my personal vehicle.
Jrags, here is a thread you started a while back on it in which we discussed a similar topic to this thread lol: https://www.electriciantalk.com/f14/...dation-224057/
Old 08-07-2019, 12:22 PM   #165
HertzHound's Avatar
Rewards Points: 646
I had the Klein ET-200 for a few years before I switched to the T+ Pro.
The ET-200 served me well for a “check for dead” tester. Also had continuity and a light. The light would get turned on often accidentally. It was low Z but the battery was for the vibration function. The indicator lights worked without battery.
Why say lot words when few words do trick
Old 08-07-2019, 11:21 PM   #166
stiffneck's Avatar
Rewards Points: 788
I started with a DMM but I listened to others talking about the advantages of a solenoid tester for safety and agreed that for many tasks, you're better off with the reliability and ruggedness despite the limited functions.
I can't imagine trucking around all day every day with a full function DMM, too big, too delicate. I need a dead reliable voltage check and a continuity tester, it has to fit in a pocket or small pouch, it has to be rugged enough to get knocked around a little, and it has to be cheap enough it won't break my heart if it's lost or stolen or damaged.
Long ago I had my government issue Square D type VT-1 "Wiggy" let me down. I received a call from the airport police department that a customer had been "shocked" when standing between 2-signs. The location was along the wall, as you exited concourses "C" and "D" into the baggage claim area Terminal-1 (older area). I checked for voltage between the 2 sign frames and read nothing. The cop said, "just put your shoulders between these 2 signs like I did". I ignored him and then pulled out my cheapy no-name digital multi-meter, to test for voltage. There it was, a little over 500 volts. Turns out the secondary side of the ballast had gone to ground, but the sign and raceway didn't carry the current back to the service. So I turned off and disconnected the sign. The only thing I can figure is there wasn't enough current flow, to energize the relay in the Wiggy. As for the cop, back then they used to shoot each other with their stun guns. Higher voltage with lower current, makes for safer toys.
splatz, joe-nwt and Incognito like this.
In Bred Electrical Worker
Old 08-07-2019, 11:50 PM   #167
Rewards Points: 70
Haha. Nice pull Hack!
I should have asked if anyone had experience with the new Klein ET60 to see if their quality has improved. This is the one that actually seems more like a LoZ Wiggy than their other ones.
https://www.kleintools.com/catalog/e...voltage-tester
Jrags is offline   Reply With Quote
Old 08-09-2019, 10:07 AM   #168
FishinElectrcian's Avatar
Was there a lot of recalls on the Klein?
Am I correct that those are made by UEI?
I've been using that CL800 more since I know what the low Z does, it's got everything, even has a single lead holder on the side of the clamp. (Which I only noticed yesterday) Like I said before it's a whole lot of meter for $150, but so slow to read might be 3 or 4 seconds before it registers a voltage and it's a little painful to see amps unless you set it to "max" before energizing.
FishinElectrcian is online now   Reply With Quote
Old 08-09-2019, 11:24 AM   #169
Yes there were a few that were posted on here and if I recall correctly at least one was a potential safety issue, failing to read voltage or something like that.
Old 08-09-2019, 02:35 PM   #170
Rewards Points: 276
This example is exactly why one tester is no better or reliable than the rest. Test your testers regularly.
stiffneck likes this.
joe-nwt is online now   Reply With Quote
The Following User Says Thank You to joe-nwt For This Useful Post:
stiffneck (08-09-2019)
Old 08-09-2019, 05:20 PM   #171
Rewards Points: 102
I think in that instance I'd start off with a NCVD.
Old 08-09-2019, 07:25 PM   #172
stiffneck's Avatar
Rewards Points: 788
Back in 1996 I didn't have one, but we did have a few "tic" tracers IIRC. Those where located in the Field trucks, not the Service vans. Today everyone has a pocket pencil sized NCVD tester. Progress by inches is still progress.
Old 08-09-2019, 07:37 PM   #173
Rewards Points: 102
Not sure what year I got my first neon pocket screwdriver. You touched the clip and the bulb would light up, it didn't take all that much voltage.
Old 08-11-2019, 10:44 PM   #174
Rewards Points: 70
Default Fluke T90
Anyone have experience with a Fluke T90?
It is a UK produced fluke tester that looks perfect for this application. Not sure why it wouldn’t work in the US... tests our Voltages too.
Aside from not easily attainable here, it seems pretty good.
https://www.fluke.com/en/product/ele...t110-t130-t150
Old 08-13-2019, 10:52 PM   #175
Rewards Points: 1,874
I was thinking about picking up the T6-600. A comparison on sparky channel made it seem like an upgrade from the T5. I like the idea of a quick check of voltage with the open jaws. Accuracy was +/- 3% +3 which is good enough to know what range you're dealing with.
I only own the UEI clamp meter which I really only favor because it has a magnet on the back. Seriously.
I have an etcon solenoid tester but don't carry it.
Anybody have experience with the T6?
Old 08-13-2019, 11:01 PM   #176
Rewards Points: 102
They must have improved it since it's inception.
Old 08-13-2019, 11:22 PM   #177
Jlarson's Avatar
Rewards Points: 3,966
I just bought a T6 today, so far I like it, it is nice to have a back light. I'm curious to see how the field sense works out.
Old Yesterday, 12:24 AM   #178
Rewards Points: 1,512
It was 1975 when I bought my first neon light screwdriver tester.
bill39 is online now   Reply With Quote
Old Yesterday, 06:53 AM   #179
Rewards Points: 102
I can't recall accurately but I think it was before that as we were still dealing with a lot of K&T on jobs.
Old Yesterday, 06:55 AM   #180
Rewards Points: 102
Best of luck with it, let u know what you think once it has a little time in grade.
