1000 watt dimmer - Electrician Talk - Professional Electrical Contractors Forum
Old 04-01-2010, 11:16 PM   #1
Default 1000 watt dimmer
Has anybody seen a 1000 watt dimmer that will fit in a 3gang box with 2 other switches. Or does it need its own box.The ones ive seen are the ones that have the fins on them for cooling . Might be to late roughed in and dry wall up.
hot wire is offline   Reply With Quote
Old 04-01-2010, 11:18 PM   #2
Default Joe
Put a tandem switch in left side of box, leave middle open, then dimmer. We use a rotozip and cut back of box out for extra cooling as well.
GitRDoneElectric is offline   Reply With Quote
Old 04-01-2010, 11:19 PM   #3
I own stock in FotoMat!
Rewards Points: 6,520
Originally Posted by GitRDoneElectric View Post
.........We use a rotozip and cut back of box out for extra cooling as well.
I hope this is an April Fools' joke.
Old 04-01-2010, 11:19 PM   #4
Rewards Points: 5,198
What kind of wattage are you dimming? Does it HAVE to be that large?
Old 04-01-2010, 11:20 PM   #5
Default bob
shhh, we have 2 hrs left....
Old 04-01-2010, 11:21 PM   #6
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,028
Last dimmers I installed were 2000 watts, we did not cut the back of the box out.
Old 04-01-2010, 11:24 PM   #7
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
Yeah, they have cooling fins on them....They stick out a little...I've never had a problem with them not fitting....Maybe derate one side of the switch or go up to a 1500...
Old 04-01-2010, 11:26 PM   #8
Rewards Points: 6,421
They'll fit in a box with regular switches with the fins on them. Not sure I follow your reasoning for wanting to break them off if the other switches are just switches and not dimmers.
Old 04-01-2010, 11:27 PM   #9
child please.....
Rewards Points: 14
Yeah, I've never had a problem with them fitting either...I'm also a great mechanic, so that may be why.
Old 04-01-2010, 11:39 PM   #10
You mean you do tune-ups and rebuild carburetors too?
Old 04-01-2010, 11:43 PM   #11
child please.....
Rewards Points: 14
Yeah, I used to work on lawnmowers...But, I also consider myself a "mechanic"...A mechanic that can actually read, write and can understand algebra. Oh, yeah did I mention I'm also a college graduate...I'm kinda like a renaisaance man like Ben Franklin, minus the syphylis thing.
Old 04-01-2010, 11:46 PM   #12
Licensed Journeyman
nolabama's Avatar
The 2000 watt lutron nova series needs its own two gang box, but the 1000 watters should give you no problems.
Old 04-01-2010, 11:48 PM   #13
child please.....
Rewards Points: 14
The last one I installed (2000 watt lutron) could be used in a 1 or 2 gang box...
Old 04-01-2010, 11:49 PM   #14
Spark
Marcus's Avatar
Rewards Points: 504
hey mate you could try a DIN mount 1000W dimmer to fit in the switchboard - but then you would have to run the switchwire and switched loop to the light back to the board. maybe too late if the plaster is already up, hey.
Marcus is offline   Reply With Quote
Old 04-01-2010, 11:50 PM   #15
Yeah, I can't say that I've ever used a dimmer in the 2000 watt range that "must" have a 2-gang box. They seem to all come with holes to mount them on either a 1 or 2 gang box. I generally set a single-gang, since they don't cover a whole lot around a 2-gang box... gives the sheetrockers some margin of error.
Old 04-02-2010, 12:07 AM   #16
220/221's Avatar
Rewards Points: 4,080
We install 1000 watt dimmers all the time. They are the same size as a 600 watt dimmer.
They do get hot though. It's probaby our #1 complaint.
You do have to break the tabs to install them next to a decora switch. That knocks the rating down to....????? 940???
Old school!
Found this in my warehouse a couple years ago, still in the box.
Old 04-02-2010, 01:08 AM   #17
danickstr's Avatar
Rewards Points: 568
lutron makes 1000w and 600w dimmers standard. should not be a problem. they just fit in a regular 1 gang. most of their line comes 1000w or 600w depending on what you want to pay, what you need.
danickstr is offline   Reply With Quote
Old 04-02-2010, 09:35 AM   #18
Licensed Journeyman
nolabama's Avatar
That cooling fin dimmer that 220/221 is what i am talking about. I guess I should have said it will fit in a single gang box but 2 will not fit in a 2 gang box.
Old 04-02-2010, 10:24 PM   #19
whats the deal with some of yalls replys i ask if a 1000 watt dimmer would fit in a 3 gang box with 2 other switches.
Old 04-02-2010, 10:26 PM   #20
Yes!!!
T-Bays versus 1000 watt High bays garfield General Electrical Discussion 1 03-17-2010 10:10 PM
Fluke T5-1000 cdnelectrician General Electrical Discussion 20 01-23-2009 03:00 PM
Fluke T5-1000 iAmCam Tools, Equipment and New Products 26 11-28-2008 05:36 PM
can i run an 1800 watt a/c unit on an extension cord? jmatthews General Electrical Discussion 1 07-14-2008 06:41 AM
Anybody else use the Condrive 1000?? NC_Electrician Tools, Equipment and New Products 3 04-03-2007 09:12 PM
