welding unistrut clamps. - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
Old 11-10-2018, 03:39 PM   #21
Rewards Points: 3,004
We are using SS straps, We tried pvc coated and they never seemed to fit correctly.
If you consider how a strap works, The strap pulls the conduit tight against the unistrut. If you added a small wood spacer behind the conduit and tightened the clamp then removed it you would see 2 small indents in the wood where it made contact with the unistut. Now if you imagine its doing the same thing to the pvc coating add a little vibration and the pvc over time will deform which will lead to the clamp being loose. (also happens with most clamps used on pvc coated ridgid). It may take years but eventually the clamp slips and it looks bad.
Old 11-10-2018, 08:01 PM   #22
Chops146's Avatar
Rewards Points: 1,032
Yep. Just reminded me of what we did on a vertical rack of 2". We cranked the straps down then pulled them off. Then we cut the PVC off where the strap marked and sprayed the coating on. Next day, we rehung it and strapped it with 2" EMT straps we'd sprayed the day before and cranked the heck out of them. That was only 3˝ years ago, so can't tell you long term results.
Flyingsod likes this.
None of us is as important as all of us.
Same plight, same fight.
An injury to one is an injury to all.
Chops146 is offline   Reply With Quote
Old 11-19-2018, 07:24 PM   #23
I've used a tek screw as a stop, but I guess that would be pretty tough on stainless.
Kawicrash is offline   Reply With Quote
Old 11-28-2018, 01:05 AM   #24
QMED's Avatar
Rewards Points: 316
I went through a welding program and there were a handful of union electricians there getting their AWS certs for welding as it was required for some nuke plant so they could weld their own supports.
QMED is online now   Reply With Quote
Old 11-28-2018, 04:53 PM   #25
Rewards Points: 938
Use nylocks. They would be more expensive than regular nuts, but would hold up over time and with the vibration.
https://en.wikipedia.org/wiki/Nyloc_nut
Old 11-28-2018, 05:09 PM   #26
Rewards Points: 6,421
I use a fair bit of stainless strut, but it's the type that takes U-bolts for the conduit and not traditional Kindorf-type clamps, so slipping is not an issue.
Old 11-28-2018, 06:02 PM   #27
I have a sales guy bringing some different style out. We will test it to see if it can handle the vibration with out cracking then go from there.
The machines we use have a cam action and if they get in sync it will make the whole 60 x 100' deck jump.
Old 11-28-2018, 06:10 PM   #28
This is the stuff we use. Grainger carries it. https://foodgradesolutions.com/
The benefit in a food environment is that it's self-draining.
Conduit Clamps need to be certified CSA or not?? Explorer1 Canadian Electrical Forum 8 03-15-2018 11:07 PM
unistrut product, where do i get it?? benderbus Business, Marketing, and Sales 24 11-09-2017 06:25 PM
Welding Machine Cord Length martindag General Electrical Discussion 7 06-12-2017 04:10 PM
wiring for a welding receptacle McDaniel8402 Industrial Electrical Forum 16 03-01-2017 04:20 PM
Welding without a shield Nom Deplume Off Topic (Non Trade) 10 05-11-2016 11:59 PM
