Extended device pigtails on equipment - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 1 Post By 460 Delta
  • 1 Post By Bird dog
  • 1 Post By Gnome
  • 3 Post By 460 Delta
Old 05-24-2018, 01:07 PM   #1
Rewards Points: 335
Default Extended device pigtails on equipment
I have a large job here that involves ingredient distribution through process piping, etc
The equipment is coming with devices attached and a lot of them have pigtails that are a couple feet long.
The environment entails stainless boxes so I have many small junction boxes in areas where I can pick up multiple devices, but there are still devices a ways out that their pigtails dont reach any local JBs.
Naturally, my PM is a cheapass so Im trying to figure out a cost effective way to extend these cables.
I would usually use a cast zinc rab box, but there is no nema rating on these boxes and a nema 4 rating is required, in addition to the stainless requirements.
Any thoughts or suggestions? In my searching and contact through my supply house, it seems like JBs smaller than 6x6 are not very common, but maybe we arent looking in the right place
Breakfasteatre is offline   Reply With Quote
Old 05-24-2018, 02:22 PM   #2
Rewards Points: 2,468
There are condulets that are rated NEMA 4, would that work?
http://www.cooperindustries.com/cont...letbodies.html
This too shall pass.
Old 05-24-2018, 02:51 PM   #3
460 Delta's Avatar
Rewards Points: 1,770
Like Splatz says, you can make up connections in a conduit fitting, I do it for solenoid air valves often. You may need to upsize your condulet fitting though.
active1 likes this.
micromind for moderator- make ET more industrial
Old 05-24-2018, 07:07 PM   #4
Rewards Points: 2,668
The master electrician I trained under considered a conduit body with a cubic inch mark as a small junction box as long as you followed the rules concerning the cubic inch capacity of the fitting.
Still better to ask then having to do rework on a new install (no idea what type of conduit you are installing but if its ridged it probably wont be a problem)
Old 05-24-2018, 07:13 PM   #5
Bird dog's Avatar
Rewards Points: 2,168
Have you ever done those calcs? Usually better off setting a box and flexing into it.
Old 05-24-2018, 07:42 PM   #6
Depends on the job. Installing a 6x4x4 stainless box for every low voltage analog sensor or prox switch connection is a great idea as it makes upgrading easier in the future. Its just expensive (t&m) and look a little odd.
Old 05-24-2018, 07:57 PM   #7
Bird dog's Avatar
This might be smaller, but, not sure.
p/n EJ443SS
http://www.newark.com/hammond/ej1614...nel/dp/50H3918
Old 05-24-2018, 10:40 PM   #8
Ctsparky93's Avatar
Rewards Points: 12
I got this box last week ej 6x6x4ss. rexel had it in stock for 120$ they have smaller sizes also. But like other have said if they want to be cheap conduit fitting with cubic inches marked can be spliced in. I prefer a t and a bell box with a wp cover. But if area is corrosive they donít last long.
https://www.hammfg.com/part/EJ664SS?referer=109
Ctsparky93 is offline   Reply With Quote
Old 05-25-2018, 08:51 PM   #9
Rewards Points: 863
Hoffman makes 4x4x3 clamp cover Nema 3R, 4, 4X, 12, 13 boxes in stainless. Warning though that because the 4x4 dimensions are outside and the flange subtracts from that they are a bit of a bitch to work in. I'm betting they aren't cheap (and in some cases a 6x6 is cheaper than the 4x4).
Cooper (Crouse-Hinds) makes a FD style box in stainless. Better looking and a bit easier to mount in many cases but I'd bet even more than a 4x4. Plus it's hubbed so you don't have to mess around with sealing rings etc. if using rigid.
Old 05-26-2018, 01:55 PM   #10
Going_Commando's Avatar
Rewards Points: 1,620
That's what I have done for solenoid valves and such. Just screw a C condulet on it and splice the small wires in that.
Old 05-26-2018, 05:02 PM   #11
460 Delta's Avatar
The secret is using a fitting one size larger and using a threaded bushing to reduce it down. That little bit makes a difference.
splatz, Bird dog and gpop like this.
Equipment bonding vs equipment bonding ElectricalArtist General Electrical Discussion 3 12-10-2017 07:00 AM
Two Questions from Apprentice maverick323 General Electrical Discussion 50 06-06-2017 06:26 AM
PV rapid shutdown device location katwalatapan Alternative Energy Forum 8 02-26-2016 10:50 AM
