#10 solid in conduit - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 04-25-2010, 07:12 PM   #41
Rewards Points: 250
Originally Posted by varmit View Post
Years ago, solid wire was used on almost everything up to and including #10. Stranded use was mostly for motor circuits as it is not a good idea to use crimp lugs on solid wire. Terminating motors with wirenuts was usually a "get run off" offense.
Before THHN became the default wire of choice, we used solid TW pulled from the center of a cardboard box. This was not fun to pull, especially #10, as the wire pulled out of the box like a big long 500 foot spring. Pulling solid or stranded THHN off of a roll that can revolve around a piece of pipe is easy compared to the old ways.
I guess all this means that I am old enough to remember history.
In actual fact, solid copper wire came in #8 and 3 # 8 rw solid in 3/4" emt was the most difficult wire pull imaginable, this was before EZpull ! Ah for the good old days, BillW.
wwilson174 is offline   Reply With Quote
Old 04-25-2010, 07:20 PM   #42
Podagrower's Avatar
Rewards Points: 568
Originally Posted by Voltech View Post
Is the insulation getting nicks or if that clear coating over the insulation?
I would use solid #10 or #12 over stranded any day. Its faster to install IMO.
The clear coating, but if it wasn't important, they wouldn't put it on the wire...
Podagrower is offline   Reply With Quote
Old 04-25-2010, 07:41 PM   #43
Rewards Points: 2,050
I have read that is THHNs gasoline and oil resistant part.
Someone had posted the UL testing standards and when they do the dielectric testing they strip the plastic off.
Old 04-25-2010, 07:43 PM   #44
Rewards Points: 6,421
The nylon outer covering is completely optional anyhow. It is allowable to make THHN without the nylon outer covering. I think that's a footnote in table 310-something-or-other.
Old 04-25-2010, 08:08 PM   #45
Les Voltage
Its never important when I use it...
Old 04-26-2010, 03:42 PM   #46
220/221's Avatar
Rewards Points: 4,328
Why do they make it then!?
Because they are morons too.
The world is ful of them.
Old 04-26-2010, 03:44 PM   #47
I own stock in FotoMat!
Rewards Points: 6,520
Table 310.13(A). Note 1 states "Some insulations do not require an outer covering."
But T310.13(A) states THHN has an outer covering of "Nylon jacket or equivilant".
Old 04-26-2010, 03:47 PM   #48
Fried Bologna um um good!
jwjrw's Avatar
I pull whatever I get the best price on or whatever I have left laying around. I would rather terminate solid but stranded is easier to pull.
Old 05-14-2010, 01:41 AM   #49
ok how do you hold onto #10 while twisting it? I'm having trouble holding it firm. I tried holding it together with smooth jaw pliers but it still pinched the insulation.
Conduit Phil is offline   Reply With Quote
Old 05-14-2010, 08:12 AM   #50
JohnR's Avatar
In schools or on some commercial jobs the architect specs solid up to 10 here in CT.
After struggling with pulling a bunch of long runs with #10 in a 1"C. Job was 1.3 mil Sq ft. so there was plenty of it.
I finally got a chance to ask one of the architect's engineers why they made such a ridiculous requirement. His answer was that a splice made with solid and wirenuts was the only splice rated for 25 years without failing. what a joke.
Correct me if I am wrong, but isn't the clear coating that gets DEstroyed part of the W in THWN? so if it is underground then just in pulling it in, we have ruined the rating if it is scraped?
Signed out.
Old 05-14-2010, 11:15 AM   #51
I don't have that much experience with stranded, but any time I've made a splice with it, it doesn't seem as solid as well, solid. Solid will twist around each other and hold its shape. How do you get stranded to do that? Theres no pre-twisting with stranded, is there?
Old 05-14-2010, 12:14 PM   #52
I
When I hear stuff like that, it makes me want a requirement that building wiring engineers get some kind of practical instruction on wiring practice as part of their degree, or do an internship with an electrical contractor, maybe even put some tools on and do some work! It would go a long way towards eliminating silly specs like that.
Fusion is offline   Reply With Quote
Old 05-14-2010, 12:18 PM   #53
As far as I know UL strips the plastic of when doing their dielectric testing on THHN.
The plastic outer is part of the Gasoline and oil resistance rating not the wet location rating.
The Following User Says Thank You to Bob Badger For This Useful Post:
JohnR (05-16-2010)
Old 05-14-2010, 02:42 PM   #54
Square D
david wise's Avatar
Just had to pull out 300ft. #10 solid out of underground pipe for our parking lot lights. Repulled with strainded. I always TRY to pull strainded when possible. Solid 10 strips easily though
david wise is offline   Reply With Quote
Old 05-14-2010, 06:43 PM   #55
Rewards Points: 3,522
Originally Posted by sparks134 View Post
I've never seen it before, must be a beeaatch to pull in conduit!
You ever pulled 750 kcmil copper?
The Following 2 Users Say Thank You to brian john For This Useful Post:
sparky970 (02-25-2014)
Old 05-14-2010, 06:45 PM   #56
Nope, never. Don't care if I never do either. I saw it on a reel once in a warehouse and decided right then and there that it was evil.
Old 05-14-2010, 09:15 PM   #57
Rewards Points: 250
The biggest cable I ever pulled was 1500mcm PILC 15KV , I have a piece of it on my work bench as a souvenir! I ran some exposed 2000mcm on another project but it was not in conduit. I don't have any of that cable but I have one of the lugs ! Ahhh --memories!
Old 05-14-2010, 09:25 PM   #58
Why not? Wrestling big wire is more manly.
Yes, my e-penis is longer than yours.
Fission is offline   Reply With Quote
Old 05-14-2010, 09:33 PM   #59
1000 kcmil was the biggest I have worked with.
Old 05-16-2010, 11:19 AM   #60
Rewards Points: 504
Paralell runs of 4/750kmcm Tech90 in a grid ceiling
Mike_586 is offline   Reply With Quote
Stranded or solid 12 awg wire? calimurray General Electrical Discussion 99 06-16-2014 12:23 AM
good solid 10 in 1 (Ideal) bduerler Tools, Equipment and New Products 7 10-22-2009 12:04 AM
why solid bonding conductor te12co2w NEC Code Forum 34 03-02-2009 08:55 AM
Solid State Relay simmo General Electrical Discussion 9 09-15-2008 12:30 PM
Solid Fuel Heating Mountain Electrician Off Topic (Non Trade) 4 04-29-2008 07:54 PM
