Crazy things you've used EMT for - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrician Talk Community > Off Topic (Non Trade)
Like Tree148Likes
Old 01-10-2019, 10:35 AM   #41
Rewards Points: 18,604
Originally Posted by MikeFL View Post
Some pretty interesting responses here, for sure.
One physical property which never came to mind is the tensile strength of the material. Smash it flat for the last 2" and you can drill a hole for a hanger or bolt and carry quite a load with it.
I've used it that way for shelf supports and braces many times.
jelhill likes this.
Old 01-10-2019, 10:41 AM   #42
daveEM's Avatar
Rewards Points: 2,382
Originally Posted by CoolWill View Post
If it ever snows so much I need a machine to deal with it, I'll lay down in front of it and let you run me over with it.
I have a real snow blower for the heavy stuff (6, 8, 10, 12 inches... drifted, etc.). Crap -40 possible, - what a place I live in.
This morning I'm using my wireless 2 cycle power shovel which works really well on 1 inch of snow... as fast as you can walk. It will do up to 2 inches of the fluffy stuff.
tmessner likes this.
I like perfect.
Old 01-10-2019, 10:43 AM   #43
Watt Pusher
B-Nabs's Avatar
Rewards Points: 466
I use it for drilling and driving seismic anchors without using a ladder:
Duct tape a hammer drill to the end of a piece of 3/4", tape the trigger on, and walk along drilling 1/4" holes where needed in the concrete ceiling above.
Hammer the end of a piece of 1/2" flat leaving a big enough gap to insert a 1/4" eye wedge anchor, drill a hole about 3/4" back and put a 1/4"-20 bolt through (gives the wedge anchor something to butt up against). Pre-crimp 1/16" aircraft cable on a bunch of eye wedge anchors. Walk along and hammer anchors into your pre-drilled holes.
Also works great if the grid is already up.
splatz and MikeFL like this.
Old 01-10-2019, 11:02 AM   #44
MikeFL's Avatar
Rewards Points: 2,376
If you look at scaffold braces that's pretty much what they are, with a bolt where the X meets. Probably slightly heavier wall schedule but not by much.
jelhill likes this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 01-10-2019, 11:36 AM   #45
CoolWill's Avatar
Rewards Points: 1,636
Someday, I'm going to use some to build a geodesic dome.
Old 01-10-2019, 11:46 AM   #46
MikeFL's Avatar
Use a spot welder and that could go pretty quick.
CoolWill likes this.
GPS Timers
(833) GPS-TIME
Old 01-10-2019, 11:51 AM   #47
CoolWill's Avatar
You have more than 1 piece of snow machinery? Jeebus... I have some tanks of CO2 I'm going to release into the atmosphere just for you.
daveEM and splatz like this.
Old 01-10-2019, 12:22 PM   #48
Elderly Member
jelhill's Avatar
Rewards Points: 1,090
Originally Posted by B-Nabs View Post
How is the top piece of pipe secured? And is this 1" EMT?
1/2" EMT... I just use it for 500' reels of THHN (Usually #12 and #10) circuit pulls. I only use our heavy-duty fiberglass step ladder for 3 reels at a time with the rack bolted to the back side of it with 1/2" rigid straps. A bigger caddy that we built with 1/2" EMT is mounted on an old heavy duty materials cart with tech screws. Granted, caddy's for 500' circuit wire reels are not that expensive, but this was a way to use up a bunch of pieces of EMT and loose fittings during a time when projects were slow... 2009 for example! Also a good time for building temp poles. Things sure ain't slow here now, everybody is slammed!
We built a big rack once for heavy reels using strut and rigid conduit... but that is a whole different story.
jelhill is offline   Reply With Quote
Old 01-10-2019, 12:31 PM   #49
Elderly Member
jelhill's Avatar
I've made all kinds of brackets out of the stuff for garage storage.
As I was telling @B-Nabs, it is amazing what projects you can think up during dead times, like we had around here in 1982 and 2009. Reel caddys & racks... shelves... temp poles... ceiling racks for lumber.... bird feeders... etc. etc.
Old 01-10-2019, 02:37 PM   #50
82 I was working on satellite comm stations for RCA, I was pretty busy.
09 I retired from the union and moved south.
Conduit, a bender, a set of holesaws, and a mig welder and the possibilities are endless.
jelhill likes this.
Old 01-10-2019, 02:52 PM   #51
Rewards Points: 3,714
Built one last year for my nephew. PM me if you want some instructions.
Cheers
John
Old 01-10-2019, 03:20 PM   #52
just the cowboy's Avatar
Rewards Points: 344
Default Wind chimes
Different sizes and lengths make a great set of wind chimes. It also polishes up nice in a lathe.
I also new a guy that could play one like a trumpet and blow notes on it.
Cowboy
splatz, MikeFL and jelhill like this.
Old 01-10-2019, 04:15 PM   #53
MikeFL's Avatar
Should also be easy to electroplate.
Nickel would be really cool.
GPS Timers
(833) GPS-TIME
Old 01-10-2019, 04:17 PM   #54
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 5,218
Curtain rods when we moved into a new home years ago.
Folks next door thought them drop cloths were custom made curtains as they were up the same day.
Fishing pole cause I was off early and the salmon were running one day.
MechanicalDVR and MikeFL like this.
Old 01-10-2019, 04:26 PM   #55
Rewards Points: 3,636
1" EMT on the internal frame on my wall tent that I take hunting. It's going on 10 years with only a couple of bows in a couple of poles from a heavy snow one year..
splatz, MikeFL and CoolWill like this.
glen1971 is online now   Reply With Quote
Old 01-10-2019, 04:27 PM   #56
Small Potatoes
flyboy's Avatar
Rewards Points: 3,274
Clothes hanger for Cintas uniforms in the technician locker room.
Old 01-10-2019, 04:54 PM   #57
cog
stuiec's Avatar
Rewards Points: 1,106
THAT is an M. C. Escher perspective illustration of an improvised EMT wire rack.
Multitalented!
I get it now, after coming back......1st time it was all Escher to me.
Old 01-10-2019, 05:00 PM   #58
Rewards Points: 746
If you count all of the shovels by every door, the snowpushers by every door, the tractor loader with the snowblower on the 3 point and the the snow bucket in place of the regular loader bucket plus the jugs of ice melt by every door. I forgot the ice scrapers and the electric snow melt cable in part of the sidewalk. I need a BS degree to add it all up.
Old 01-10-2019, 07:29 PM   #59
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 526
I used 3/4" EMT and drilled a hole straight through the pull cover plate. Then drilled the crossbar EMT pipe and secured it with a wingnut. Easy off, easy on.
When I quit the business I gave them to my buddy. I need to make some more.
I'll draw a better one.
Cowboy words of wisdom.
Old 01-10-2019, 08:06 PM   #60
LARMGUY's Avatar
Rewards Points: 526
B-Nabs, splatz and CoolWill like this.
Crazy idea for Lotus Lights 99cents Canadian Electrical Forum 11 10-11-2018 12:20 PM
What things do you wish you had known as a journeyman? Cricket Featured Articles 22 08-24-2018 07:13 AM
Crazy voltage electricdummy General Electrical Discussion 1 03-31-2018 08:20 PM
Wholesalers Drive me crazy Maks77 General Electrical Discussion 29 12-08-2016 05:41 PM
