208/460 Motor Very HOT! - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
  • 1 Post By wildleg
  • 3 Post By tates1882
  • 2 Post By 460 Delta
  • 2 Post By micromind
Old 09-06-2019, 12:50 PM   #1
Default 208/460 Motor Very HOT!
Couldn't figure out a title, but help me out on this one.
Baldor 7.5hp (6 years old), Cooling finds, fan blade intact, FLA is 19.5/9.5 (208-230/460). The motor under no load was drawing 8.0, 8.1, 8.3 Amps and was very hot from cool to running for 15 minutes. Would eventually trip a breaker set at 18amps.
A new motor was installed same specs FLA 20/10 (208-230/460) and is cool as can be after 15 minutes.
The other motor had a slight hum any thoughts? Bearings over time expanding binding? I never saw it trip, but did feel the temperature you could not put your hand on it for more than 1-1.5 seconds.
jasil is offline   Reply With Quote
Old 09-06-2019, 12:58 PM   #2
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
cool .
glen1971 likes this.
Old 09-06-2019, 02:35 PM   #3
zap
tates1882's Avatar
Rewards Points: 1,084
Your hand isn't a accurate thermometer, Sounds like it was single phasing.
Old 09-06-2019, 02:49 PM   #4
Okay great answers! Strange place this Electrician Talk .com
Has anyone ever seen single phasing that is not picked by a clamp on Amp meter?
Old 09-06-2019, 02:51 PM   #5
Rewards Points: 2,656
presuming you are running the motor on 480v as you have a 18 amp breaker setting then no load should have been around 5-6 amps and you are showing 8amps. (if you tested the new motor with new load it should be around 50-60% of FLA)
Best guess is the motor has a bad bearing causing 3 amps of load (the phases are balanced so that counts out alot of different problems).
As the bearing gets hotter the tighter the tolerances the more load applied thus causing more heat rinse and repeat until the motor safetys kick in.
Are you sure its the breaker kicking at 18amps and not the Overload block.
I would suggest reading and understanding how to calculate and set your motor safety's including service factor. Caught early with the correct motor protection settings this could have been a quick bearing change rather than a motor replacement.
Old 09-06-2019, 03:22 PM   #6
zap
tates1882's Avatar
Its not exactly clear if you are in fact a professional electrician, so normally if you fail to fill out your profile than most members won't answer until you are vetted or a mod boots you.
micromind, glen1971 and Bird dog like this.
Old 09-07-2019, 01:30 AM   #7
Rewards Points: 7,877
When was the last time the oil was checked? Depending on bearing type, the right oil is important. Does it turn freely? No grinding?
Old 09-07-2019, 07:30 AM   #8
460 Delta's Avatar
Rewards Points: 1,730
When run on the low voltage connection, a motor can be partially single phased if one of the paralleled winding connections comes loose or opens up leaving only half the winding to take the load. They will be noisier than usual and run hotter than normal if this happens.
micromind and JRaef like this.
micromind for moderator- make ET more industrial
Old 09-07-2019, 05:45 PM   #9
Rewards Points: 178
Default John R retired electrician from Fed Gov
I am old school, to hot to touch, something wrong, bearing would be my guess
John R is offline   Reply With Quote
Old 09-07-2019, 08:17 PM   #10
Rewards Points: 3,356
I looked up the specs for a basic Baldor 7.5 HP 4 pole TEFC 213T steel frame motor, model EM3710T.
It states that the full-load temperature rise is 63C (145F). And that's over and above ambient. If ambient is 40C (104F), then its winding temperature would be somewhere around 103C (217F). The frame would be cooler but still pretty pickin hot! But also normal for this motor.
It has class F insulation, this means that the hottest part of the windings can safely operate at 155C (311F). Again, the frame will be cooler than this but it shows that it can indeed run way hotter than you'd think is normal.
A Leeson model 140450 (same type) is 43C (109F), same as a Marathon E2116.
A Lincoln model LM32805 has a 55C (131F).
tates1882 and gpop like this.
Old 09-09-2019, 01:26 AM   #11
Rewards Points: 1,554
shorted turns in the field.
Old 09-09-2019, 02:31 PM   #12
Rewards Points: 506
The trick to finding this is to measure all three phase currents and compare them. A small difference in current results in a very large difference in motor heat, because when a winding is not being fed power, it becomes a generator creating "negative sequence current" which then makes a rotating magnetic field then opposes the direction of the motor rotation, so the rest of the motor has to "fight" that one partially dead winding.
