120 volt, 20 amp on #6 wire - Electrician Talk - Professional Electrical Contractors Forum
Like Tree25Likes
Old 05-02-2018, 05:30 PM   #1
Sblk55's Avatar
Default 120 volt, 20 amp on #6 wire
Our plant is adding what I am calling a redundant phone system.
They call it a "diversified" system.
The phone people hand me a paper listing what I need to provide for their install.
They require a 120 volt, 20 amp receptacle fed with #6 wire. Any ideas why?
Thanks Steve
Sblk55 is offline   Reply With Quote
Old 05-02-2018, 05:41 PM   #2
German Spy
Helmut's Avatar
Rewards Points: 4,711
Thanks Steve
First thoughts:
1. how far is the homerun, and what size load?
2. They want the #6 going to steel frame for ground?
3. Phone company engineers are idiots.
Old 05-02-2018, 05:45 PM   #3
Chief Flunky
Rewards Points: 366
Originally Posted by Helmut View Post
First thoughts:
I’ll say #3, final answer. Or should I phone a friend?
Old 05-02-2018, 05:49 PM   #4
Sblk55's Avatar
I would say #3 they have no idea where I am getting the power, which turns out to be 30 ft. and the building is 200 year old brick and wood.
Tha paper they gave me looked to be a standard form they must give to everyone.
Old 05-02-2018, 06:13 PM   #5
Rewards Points: 2,320
Are you sure the #6 isn't a separate ground for the phone system. Many of these systems call for a redundant ground
I can't help it if I'm lucky
Old 05-02-2018, 06:20 PM   #6
Rewards Points: 976
Thanks Steve
Is there any reference to BICSI, if so just ignore it, it was created by a bunch of old fat lazy telephone guys.
Roger
MTW likes this.
Roger is offline   Reply With Quote
Old 05-02-2018, 06:26 PM   #7
Bird dog's Avatar
Rewards Points: 582
First thoughts:
IIRC a #6 CU for hot, neutral, and ground would be 5% voltage drop at 300' for a 16amp load.
active1 likes this.
Old 05-02-2018, 06:27 PM   #8
German Spy
Helmut's Avatar
See option 3.
Bird dog likes this.
Old 05-02-2018, 06:35 PM   #9
Sblk55's Avatar
I will check on that tomorrow. I did not have the paper long before the foreman took it to make a copy. Redundant ground would make more sense. I hope you are right, getting a #6 on a 20 amp breaker or 20 amp receptacle may be tough.
Old 05-02-2018, 06:35 PM   #10
Southeast Power's Avatar
Rewards Points: 9,258
Thanks Steve
What is the transition onto the receptacle going to be?
Terminal block?
I don't think there is a .6 sq mm wire but, it would be a perfect size for about a#12
Old 05-02-2018, 07:04 PM   #11
Rewards Points: 2,888
And most modern electronics have a switching power supply that will tolerate pretty broad range of voltages without a blip.
Bird dog (05-02-2018)
Old 05-02-2018, 07:06 PM   #12
The TIA/EIA telecom grounding and bonding standards often call for a ridiculous monstrous ground wire for grounding bus bars.
Old 05-04-2018, 12:31 AM   #13
HandyManDan928's Avatar
Rewards Points: 98
I concur with the ground wire theory ... I've always wondered what it's supposed to do for them ... it's not like any of those 24ga wires are going to outlast a lightning hit ...
HandyManDan928 is offline   Reply With Quote
Old 05-04-2018, 09:32 AM   #14
Rewards Points: 6,421
When I worked at AMP, we made plenty of rings and forks and such to go from #6awg (and larger) to a #8 or #10 screw, so there's terminals in the marketplace to get a #6 on a receptacle screw.
I'm trying to think of what you'd need for bend radius to get the thing in a box. Maybe a deep 4-11 with an RS cover might work . Might need an extension ring on it too. Best of luck.
Old 05-04-2018, 09:34 AM   #15
What I know about senseless phone guy requirements: If you don't follow them to the letter you'll get blamed for all sorts of illogical and senseless things from now until eternity. The path of least resistance is to follow the idiotic requirements.
Old 05-04-2018, 10:10 AM   #16
Chief Flunky
Rewards Points: 366
The crazy ground stuff is because they’re pushing very weak (a few volts) audio frequency (0-3000 Hz) signals everywhere unshielded. Inductive pickup is the rule of the day so they go bat blank thinking grounding can/will fix signal interference issues rather than the obvious solutions the rest of us use (proper grounding AND shielding, isolation, separating ground systems, use current instead of voltage signals, get away from 60 Hz and the 0 V noise floor).
HandyManDan928 likes this.
Old 05-04-2018, 12:04 PM   #17
Rewards Points: 24,212
I'm in agreement with the guys that say the #6 is for grounding.
Old 05-04-2018, 01:14 PM   #18
German Spy
Helmut's Avatar
You know, when you think about this.
How many electricians do you think out there, take this literally, and run 6 romex or mc to a box, pigtailed a #12 to the #6, and shoved it all in a 1900 box with a raised cover?
Only to find out the #6 on the print was for the ground.
Then they beat a ground rod in the floor, and connected the #6 to it?
I can see this happening after seeing some crazy stuff in my day.
Old 05-04-2018, 03:19 PM   #19
Certified Organic A-Hole
pudge565's Avatar
Rewards Points: 1,036
I was going to remark that receptacles are not to be connected to wire larger than 10 AWG per the UL listing but that is not contained in RTRT of the UL product spec. It may be a manufacturer instruction that I am remembering so always check those. Also see my comment to MD's post below.
Per UL product category RTRT, this is only permissible if the manufacturer identifies the terminals for such use. The only manufacturer I know of that does so is Hubbell but there may be one other that I can't remember right now.
This is what the UL product spec says:
"Terminals of a receptacle are permitted for use with certified field-installed crimped-on wire connectors or an assembly, if so identified by the manufacturer."
Old 05-04-2018, 03:37 PM   #20
Then there's millions of receptacles with prefabbed ground pigtails installed noncompliantly.
Converting a 3 wire 3 phase aux panel to 4 wire Elec Trix Commercial Electrical Forum 10 01-13-2018 06:33 AM
T-stat wire at 120V: Lamp Repair boot Off Topic (Non Trade) 5 09-23-2017 06:38 PM
600 Amp, 208 Volt, 3 phase, 4 wire Service for new tenant Atlas960 Commercial Electrical Forum 2 08-22-2017 02:27 PM
220 volt contactor with 24v thermostat wire J V General Electrical Discussion 7 05-10-2017 09:34 AM
Wire Strippers for #18 stranded 2 conductor !Tom Tools, Equipment and New Products 22 05-04-2016 08:22 PM
