1950 bx - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 2 Post By brian john
  • 1 Post By telsa
  • 4 Post By HackWork
Old 03-09-2017, 11:19 PM   #1
Rewards Points: 94
Default 1950 bx
Replacing devices in a 1950's home. I know the BX does not count as a ground and installing a GFI with a non grounded label is a good idea. Should I connect the ground terminal to the box anyway?
Have you had any luck knocking the metal boxes out of the way and replacing them with plastic old work boxes? I can fish new NM to some.
Thanks in advance.
smiley64 is offline   Reply With Quote
Old 03-09-2017, 11:26 PM   #2
Rewards Points: 1,972
Thanks in advance.
BX that we used was acceptable as a EGC (Equipment Grounding Conductor)
As for removing boxes in todays age of battery sawzalls a simple task, cut the brackets.
I seldom had problems removing boxes with a screw driver and hammer, starting in the middle of the box drive the screw down and pry the box off then the top and repeat until the box we lose.
MechanicalDVR and telsa like this.
Old 03-09-2017, 11:29 PM   #3
Rewards Points: 131
BX (type AC) cable properly installed in a metal box provides NEC-approved grounding. Just make sure the method used for grounding the installed device is correct.
khfiei is offline   Reply With Quote
The Following User Says Thank You to khfiei For This Useful Post:
Southeast Power (03-10-2017)
Old 03-09-2017, 11:32 PM   #4
Rewards Points: 26,502
Really old metallic boxes used in residential construction were often attached by way of nails hammered through the interior of the box into the stud.
Cutting such nails with a Sawzall is a snap... just work between the stud and the box.
Old 03-09-2017, 11:51 PM   #5
Dash Dingo's Avatar
Rewards Points: 318
Thanks in advance.
Does the BX have a bonding wire in it? If it don't I would not rely on it for an EGC. That was the worst wiring method ever.
Dash Dingo is offline   Reply With Quote
Old 03-10-2017, 12:15 AM   #6
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
You gonna have to upgrade all the breakers to afi/gfi too?
Old 03-10-2017, 09:46 AM   #7
Rewards Points: 1,189
I do this a lot.
The BX you are talking about most likely doesn't have the bonding wiring and can't be used as an EGC "officially". However, it usually does work perfectly fine. So YES, install the outlets as if it were grounded. It can't hurt. You are still going to GFCI protect them for code compliance.
Removing the old boxes could be easy, but a lot of times they are plastered in. And that old plaster with wood lath will have to be cut in order to install a new plastic box which is always larger than metal boxes. Sometimes cutting the plaster goes OK, other times it just breaks off and becomes a mess that needs patching.
I often try to bring a new romex to the existing metal box by removing a KO from the inside of the box, inserting a small magnet thru the KO into the wall, and then dropping a chain down from the attic to mate with the magnet. If you are coming up from the basement, do it the opposite way, drop the chain from the bottom KO in the box and grab it with a magnet thru the floor from the basement.
smiley64 (03-11-2017)
Old 03-10-2017, 11:47 AM   #8
Rewards Points: 3,006
I do this a lot.
I love using chain for fishing, that's an old school trick.
Old 03-10-2017, 02:35 PM   #9
Yeah, I have posted my handgun case of tricks before:
3 different size chains for different purposes.
The Following 2 Users Say Thank You to HackWork For This Useful Post:
robotsweat (03-10-2017), Semi-Ret Electrician (03-10-2017)
Old 03-10-2017, 02:52 PM   #10
Attachment 101849
I've used bead chain and sash chain, never tried jack chain.
Old 03-10-2017, 02:54 PM   #11
The bead chain is nice because it slinkies down thru obstructions really well, and will often find the hole and fall thru it.
Sash chain is nice because it's strong and durable.
The jackchain came with the Magnapull. I use it when I need something a little smaller than the sash chain but stronger than the bead chain.
Old 03-10-2017, 02:59 PM   #12
I have two sizes of bead chain and agree, it will find it's way around obstructions very easily. Smooth edges are a plus as well.
