1000 watt dimmer - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 04-02-2010, 10:26 PM   #21
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,028
we were being april fooley
Old 04-02-2010, 10:27 PM   #22
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
Originally Posted by hot wire View Post
whats the deal with some of yalls replys i ask if a 1000 watt dimmer would fit in a 3 gang box with 2 other switches.
Are they standard switches?....If so, then YES they will....I've never had a problem...I believe that several people have said so.
Old 04-02-2010, 10:27 PM   #23
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Has anybody seen a 1000 watt dimmer that will fit in a 3gang box with 2 other switches. Or does it need its own box.The ones ive seen are the ones that have the fins on them for cooling . Might be to late roughed in and dry wall up.
I think for a 1,000 watt dimmer w/o fins in a 3-gang box is good for less than 800 watts.
Replies based on NEC 2014
Old 04-02-2010, 10:28 PM   #24
Licensed Journeyman
nolabama's Avatar
just dont cut the back of the box out
and remember if it is a 2000 watt it will fit but the other two switches will not
Old 04-02-2010, 10:32 PM   #25
child please.....
Rewards Points: 14
That's how they do it in Chalmette
The Following User Says Thank You to NolaTigaBait For This Useful Post:
nolabama (04-02-2010)
Old 04-03-2010, 12:22 AM   #26
absolutley, (dont cut back of box)!!
rnr electric is offline   Reply With Quote
Old 04-03-2010, 12:44 AM   #27
220/221's Avatar
Rewards Points: 4,122
Cut the top out. Heat rises.
220/221 is online now   Reply With Quote
Old 04-03-2010, 01:30 AM   #28
Here's a ganging chart from Lutron:
http://www.lutron.com/product_technical/ganging.asp
A diva (for instance) will have difficulty fitting between Decora switches. When you break off a side, you derate. For a Diva, one side removed makes it a 800 watt dimmer, two sides removed an it's a 650 watt.
So to answer the original poster's question, it depends on the type of dimmer and type of switch you are using.
I had a customer ask about a hot dimmer and found that the installer had broken off both sides when mounting it at end of a three gang. In the end, I changed all the lamps in a large chandelier to lower the load. They never used the fixture full bright anyway.
egads is offline   Reply With Quote
Old 04-03-2010, 08:57 AM   #29
what the guy is trying to find is a 1000 watt 3 way dimmer.And the 2 other switches that are in the same box is 3 ways also.The dimmer is on 13 6 inch recess cans that goes around the room THE 600 watt dimmer he put in is hot as fire i told him 13x75 is more that 600. but every thing is roughed in and dry walled. Why do the 1000 watt dimmers get hot to are you talking hot or warm to the touch.hot wouldnt be good.
hot wire is offline   Reply With Quote
Old 04-03-2010, 10:41 AM   #30
Rewards Points: 1,810
Lutron's Ariadni or diva style dimmers come in 1000 watt and look exactly like the 600 watt units and fits with other switches.
Multi-Unit Installations
When combining controls in a wallbox, remove all inner side sections prior to wiring (see below).
Use pliers to bend side section up and down until it breaks off. Repeat for each side section to be
removed. Reduction of dimmer capacity is also required. Refer to chart below for maximum
dimmer capacity.
I am not sure what this means but it appears you need to derate even if you don't break the tabs, say, in a 3 gang install.
Model Number No sides removed 1 side removed 2 sides removed
AY-600P / TG-600P 600W max. 500W max. 400W max.
AY-10P / TG-10P 1000W max. 800W max. 650W max.
AYLV-600P 600VA/450W max. 500VA/375W max. 400VA/300W max.
I only break off tabs if necessary. If that is the only dimmer in the box then you won't need to remove the tabs
I can't help it if I'm lucky
Old 04-03-2010, 12:25 PM   #31
220/221's Avatar
no problem
problem. You will need to break a tab and lose the 1000 watt capacity.
He should have done the math at rough in
Why does your plasma TV get hot? Probably the same reason. They WILL get hot. VERY hot if fully loaded.
Just pull the 3gang box out, add another switch leg and split the cans up in a logical manner.
If you want to half ass it, lose the 75 watt lamps. If they are R 30's, change to 50 watt par 30 halogen. The light will seem brighter but the wattage will be dropped by 33%
If the are already par 30's, change them to 50's and hope the HO doesn't notice.
Old 04-03-2010, 03:00 PM   #32
On the Lutron site, they suggest adding a single gang box adjacent to the existing and connecting them with a chase nipple. That would move the hot 1000watt to it's own area.
In the case I cited above, the homeowner also had some arcing in the 3 way at the other end. So lowering the load was a big part of my solution.
I speculate that the switches are Decora. In that case both a derated 1000w dimmer (to 850) AND lowering the recess wattage are necessary.
Now let's hope the original electrician accounted for the heavy lighting load. If not, there is some very hot #14 romex in the walls as well.
Old 04-03-2010, 03:20 PM   #33
I own stock in FotoMat!
Rewards Points: 6,520
Originally Posted by 220/221 View Post
......He should have done the math at rough in .......
Some times you do, but the HO changes their minds once things are trimmed out.
More than once I've gone 'round and 'round with a HO about dimmers, and they flat-out don't want them. Until, of course, after the walls are all finished.
I pre-empt this by running more than one switch leg to the switch box.
T-Bays versus 1000 watt High bays garfield General Electrical Discussion 1 03-17-2010 10:10 PM
Fluke T5-1000 cdnelectrician General Electrical Discussion 20 01-23-2009 03:00 PM
Fluke T5-1000 iAmCam Tools, Equipment and New Products 26 11-28-2008 05:36 PM
can i run an 1800 watt a/c unit on an extension cord? jmatthews General Electrical Discussion 1 07-14-2008 06:41 AM
Anybody else use the Condrive 1000?? NC_Electrician Tools, Equipment and New Products 3 04-03-2007 09:12 PM
