12V emergency lighting systems - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By RePhase277
  • 2 Post By MTW
Old 11-10-2017, 09:00 PM   #1
Rewards Points: 334
Default 12V emergency lighting systems
I have a customer (condo complex) with an old emergency lighting system. 2 head units in hallways with master boxes in the basement with batteries to power them in the event of a power failure. They fail frequently and don't run for long. The customer would like me to propose on replacing them with LED units.
Can someone recommend brands/products that I should look at? Would I be crazy to keep the existing old master units and only replace the lights heads and batteries?
Here are some example pictures:
12V emergency lighting systems-img_20171108_095917.jpg   12V emergency lighting systems-img_20171108_102126.jpg   12V emergency lighting systems-img_20171108_102145.jpg
shocksystems is offline   Reply With Quote
Old 11-11-2017, 01:12 AM   #2
Rewards Points: 1,360
It's likely you can find an LED bulb to fit the socket in the existing heads.
The charging circuit is what fails most often in old units like that, so just doing heads and batteries is a dead end.
Something like the AS-series products from Dual-Lite is probably what you're looking for.
The Following User Says Thank You to RePhase277 For This Useful Post:
shocksystems (11-11-2017)
Old 11-11-2017, 02:43 AM   #3
Rewards Points: 18,235
Perfect candidate for a. photovoltaic charging system.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 11-11-2017, 03:27 AM   #4
Rewards Points: 1,510
What exactly, "fails" ?
Batteries
Lamps
Control equipment
what ?
Old 11-11-2017, 08:23 AM   #5
Rewards Points: 334
Batteries
Lamps
Control equipment
what ?
The lamps I believe, based on the customers explanation.
Old 11-11-2017, 08:28 AM   #6
Rewards Points: 334
It looks like the AS-series is incandescent bulbs .... http://www.dual-lite.com/products/as_maintfree
Old 11-11-2017, 10:36 AM   #7
The heads attached to the unit come as incandescent, but I don't see a requirement that only incandescent lamps be supplied from it. It's rated in watts.
shocksystems likes this.
Old 11-11-2017, 10:58 AM   #8
MTW
Rewards Points: 10,228
Take the heads down and replace with LED heads. I buy that stuff on econolight.com. As for the battery box, the charger is probably shot so just buy a new one. It can be much smaller with an LED system.
But assuming the charger is still putting out the right voltage (around 13 or so) then go ahead and change the heads and keep that battery box. You can replace the batteries with smaller ones.
The Following User Says Thank You to MTW For This Useful Post:
Old 11-11-2017, 07:36 PM   #9
DITTO !
Replace the incandesant heads with LED.
Its the easiest option !
Much easier than replacing everything
And running new wires !
Emergency lighting Sparky_136 General Electrical Discussion 14 07-12-2018 07:18 PM
CCTV, Alarm systems, Access Control, and Fire alarms Kevin_Essiambre Structured Wiring 21 12-10-2017 04:46 PM
A very unusual lighting senerio....... Ghostnotes1221 Lighting Design 6 10-22-2017 02:51 PM
extra low voltage lighting systems and led luminaires supplied by class 2 circuit? mike883 Canadian Electrical Forum 5 09-30-2017 06:17 PM
Lighting Circuit Loading Kunolop Canadian Electrical Forum 8 03-06-2016 10:31 PM
