Is this a 15 or 30 amp plug? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
  • 1 Post By wildleg
  • 1 Post By frenchelectrican
  • 3 Post By Southeast Power
  • 1 Post By micromind
  • 1 Post By ppsh
  • 2 Post By Fishbulb
  • 1 Post By Islander
Old 11-22-2016, 03:57 PM   #1
Islander's Avatar
Rewards Points: 630
Default Is this a 15 or 30 amp plug?
Hey everyone!
Can you tell me if this plug would require a 6-15R or a 6-30R receptacle? I haven't actually seen it in person. The drywaller sent a pic to me, so that I can get something set up for his dryer that he uses for drying the mud.
I know it should be a 30 Amp, as the dryer is a 4800 watt model, running at 240V. However, I can't tell what it is from his blurry photo.
TIA
Islander is offline   Reply With Quote
Old 11-22-2016, 04:08 PM   #2
Rewards Points: 1,830
Could be either depending on the size of the plug. A 15 amp unit will look like a standard size while the 30 amp male end will be slightly larger-- Looks like 15 amp to me but from the pic I am not sure
Old 11-22-2016, 04:18 PM   #3
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
I don't see how you can put 4800w on a 15, but what do I know.
electricguy likes this.
Old 11-22-2016, 04:24 PM   #4
Islander's Avatar
Rewards Points: 630
Me neither. He mentioned he had an adaptor, which I assume will allow it to run on 120 volts. That would drop it to 1200 Watts, which should be fine.
Old 11-22-2016, 04:38 PM   #5
Rewards Points: 21,898
Ya that true .,,
Actually 4800 watts on 240 volts is 20 amp right there .,,
The quickest clue you will know is if someone used a quarter next to the plug that will give you a answer because the 30 amp verison is larger than 15 amp plug is.
I will make a safe bet that is a 30 amp verison there.
telsa likes this.
Old 11-22-2016, 09:36 PM   #6
Southeast Power's Avatar
Rewards Points: 8,720
Originally Posted by Islander View Post
Hey everyone!
TIA
7/10 it's a 5-15p just due to the size of the ground.
Next time, for scale, have him take a pic with a banana adjecent to the subject.
Old 11-22-2016, 09:37 PM   #7
Rewards Points: 3,128
If it's about 2" wide, then it's a NEMA 6-30. 30 amp, 250 volts. The 6-15 would be about an inch wide.
My bet is a 6-30.
frenchelectrican likes this.
Old 11-23-2016, 12:35 AM   #8
Islander's Avatar
Rewards Points: 630
I'm hoping it's a 30, because that is what I wired up for him.
Old 11-23-2016, 01:06 AM   #9
Fishbulb's Avatar
Rewards Points: 110
A 6-30p would not normally have that orientation. Usually the ground pin would be away from the cord. It isn't that 'backward' 6-30p cord assemblies don't exist but they are unusual.
Fishbulb is offline   Reply With Quote
Old 11-23-2016, 01:21 AM   #10
ppsh's Avatar
Rewards Points: 126
Prongs look wider, and spaced closer than a 6-15, my guess would be a 6-30.
micromind likes this.
ppsh is online now   Reply With Quote
Old 11-23-2016, 01:41 AM   #11
That is very true with 6-30P and 6-50P both are simauair on that the ground pin useally away from cord.
The dryer and range cords the ground pins are useally away from cord.
I have see factory window shakers useing 6-30P the pin useally away from the cord which it is a norm for me to see it.
but not very often you see it in reversed fashion on that.
Here a 6-30 P look like
Old 11-23-2016, 07:12 AM   #12
MikeFL's Avatar
Rewards Points: 624
Just take both with you.
Hey everyone!
TIA
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 11-23-2016, 07:41 AM   #13
Im going to throw in as a 6-15P only due to the fact that the ground on moulded cord caps in 15 amps are on the cord entry side of an angle plug and as stated here, moulded 30 amp cord caps are on the far side of the cord entry.
Old 11-30-2016, 12:23 AM   #14
Fishbulb's Avatar
Rewards Points: 110
Which was it? A life without knowing the answer is hardly a life worth living!
micromind and PlugsAndLights like this.
Old 11-30-2016, 12:41 AM   #15
Islander's Avatar
Rewards Points: 630
lol! Didn't know you folks cared so much. It must have been a 30, because that's the type of receptacle I wired up, and I haven't heard any complaints.
I have yet to see that heater and its plug in person, and I may not.The drywalling and mudding will be done by the time I return to the site, I suspect.
leviton lighting and plug control HAL9000 Lighting Design 2 05-18-2016 10:25 PM
Plug circuit grounding Ziptie45 General Electrical Discussion 22 04-03-2016 11:03 AM
split plug upgrade to gfi? carlyn Residential Electrical Forum 41 03-30-2016 12:47 PM
6-20 to L6-20 plug change Gitarre10000 Residential Electrical Forum 1 03-11-2016 08:11 PM
Stackable washer dryer plug heights jordandunlop General Electrical Discussion 6 01-14-2016 09:09 AM
