Removing Silicone Adhesive - Sealant - Caulk - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrician Talk Community > Off Topic (Non Trade)
Like Tree10Likes
  • 2 Post By PlugsAndLights
  • 1 Post By 99cents
  • 1 Post By splatz
  • 1 Post By MikeFL
  • 1 Post By 99cents
  • 1 Post By macmikeman
  • 3 Post By splatz
Old 11-03-2016, 08:41 AM   #1
Rewards Points: 2,470
Default Removing Silicone Adhesive - Sealant - Caulk
Someone else left a bit of a mess with silicone adhesive but if I don't clean it up the customer may assume it was me. I think I used 3m caulk remover before and it worked, but I am in outer Mongolia without even a hardware store for 45 minutes maybe more.
There is a Dollar General close by. Does anyone know, is there an ordinary household product that will remove silicone adhesive? WD40 did not work. I thought of
acetone / nail polish remover
lighter fluid / naptha
carb cleaner and brake cleaner
This too shall pass.
Old 11-03-2016, 09:04 AM   #2
MikeFL's Avatar
Rewards Points: 846
Can you just pull or pick it off? What's it on?
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 11-03-2016, 09:10 AM   #3
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
Your customer care is excellent. Mine is lower. If I couldn't clean it in
5 minutes I'd tell the customer it was already there and he should buy
3M caulk remover if (s)he wants to get rid of it.
YMMV
P&L
sbrn33 and splatz like this.
splatz (11-03-2016)
Old 11-03-2016, 09:15 AM   #4
It's around a hole through a piece of trim, some composite material. It isn't a smooth surface and it looks like they tried to wipe off the excess but made it worse.
Old 11-03-2016, 09:21 AM   #5
Rewards Points: 1,999
YMMV
P&L
Agreed. I charge money to fix code violations but the customer is on his own for violations of aesthetics.
splatz (11-03-2016)
Old 11-03-2016, 09:37 AM   #6
Most cases I would say F. it but the owner will be here to see the new construction for the first time and everything is perfect, I don't want any kind of blemish to interfere with that warm fuzzy feeling when they lay eyes on their finished product.
readydave8 likes this.
Old 11-03-2016, 10:37 AM   #7
MikeFL's Avatar
Rewards Points: 846
My concern is if you use acetone or similar you may cause more damage.
You could take a picture of preexisting conditions and make a suggestion on how they mitigate it.
Is there a punchout guy on the job?
GPS Timers
(833) GPS-TIME
splatz (11-03-2016)
Old 11-03-2016, 11:46 AM   #8
I would put a tool bag in front of it when they do the walk through .
splatz (11-03-2016)
Old 11-03-2016, 12:08 PM   #9
Rewards Points: 20,951
Wire brush on a high speed drill or even better a dremmel.
splatz (11-03-2016)
Old 11-03-2016, 12:15 PM   #10
Good point, I tested on a small spot to see if it ruined the finish first.
Old 11-03-2016, 12:19 PM   #11
Turned out acetone and a magic eraser sponge took it off pretty easily. Too much scrubbing and I think it would have taken off some finish but with a light touch it cleaned it up nicely.
99cents, PlugsAndLights and MikeFL like this.
The Following 2 Users Say Thank You to splatz For This Useful Post:
MikeFL (11-03-2016), telsa (11-03-2016)
