208 to 120 transformer? - Electrician Talk - Professional Electrical Contractors Forum
Old 10-11-2013, 11:10 AM   #1
LBC Jesse's Avatar
Rewards Points: 182
Default 208 to 120 transformer?
Customer is asking me to locate a 3 5kva 208 to 120v transformer.. Ive never heard of such an animal and I feel like there is something OBVIOUS he could do wiring wise? Obviously buck/boost wont buck down more than 48 volts.... He says he has a 3 20a 120v machine... Am I missing something, or is he been eating special brownies?
Cowards never start. The weak never finish. Winners never quit. Semper Fi.
LBC Jesse is offline   Reply With Quote
Old 10-11-2013, 11:13 AM   #2
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
I doubt he's been eating brownies, but I agree he probably doesn't know wtf he's talking about.
Old 10-11-2013, 11:14 AM   #3
dronai's Avatar
Rewards Points: 155
Old 10-11-2013, 11:19 AM   #4
LBC Jesse's Avatar
Rewards Points: 182
and he SWEARS its not 1 ... i think he needs to call an electrician, I just wanted to make sure I wasnt overlooking something before i cut him loose
Old 10-11-2013, 11:29 AM   #5
Slave to the grind
CopperSlave's Avatar
Rewards Points: 630
Sounds like he has a 208 wye system, is measuring 120V to neutral on each phase, and just thinks he needs to step it down. Like others have said, I think he is over his head.
I spend most of my money on racing and beer...the rest of it I waste.
CopperSlave is offline   Reply With Quote
The Following User Says Thank You to CopperSlave For This Useful Post:
LBC Jesse (10-11-2013)
Old 10-11-2013, 12:34 PM   #6
Rewards Points: 332
If he has 208V, it should be 208Y120 3phase 4wire, where the line to neutral voltage is ALREADY 120V. Thats why you are not going to easily find a 208 to 120V single phase transformer, there is very little need for one. But hooking it up this way is not a simple matter, especially for someone who, in your customer's case, is obviously clueless by virtue of his asking for the transformer!
No offense, but you are a supplier, not a contractor. He needs to hire a proper electrical contractor to ensure this is done right. There are circuit sizing and balancing issues to contend with just to scratch the surface. His asking a supplier to design the system for him is often a sign he is trying to circumvent what he perceives is an unnecessary added expense. The problem is, YOU cannot know enough about his installation from behind your desk to properly advise him, and for you own sake, you should not. A qualified licensed electrician needs to visit the site and assess ALL of the issues and ramifications. Your best course is to maybe recommend someone who is also one of your customers, a little mutual back scratching so to speak. Nothing works better in developing loyalty.
PS: just noticed you said he thinks it's a 3phase 120V machine? Lol, even more evidence you need to steer clear! No such thing. Period.
Old 10-11-2013, 12:34 PM   #7
This is what I believe.
HadItUpToHere is offline   Reply With Quote
Old 10-11-2013, 12:52 PM   #8
LBC Jesse's Avatar
Rewards Points: 182
No offense taken my friend... oft times we have someone call in that presumes because we sell electrical parts im also an electrician and ask weird crap like this fella did.. I'll try to help, but by NO means would I risk the liability of offering electrical advice... and yep, we use a few of our loyal customers as recommendations for face-palmers like this guy ..
Thanks for the info gents....
Old 02-07-2015, 06:24 PM   #9
Rewards Points: 6
Hello, I've got a question about an 'Industrial Control Transformer'.
There's an elevator which is fed from a 120/208Vac panel, with a 60 amp 3 phase disconnect in between. The 3 phases come in and feed the motor circuit. From the top of that circuit, two lines tap off and go to 2 - 1.6A fuses and then to the 0.15kVA - 208Vac to 120Vac 'Industrial Control Transformer'. (which is single phase)
Anyone have an idea why on earth the installers didn't just bring a 15amp line to neutral circuit from the panel to the 1.6amp fuses to feed the control circuit? Is it an elevator code situation where the entire system must be able to be de-energized with one disconnect? That's all I can really think of.
unlucky.break is offline   Reply With Quote
Old 02-07-2015, 06:32 PM   #10
Rewards Points: 1,702
I'll take the brownies .
Well you can have anything made .
Pete
pete87 is offline   Reply With Quote
Old 02-07-2015, 07:28 PM   #11
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
Welcome aboard..
You should start a new thread with your question.
Old 02-07-2015, 07:50 PM   #12
Rewards Points: 6
Thanks. Will do
Old 02-07-2015, 08:09 PM   #13
Rewards Points: 44
Originally Posted by pete87
I'll take the brownies . Well you can have anything made . Pete
Just go to next size up xtrans
FF301 is offline   Reply With Quote
Roof unit w/ transformer to create neutral - what feeds the transformer? owl General Electrical Discussion 52 12-25-2012 12:44 PM
480/240 transformer DM1981 General Electrical Discussion 10 12-03-2012 06:09 PM
What transformer will I need? solo9999 Residential Electrical Forum 1 04-19-2012 11:43 AM
transformer aposada007 General Electrical Discussion 3 02-21-2012 08:00 PM
225 KVA Transformer patrickw1961 General Electrical Discussion 9 10-09-2010 03:03 AM
