MCC Room Requirements - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By Forge Boyz
  • 1 Post By JRaef
Old 04-08-2020, 06:38 AM   #1
Question MCC Room Requirements
I work at a sawmill and recently we has a steam turbine installed here to supplement power from our boiler house. The turbine output is rated for 575 volts and runs around 513 KW. The electrical equipment is in a room with questionable clearance and the construction of the room is not what I would typically see in an electrical equipment or MCC room. They basically built a couple walls and a ceiling from 2x4's and double 5/8" sheetrock. I have tried to find in the code book what the specific requirements are for this room as any I've ever worked in were steel and concrete. Any info is appreciated.
Electricman3 is offline   Reply With Quote
Old 04-08-2020, 06:58 AM   #2
Rewards Points: 60
In a sawmill? Just be glad you actually have a room to put the MCC in.
Sent from my SM-G970U using Tapatalk
gpop likes this.
Old 04-08-2020, 08:58 AM   #3
Rewards Points: 1,896
The actual room construction would be determined by local building codes. The electrical installation clearances and ingress/ egress would be determined by NEC article 110.
There are some specific NEC requirements if there are transformers located in this space. See article 450.
Old 04-09-2020, 02:01 PM   #4
Rewards Points: 562
The only thing that changes is the clearance distances when doors are open (table 110.26) based on conductivity of the wall material. Sheetrock is considered non-conductive, concrete IS considered conductive. I have, on a couple of occasions, added Sheetrock to a wall (one concrete, one corrugated steel) in order to decrease the clearances required.
The only other requirement is that MCCs are all rated for a maximum of 40C (104F) operation so the room must have adequate ventilation and/or air conditioning to be able to maintain that when everything is running. I have walked into some MCC rooms where the heat blast makes me swoon, then the users are complaining that their VFDs are continually failing "for no reason".
