2x4 lay in fixture measurement - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By splatz
Old 04-12-2016, 10:12 AM   #1
Rewards Points: 79
Default 2x4 lay in fixture measurement
What would be the minimum measurement from the grid to the structural ceiling to get a fixture in the grid.
6 shooter is offline   Reply With Quote
Old 04-12-2016, 10:38 AM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Depends on the fixture. Some are thicker than others.
BDB (04-12-2016)
Old 04-12-2016, 11:05 AM   #3
Rewards Points: 79
They would be the Lithonia contractor select. The GT3mv. Looks like a depth of 3-1/8 inches
Old 04-12-2016, 11:08 AM   #4
Rewards Points: 17,703
With LED fixtures that number ought to be drifting down to next to nothing by now................
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 04-12-2016, 11:09 AM   #5
Rewards Points: 306
I doubt there's a table anywhere with that info.....
Sparkchaser1 is offline   Reply With Quote
Old 04-12-2016, 11:15 AM   #6
dawgs's Avatar
Rewards Points: 1,008
I usually figure 4" minimum.
dawgs is offline   Reply With Quote
Old 04-12-2016, 12:53 PM   #7
Rewards Points: 79
Did they go in decent with out banging every thing up? I think the 4" is the minimum for the tiles that manufactures recommend. The light fixtures are kind of tough to bend.
Old 04-12-2016, 02:12 PM   #8
dawgs's Avatar
I meant that I usually figure the fixture as 4" thick. I always want as much headroom as possible in the ceiling. You want at least double thickness of fixture to have enough room to get it set without smashing the t-bar and scratching everything up.
Old 04-12-2016, 03:27 PM   #9
Light Bender
eddy current's Avatar
Rewards Points: 7,736
Many lay ins are wired from the top as well.
I'd say you need 12 inches of clearance to get a 4" lay-in without taking the grid apart.
Old 04-12-2016, 07:39 PM   #10
Rewards Points: 814
Before long ceiling tiles are going to come standard with LEDs that make them glow and the grid itself will light them with 12VDC.
Majewski likes this.
Old 04-13-2016, 12:14 AM   #11
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
There's an idea!
Old 04-13-2016, 01:38 AM   #12
Rewards Points: 21,856
Most case useally 4 inches but i rather leave more room to install the lay in luminaires without getting the grid damaged...
But the actual height that will varies depending on the luminaires it being used ..
Old 04-13-2016, 06:49 AM   #13
Going_Commando's Avatar
Rewards Points: 1,540
I've gotten them into 4 1/2-5" or so, but you have to pop out a cross bar so you have more room to slide the beasty up, and have to wire it on the ground with whips and right angle mc connectors. Pain in the balls, but they wanted all the head room they could get.
The Following User Says Thank You to Going_Commando For This Useful Post:
wendon (04-13-2016)
Old 04-13-2016, 08:06 AM   #14
wendon's Avatar
Rewards Points: 54
Just take a couple tie wires loose and slip it in. Just be sure put them back where you found them!
Old 04-13-2016, 12:04 PM   #15
You are probably right about that. Grid bus low volt systems. The death of commercial electricians. Watch and observe.
JOBS GROWTH SOARS
RECORD WORKING
Drudge Report
Old 04-13-2016, 12:13 PM   #16
sbrn33's Avatar
Rewards Points: 3,490
If I never had to put in another GT8 I wouldn't blink an eye.
Old 04-13-2016, 02:17 PM   #17
Vintage Sounds's Avatar
Rewards Points: 4,004
http://tbarledsmartlight.com/
http://www.armstrong.com/commceiling.../_/N-mZ1z141h7
Old 04-13-2016, 02:27 PM   #18
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,322
Check this: http://www.armstrong.com/pdbupimages/201068.pdf
Covered by Article 393- New to the 2014 nec
Signal1 is online now   Reply With Quote
Old 04-13-2016, 04:15 PM   #19
Rewards Points: 814
(Every one of those f'ers owes me royalty money.)
OK those are going to be popular for a short while, then ceiling grids will all be smartglass displays like you see in this video
there will be cameras in them, they will watch you, and sensors to identify you by emanations from your cell phone, infrared to determine your disposition via temperature like the mood ring, and will tell your true character and predict your future by reading the bumps on your head. They'll confer with a big data mothership in the cloud and display images you find appealing, surrounded by ads you find irresistible.
We are going to make great pets!
millelec (04-14-2016)
Looking for a fixture type wy2ak Lighting Design 9 04-14-2016 12:39 AM
SO cord for fixture whips? Derek1 NEC Code Forum 14 03-06-2016 05:50 PM
Preferred fixture type over sink with valance. sayn3ver Lighting Design 3 02-14-2016 10:06 AM
Supporting a 175lbs and 350lbs fixture oldschoolvdub General Electrical Discussion 6 01-27-2016 06:04 AM
Fixture Wire power General Electrical Discussion 5 01-12-2016 02:13 PM
