250V DC power supply - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 2 Post By MikeFL
  • 1 Post By just the cowboy
  • 1 Post By CoolWill
Old 06-28-2019, 08:10 AM   #1
Rewards Points: 46
Default 250V DC power supply
Anyone know a source for a 250V DC power supply? I have a customer looking for one to power a magnet. He says it is a 10 amp load. That's all the info I have. I haven't seen it and don't know the manufacturer.
Sent from my XT1650 using Tapatalk
Old 06-28-2019, 08:36 AM   #2
CoolWill's Avatar
Rewards Points: 2,016
How about a bridge rectifier and filter capacitor?
I'm With Her! Hillary 2016
Old 06-28-2019, 08:43 AM   #3
Rewards Points: 46
He told me it needs 250v and that a rectifier won't work because it's only 230-240v. It's a magnet for on a crane and they always have a power supply mounted on the machine.
Old 06-28-2019, 09:02 AM   #4
MikeFL's Avatar
Rewards Points: 2,712
I had something in mind until you said it's mounted on a crane.
Is this crane outdoors?
What are the ambient conditions?
Your supply is 240VAC and you need 250VDC 10A output?
You may want to check with the manufacturer/supplier/ dealer of the crane and of the magnet. Ask them how they do it.
MechanicalDVR and Bird dog like this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
MechanicalDVR (06-28-2019)
Old 06-28-2019, 09:06 AM   #5
Rewards Points: 280
Use a step-up to increase your input voltage to the rectifier.
Old 06-28-2019, 09:14 AM   #6
Rewards Points: 46
Ok. I talked to the guy again and he said he just wants to be able to test the magnet. So I would be looking for a cheap way to do it. Then he remembered that he just might have a power supply on another machine and is going to check that out. Thanks for your input. If it doesn't work for him with what he has I might be back asking how to do a rectifier as I haven't ever worked with them.
Old 06-28-2019, 10:01 AM   #7
just the cowboy's Avatar
Rewards Points: 378
Default We did this
Way back when.........
We took a Variack and ran it to a step up transformer then to the full wave bridge. Set proper voltage then hooked up test weight. We could then turn down voltage till weight dropped off to prove % voltage drop was safe.
Cowboy
micromind likes this.
The Following User Says Thank You to just the cowboy For This Useful Post:
Southeast Power (06-28-2019)
Old 06-28-2019, 10:53 AM   #8
Rewards Points: 1,992
just use 208v 3ph + a 3 phase rectifier, it will gives you about 243vdc with a lot less ripple than single phase rectifier, no need for capacitor
Old 06-28-2019, 10:55 AM   #9
Rewards Points: 46
No 208 on sight. They do have 480v
Old 06-28-2019, 10:56 AM   #10
CoolWill's Avatar
240 volts AC rectifies into about 338 volts DC. Then you can PWM it to what he needs.
Old 06-28-2019, 11:03 AM   #11
Rewards Points: 46
This is good. I'm learning things. I've never worked with DC much before.
Old 06-28-2019, 12:47 PM   #12
Rewards Points: 1,982
Buy a used 2 quadrant DC drive with a 480V input, lots of people are pulling these out to replace them with AC drives and motors, so the old DC drives end up surplus sites for dirt cheap.
240V input only gets you to 180VDC output..
Forge Boyz (06-28-2019)
Old 06-28-2019, 01:01 PM   #13
Rewards Points: 3,726
Is that or vice versa?
If it's reversed, am trying to think if there's something you can do with transformer taps to make 338VAC...
Old 06-28-2019, 01:06 PM   #14
CoolWill's Avatar
VAC x sqrt2 = peak DC, which without the capacitor averages to 0.637 x peak. With the capacitor, the voltage is pretty close to the peak.
splatz (06-28-2019)
Old 06-28-2019, 04:10 PM   #15
thats only when using capacitors, if no capacitor you will get 240vdc minus losses in rectifer
Old 06-28-2019, 04:27 PM   #16
CoolWill's Avatar
You get roughly 215 volts DC average, after rectifier losses with no capacitor.
