277v LED can with 120v thermal? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-10-2015, 12:46 PM   #1
Rewards Points: 2,950
Yep. A contractor working in the same bldg as me wanted to show me something. An entire hallway of LED can lights cycling off and on every 30-60 seconds. They were installed this morning in a grid ceiling with no tiles installed yet. Upon further investigation, the fixtures are 120-277v rated, but the thermals were 120v rated. They are wired 277v. He has 2 skids of these fixtures sitting on the floor and 50-60 already installed. 277v LED can with 120v thermal?-image-1061483532.jpg 277v LED can with 120v thermal?-image-2783764045.jpg
Old 02-10-2015, 01:55 PM   #2
mr.photon's Avatar
Rewards Points: 78
Thats weird. I would probably take them all down and see what the supplier can do about a refund or something. I would not trust those. You might just be able to change the thermals but i wouldnt.
"Science isn't about why, Its about why not!" -Cave Johnson
mr.photon is offline   Reply With Quote
Old 02-10-2015, 02:18 PM   #3
Slave to the grind
CopperSlave's Avatar
Rewards Points: 630
Good 'ol Lithonia strikes again. I wish him luck in dealing with the factory. We have very few good things to say about that company, around this shop.
I spend most of my money on racing and beer...the rest of it I waste.
CopperSlave is offline   Reply With Quote
Old 02-10-2015, 04:43 PM   #4
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
As far as I can tell, they are not multi tap.
The 3510s are 120 volt
The 3515s are 120 volt
The 3506s are 277
The 3520s are 120 volt
Old 02-10-2015, 05:00 PM   #5
Here is a better pic of the label with the voltage on it.
According to this, they are multi volt? Something is not jiving.
Old 02-10-2015, 05:46 PM   #6
Very Long Vacation
Rewards Points: 5,262
Id be curious to know the reasoning behind that. You say these were cycling?
pete87 (02-10-2015)
Old 02-10-2015, 05:46 PM   #7
Watt Pusher
B-Nabs's Avatar
Rewards Points: 474
It looks to me like they use a universal driver (120-277), but that the fixture assembly as a whole is only intended to be connected to 120v, hence the 120v thermal. Probably they use the same driver on all models, but other parts are specific to the intended voltage. Just a guess.
The Following 3 Users Say Thank You to B-Nabs For This Useful Post:
CopperSlave (02-11-2015), mcclary's electrical (02-10-2015), mr.photon (02-10-2015)
Old 02-10-2015, 05:49 PM   #8
mr.photon's Avatar
Rewards Points: 78
Thats what im thinking. Its probably just easier for the company to give it a range because of all the variables in the cheap product.
Old 02-10-2015, 05:54 PM   #9
So, it's possible this contractor may just have a lazy contract manager who just picked the first part number for this fixture without researching compatability.
Old 02-10-2015, 05:59 PM   #10
Now that I'm home and can do some research online, It looks like they were just not on the ball when placing their order. Lithhonia's website clearly shows 3 voltage options, 120, 277 & 347. I wonder who will end up paying for that one. I can only assume the contractor will have to make it right on their dime. I suppose in the same situation, I would have to eat the cost to make things right.
Old 02-10-2015, 06:19 PM   #11
Yeah Toast!!
Roger123's Avatar
Rewards Points: 1,366
So, the box shows multi-tap as input but the fixture is not?
Old 02-10-2015, 06:39 PM   #12
Rewards Points: 1,702
First Thought .
Helper with other contractor playing with breaker .
Pete
pete87 is offline   Reply With Quote
Old 02-10-2015, 06:48 PM   #13
Rewards Points: 1,512
send them all back to the manufacturer,
if they are marked as suitable for 277v ?
Then they should work on 277v
If not the manufacturer can replace them
Have you tried wiring two fittings in series
that would give about 138v a piece.
But my first choice is send them back !
Old 02-10-2015, 10:31 PM   #14
evil bastard
Rewards Points: 746
Its the contractor's fault. The list number shows its a120 volt fixture. The ballast itself is rated for 277, but the fixture is not. that is just because they used the same ballast in every fixture. It doesn't change the fact that that particular fixture is not intended for use with 277
btharmy (02-11-2015)
Old 02-11-2015, 12:17 AM   #15
Yep. I'm curious to find out their solution. I will be there again tomorrow to see what happened. I would assume the journeyman on site went home and did a little research and found out his shop screwed up.
Old 02-11-2015, 12:48 AM   #16
evil bastard
Rewards Points: 746
Your original picture:
35/20 120........... says it all.
Old 02-11-2015, 10:35 PM   #17
What about using a transformer ?
How many lights ?
How hard is it to send them back ?
Old 02-12-2015, 12:13 AM   #18
Double post.
Old 02-12-2015, 12:15 AM   #19
Rewards Points: 5,198
Yep. A contractor working in the same bldg as me wanted to show me something. An entire hallway of LED can lights cycling off and on every 30-60 seconds. They were installed this morning in a grid ceiling with no tiles installed yet. Upon further investigation, the fixtures are 120-277v rated, but the thermals were 120v rated. They are wired 277v. He has 2 skids of these fixtures sitting on the floor and 50-60 already installed. Attachment 47449 Attachment 47465
Just for informational purposes why would the "thermal" trip at a higher voltage?
Old 02-12-2015, 12:17 AM   #20
I'm not sure unless the higher voltage combined with the resistance in the smaller thermal actually caused it to reach its trip temperature pre-maturely.
277v to 120v XFMR carryyourbooks General Electrical Discussion 3 10-26-2012 12:03 AM
120v 277v ?! Mcsparkin Services and Service Equipment 11 09-15-2012 12:48 AM
t 5 120v -277v ballast running on 347v sparky105 Lighting Design 8 11-27-2010 05:38 PM
120-277v led mogul base? nFLzap Lighting Design 9 04-06-2010 07:43 AM
