welding unistrut clamps. - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
Old 11-09-2018, 06:32 PM   #1
Rewards Points: 946
Default welding unistrut clamps.
When you run unistrut (stainless) vertical in a area with a high level of vibration it seems the clamp always come loose and slip down. It might take years but every make and model of clamp seems to do this (mild steel is not to bad as it rusts and gives the clamp something to grip)
As a patch we tig the bottom clamp or use a spring nut and a square washer to act as a stop if the conduit slips. (normally years after original install)
I was wondering if you hooked a spot welder to the clamp after the conduit was installed (ground on the unistrut and stinger on the clamp) if you could get the contact points between the clamp and unistut to weld. Now it wouldn't be that strong that you couldn't wiggle it and snap it off and it defiantly wouldn't hold up to a couple of silverback mechanics hanging of it but it should stop the clamp from slipping.
Any thoughts?
Old 11-09-2018, 06:53 PM   #2
Rewards Points: 3,720
I never thought of that, it sounds like it should work.
I have just deformed the channel a little to make sure things don't slide.
Old 11-09-2018, 06:55 PM   #3
Cow
Rewards Points: 4,536
Hmm, good one.
We've wired some grain mills, getting ready to do another here shortly, but we use regular strut for those and weld it to the the frame work for vibration reasons. But, like you said, we've never had an issue, that I know of, with the strut straps sliding down.
I can't think of any place we've ran stainless that has had the issue you're describing. Interesting problem, sounds like a pain in the @ss to deal with though.
I wonder if there is a way to grind a notch with a skinny wheel, die grinder, whatever that would keep the strap from sliding.
On second thought, maybe welding a small ss nut or similar to the face of the strut right up against the bottom of the strut strap? At least then you could still remove the strap if needed.
Just throwing out ideas here...
Old 11-09-2018, 07:14 PM   #4
Chops146's Avatar
Rewards Points: 1,032
I have used spring nut, square washer and bolt for this. One rack where they didn't want the squares showing I used a spring nut and bolt, I think it was 1Ĺ", and turned it until it was grinding into the block behind the strut.
Gnome, Helmut and gpop like this.
None of us is as important as all of us.
Same plight, same fight.
An injury to one is an injury to all.
Chops146 is offline   Reply With Quote
Old 11-09-2018, 07:14 PM   #5
Rewards Points: 112
Iím no longer working as an electrician so my code book is stowed. Iím pretty sure there is a code prohibition about welding conduit straps shut. Welding the strap to the strut is possibly ok but welding the strap closed is prolly a violation. I know people that interpreted it as absolutely no welding on any conduit or clamps. Wish I could read again now.
Old 11-09-2018, 07:33 PM   #6
Rewards Points: 46
My brother is a hobbyist welder so I asked him about this. He says it's too great of an area for a spot welder to work. They concentrate the weld in a very small spot.
Sent from my Moto Z (2) using Tapatalk
Old 11-09-2018, 08:13 PM   #7
Rewards Points: 2,750
I have never used a welder once in my whole career. Except to practice with scrap on the night shift when there was little else to do.
I have never really seen an application where an electrician needed to weld anything or have anything welded.
In fact I was under the impression welding and electrical systems/support were a "No No"
A foreman in a plant who decided to practice his welding, decided to weld a Hoffman enclosure to strut once. To save time was his excuse.
It looked horrible. Even scorched the inside of that expensive enclosure.
I once had a ship yard electrician ask me "why not tack weld" the 2" EMT conduit to the strut to save time and not need any strut clamps. HUH?
Like I said. Never welded any electrical parts in my life and see no reason to start now.
I always thought it was hack. And silly.
I mean we are not pipe fitters. We have a product or part to do every job we can ever come up against. Welding something was never even considered.
Old 11-09-2018, 08:37 PM   #8
Cow
We weld all the time.
Ag services(on tube frame stanchions), strut brackets, transformer supports, conduit layout jigs for switchgear underground stubups, etc etc, on and on.
In my opinion, it's fairly limiting, if the only things an electrician can build are the ones they make strut brackets or electrical hardware for.
I've seen some real contraptions electricians have built out of strut and strut brackets, that would of been half as complicated and take half the time and resources, if they had just been welded.
For instance, I built this stanchion and had it powdercoated, because there wasn't enough wall space for this equipment. Another EC attached all the electrical equipment to it though.
glen1971, Forge Boyz and gpop like this.
Old 11-09-2018, 08:51 PM   #9
Rewards Points: 946
Working in a food grade stainless plant means welding as there are so many rules about making sure that the conduit and supports do not harbor food for bacteria. It why most strut is mounted vertical.
I have seen a new design for the food industry that is half round with a slot as a replacement for unistrut in SS so maybe that is the answer. In the mean time i might just borrow a spot weld timer and see what happens on some scrap. If it can tack the 4 small spots where the strut clamp grips it might work. The conduit is pvc coated ridgid (which may be the reason it loosens over time as the rubber between the strut and the conduit wears and compresses) So i do not think that a tiny weld will affect it.
Old 11-09-2018, 08:55 PM   #10
Rewards Points: 946
Isnt that a damp area with that ammonia vessel behind it (ice). Do the vfds hold up ok or do they grow mold?
Old 11-09-2018, 08:56 PM   #11
Rewards Points: 112
Iím surprised youíre allowed to use strut. That little lip curl ya about impossible for the porters to clean. Also when I did extensive work in a bakery the rule was all pipe work had to be min 3Ē off the wall to facilitate wall cleaning. We had to have a sheet metal co fab some stainless standoffs.
Kevin_Essiambre and gpop like this.
Old 11-09-2018, 09:02 PM   #12
Rewards Points: 946
Bakery's and places that use dry powder are way worse than a place that does liquids.
Old 11-09-2018, 09:13 PM   #13
Jlarson's Avatar
Rewards Points: 3,968
I wouldn't allow that just because it might leave stray arc marks.
We typically use food grade strut or ss angle and U bolts.
Old 11-09-2018, 10:26 PM   #14
Rewards Points: 3,698
Guess it all depends on the area(s) that one works.. We've welded thousands of supports over the years for electrical cable tray, unistrut, and structural steel (C-Channel, square tubing etc) for panels, disconnects, Junction Boxes, conduit runs, etc.. Some places where structural steel was fireproofed, they had very strict installation guidelines on how to build electrical supports so that they could later be properly fireproofed. One place had the switchgear welded to 4" C-channel that were set in place in the concrete floor.
Gnome likes this.
Old 11-10-2018, 07:26 AM   #15
86 45 20
Southeast Power's Avatar
Rewards Points: 7,878
I would just give the strut a nice squeeze with a pair of channel lock and it buggers up the channel enough to where the straps cant slide.
I have found a few straps and even conduits welded and its always some cross over trade Hack that has done it. It really sucks for the next guy that ends up having to bring out a grinder to do some simple demo.
We had a rack made like COW posted for a distribution panel but, I think I would draw the line at welding straps. Maybe consider vibration proof nuts or something else.
John Valdes, Flyingsod and splatz like this.
Old 11-10-2018, 08:10 AM   #16
Actually if you just nick the channel with a bandsaw, and drive a tiny sheet metal screw into the kerf, it isn't going anywhere, but if you remove the screw, you can move things around if you ever need to.
glen1971 likes this.
Old 11-10-2018, 09:32 AM   #17
Russian Bot
Helmut's Avatar
Rewards Points: 3,755
Count me in on the cone nut, bolt and washer crowd.
I wouldn't weld it.
Alright, Alright, Alright... I'll tell you what to do. Go that way, reeeeeeeeeally fast. If something gets in your way......turn.
Old 11-10-2018, 10:26 AM   #18
Rewards Points: 15,887
I haven't pulled out any of my welding machines in decades from the gang boxes they live in , but yes I can walk around the tarmac at Honolulu International Airport and point out probably a thousand pieces of strut people in my employ welded to jetways and other metal supports. Never tried welding a strap though, just mounting the unistrut to metal as a support means. If you have a guy working all day 5 days a week doing nothing else but welding like I had , you can cut a lot of time out of a project and it is a very good way to make some money , but you need something like that to make it worth the setup. You guys talk about mounting panels on plywood all the time. Well, we were mounting plate steel to iron column's and then spot welding panels to that.
Southeast Power likes this.
Old 11-10-2018, 11:13 AM   #19
Rewards Points: 112
Everything Can be done with strut but some things look way better with welded structural steel. Take for instance hanging a transformer. Get a fabricator to build a shelf for it and it looks like part of the building meant to be there. On the other hand hang it from all thread and strut like we often do and itís janky looking like an after thought. Strut to me (while I used it and really liked working with it) is like an erector set for adults. Itís toyish looking.
I love that idea about squeezing the strut as long as you can keep from scratching it. Scratches are places for bacteria to grow. Thatís also a concern with cutting or adding a set screw.
glen1971, splatz and gpop like this.
Old 11-10-2018, 01:43 PM   #20
Chops146's Avatar
What kind of straps are you using? If it's the PVC coated ones, there's your problem. All that PVC doesn't like gravity. There's a spray coating (I will edit this if I remember the name) that is listed to make rigid straps able to replace PVC coated. It allows for a much firmer grasp on the pipe! Just hang the straps from tie wire and spray them a good coat and dry overnight. I use bolts and nuts from PVC coated sets.
gpop likes this.
Conduit Clamps need to be certified CSA or not?? Explorer1 Canadian Electrical Forum 8 03-15-2018 11:07 PM
unistrut product, where do i get it?? benderbus Business, Marketing, and Sales 24 11-09-2017 06:25 PM
Welding Machine Cord Length martindag General Electrical Discussion 7 06-12-2017 04:10 PM
wiring for a welding receptacle McDaniel8402 Industrial Electrical Forum 16 03-01-2017 04:20 PM
Welding without a shield Nom Deplume Off Topic (Non Trade) 10 05-11-2016 11:59 PM
