RobRoy extends their line - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 1 Post By MechanicalDVR
  • 2 Post By Signal1
  • 1 Post By telsa
  • 1 Post By 99cents
Old 11-26-2018, 01:55 PM   #1
Rewards Points: 25,344
Default RobRoy extends their line
https://www.plastibond.com/
They're proud of their RedH2-OT sealing lock-nut.
See page 23 in November's Electrical Contractor magazine.
Opinions?
Old 11-26-2018, 02:19 PM   #2
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 1,924
Looks like nice stuff.
I'm gonna wire my whole house with that s**t!
Signal1 is online now   Reply With Quote
Old 11-26-2018, 03:57 PM   #3
Rewards Points: 3,456
I have only used Rob-Roy once; for a NG compressor station. While I definitely like the end product, it took quite a bit to get used to working with. It was easy to tear up the coating with a bender or even just moving it around the site. Treading was not too much fun either; it got easier as time went on, but I chewed up a lot of the coating to put a thread on a nipple.
Cheers
John
Old 11-26-2018, 04:20 PM   #4
Rewards Points: 17,458
I see!
Old 11-26-2018, 04:23 PM   #5
Cheers
John
There was a thread here a short time back that mentioned specially made dies and other tools for working with the stuff.
Navyguy likes this.
Old 11-26-2018, 07:22 PM   #6
Signal1's Avatar
If you follow telsa's link and click on "installation" it brings you to all that stuff.
Special clamps, dies and hand tools to work with it without damaging it. It must cost quite a bit to get set up for it.
Man it's gonna cost a lot to wire my house.
MechanicalDVR and telsa like this.
Old 11-26-2018, 09:00 PM   #7
A friend of mine always said he was going to do his whole house in conduit and I was surprised when he did it.
Old 11-27-2018, 06:28 AM   #8
Rewards Points: 694
I wish plastibond would get there 3/4 Tee redesigned. At least 30% have to cleaned with a npt tape or it will only twist on a few turns.
Nearly every type of pvc coated ridgid has a part that is a pain to use. One manufacturers hubs sucks, Another one the couplings sucks and they can be all over the place with conduit bodies. Lacks of quality control seems to be a major issue.
You can coat a turd in pvc but its still a turd.
Old 11-27-2018, 07:08 AM   #9
Is that 'tape' or 'tap' ?
glen1971 likes this.
Old 11-27-2018, 12:42 PM   #10
Rewards Points: 694
Tap...
Old 11-27-2018, 12:54 PM   #11
Rewards Points: 1,421
It's pretty much all I work with at my current place of employment. I can see a use for the sealing locknut because the hub fitting is about 50 bucks for the 3/4" size. The sealing locknut is probably only 5 bucks. I hope they come out with a special tool to tighten it, because I don't see a way to get the regular Ocal/RobRoy pliers on it. Transitioning from one conduit system to another has always been an issue, and T&B suggests putting heat shrink over the transition. This is the first product that seems to solve it with a mechanical means.
https://robroy.com/news/2017/new-rob...ealing-locknut
Old 11-27-2018, 01:09 PM   #12
Rewards Points: 10,177
When I was an apprentice, I was the guy with the paintbrush fixing the scuff marks.
Navyguy likes this.
Old 11-27-2018, 01:43 PM   #13
Yeah, we followed that / those processes and got the tools, or at least a version of them. Still was not fun to work with. Using oversized benders, wrapping pipe with emery cloth, was a pain. If that is all you worked with, then investing in a permanent set-up would likely solved this. It was the first and only time I worked with it and it was not my call to make back then...
Cheers
John
Old 11-27-2018, 02:56 PM   #14
Cheers
John
Two shops I worked for had some equipment they adapted and used for it but not specifically designed for the stuff.
Old 11-27-2018, 03:03 PM   #15
I think maybe I'll take some pictures of specialized PVC coated conduit tools.
Old 11-27-2018, 03:30 PM   #16
Dissenting Member
Wiresmith's Avatar
Rewards Points: 2,790
Cheers
John
were you using shoes for pvc coated rigid? or just over-sized shoes?
Think like a man of action, act like a man of thought. ~Henri Louis Bergson
Old 11-27-2018, 06:10 PM   #17
I can't say for sure; it was a long time ago (early 90s+/-), I still might have been apprentice or a fresh JM at the time.
I am guessing that we just used oversized benders, we had some jaws for our threader that were helped with not cutting in the coating. I don't remember how we threaded it together...
Cheers
John
Tags
robroy
Need 1 Line at 230 from 2 Lines at 230, 50hz Ari General Electrical Discussion 16 05-12-2018 01:06 PM
Do Ac Line Splitters exist in the UK davedave Tools, Equipment and New Products 26 06-28-2017 07:36 PM
Water line used as system ground. ELECTRICK2 Residential Electrical Forum 92 05-22-2017 06:48 PM
Buried Residential Service along Property Line Ceuls Canadian Electrical Forum 22 03-27-2017 03:39 PM
Voltage Fluctuation Mr.Awesome PLCs, VFDs, Motors and Controls 45 03-20-2017 12:40 AM
