20 amp Laundry Ckt - Page 4 - Electrician Talk - Professional Electrical Contractors Forum
Old 03-10-2013, 08:23 PM   #61
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I don't like arcfaults and fart fans to mix.
Until further NEC communism, most bathrooms out here abut the kitchen with the wetwall. I often tie the kitchen and bathroom lights on the same circuit to avoid the evil AFCI mythbreaker.
Old 03-10-2013, 08:25 PM   #62
Rewards Points: 1,464
Shock doc, you amaze me,but less than clevis.
Old 03-10-2013, 08:31 PM   #63
Old 03-10-2013, 08:36 PM   #64
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I bid cheap and work cheap for maximum profit. Honestly I constantly compete against another EC that runs a 12/3 to each bathroom with circuit to the outlet and the other to the lights. I beat him every time, besides I hate running into 40 circuit panels jammed full of 20 amp breakers feeding 3 amps worth of loads. Minimum code has awarded me many bids and has made me a lot of money.
Old 03-10-2013, 08:52 PM   #65
Rewards Points: 33
Plus all the service calls when there's two females in different bathrooms using flat irons and blow dryers on the same circuit and its tripping. And the old "none of my bathroom receptacles are working and I checked the breakers? Huh, what's a gfi?" I separate all bedroom bath gfi's, powder rooms is all I'll piggy back.
Stl elec is offline   Reply With Quote
Old 03-10-2013, 08:57 PM   #66
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I have yet to get one of those calls. The only calls I ever got were over AFCIs tripping when using the blowdryer in the bedroom. Simple removal solved that problem.
The Following User Says Thank You to Shockdoc For This Useful Post:
sbrn33 (03-10-2013)
Old 03-10-2013, 09:10 PM   #67
Tsmil's Avatar
Rewards Points: 508
Removal of what? The blow dryer or the afci?
Tsmil is offline   Reply With Quote
Old 03-10-2013, 09:14 PM   #68
Cletis's Avatar
Rewards Points: 2,050
As your online lawyer shockdoc I'd like to advise you to not comment on that
I'm shakin it boss..I'm shakin it
Old 03-10-2013, 09:26 PM   #69
backstay's Avatar
Rewards Points: 296
After the hack, maybe they are calling someone else.
Old 03-10-2013, 10:17 PM   #70
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I suppose two ladies blow drying at the same time can blow a breaker. I do often hit the master bedroom GFCI on it's own ckt on the higher end jobs.
Old 03-10-2013, 10:17 PM   #71
Rewards Points: 250
I never feed my bathrooms with 14. I feed a 12/2 to each, then hit the lights because the shower can needs to come from the GFCI anyway.
Shower cans need to be on GFCI? Code reference please!!
hotwire1955 is offline   Reply With Quote
Laundry circuit.. B4T General Electrical Discussion 38 02-07-2012 10:29 AM
Laundry Ckt, be aware. Mr. Sparkle NEC Code Forum 37 10-18-2011 08:58 AM
Who needs a laundry machine? Magnettica Off Topic (Non Trade) 12 07-19-2010 09:30 PM
Laundry receptacle s.kelly Residential Electrical Forum 18 03-28-2010 12:20 PM
Laundry Areas Shubey NEC Code Forum 19 11-06-2009 12:54 AM
