3 phase to a single phase - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
Old 12-09-2016, 11:32 PM   #1
Rewards Points: 12
Default 3 phase to a single phase
Hi electricians
I have a genset 12.000watt 3phase, and i have one compressor 2.200watt 3phase, 2 houses 4000watt single phase each.
So im gonna provide power to those 3 items, problem is with my compressor, do i have to buy an inverter? (im not sure what its called) but its to invert 3phase to single phase. And after its inverted to a single phase, is it still 2.200watt?
Thank you
JBoen is offline   Reply With Quote
Old 12-09-2016, 11:37 PM   #2
corn-fused
papaotis's Avatar
Rewards Points: 620
what is 2.200watt? you mean 2 200watt circuits?sorry, just realized the puncuation is my problem.
Old 12-09-2016, 11:43 PM   #3
Rewards Points: 12
I mean a 2200watt power consumption for a compressor.
Im doing a job to help him configure hoe to utilize with his current genset.
Old 12-09-2016, 11:43 PM   #4
corn-fused
papaotis's Avatar
Rewards Points: 620
you should really get an electrician for this, but no, you dont need in inverter for the compressor maybe for the other things, but dont know your wiring methods.
The_Modifier likes this.
Old 12-09-2016, 11:44 PM   #5
backstay's Avatar
Rewards Points: 296
Originally Posted by JBoen View Post
Hi electricians
Thank you
We are having trouble with your English. Is 12.000watt = 12kW(kilowatt)? We would also need to know if your gen set has a neutral and voltages. If you have a neutral, then you don't need to convert anything. We run single phase loads off two phases all the time.
micromind and papaotis like this.
Old 12-09-2016, 11:44 PM   #6
Rewards Points: 10,226
Oh dear, where do I start?
I think you should hire an electrician.
He will need nameplates on your genset and compressors.
Old 12-09-2016, 11:46 PM   #7
Rewards Points: 12
It wouldnt be a problem if he bought a bigger capacity genset, ild say 20kwatt is the minimum.
Sent from my MI 5
Old 12-09-2016, 11:50 PM   #8
Rewards Points: 12
I see i thought it will be just an inverter
Old 12-09-2016, 11:54 PM   #9
If anything, you will need a transformer. But you haven't given enough 411 for us to know. Inverters are for converting DC to AC, generaly speaking.
Old 12-10-2016, 12:13 AM   #10
Rewards Points: 1,562
QUOTE - And after its inverted to a single phase, - QUOTE.
It is not necessary to convert 3 phase to single phase.
Single phase can be obtained by running from any of the three phases to neutral.
So the question is does your genny have a neutral ?
some do some don't.
If it does not ?
Then you can use a transformer.
backstay likes this.
Old 12-10-2016, 12:32 AM   #11
Rewards Points: 12
some do some don't.
If it does not ?
The genset capacity is too small, 12000watt / 3 = 4000watt each phase. His 2 stores are 5000watts each, everytime turning on the compressor, genset breaker will be down. What kind of transformer do i need? I never handle a transformer before but would like to learn
Old 12-10-2016, 12:44 AM   #12
backstay's Avatar
Rewards Points: 296
Not correct.
Old 12-10-2016, 01:15 AM   #13
Rewards Points: 12
Not correct.
Which part is not correct?
Old 12-10-2016, 02:37 AM   #14
Rewards Points: 21,898
Hi electricians
Thank you
It depending on the generator itself .,,
Did the generator do come with netural in there ??
I know you mention compressor which it run on three phase but what voltage ? 240 or 415 volts or other voltage ?
What kind of load it is useing in the house ?
Keep in your mind the biggest issue with any generator is motor start up that what can cause pretty serious load voltage drop when the motor start up. it dont matter if single or three phase.
The starting watts or Kva rating that do count.
I really recomoned that you get your electrician which they are famiuair to your area.
They can help you to the proper connection on the generator.
Personally I think the generator size is on small side if you used the load as you posted.
telsa likes this.
Old 12-10-2016, 04:05 AM   #15
Rewards Points: 12
Yes, it has a R S T N terminal. The compressor requires 380 volt.
Its a car tire workshop. I dont know whats in there. But this is what i have tried
From genset
RSTN to compressor
RN to workshop 1
SN to workshop 2
Breaker down
If genset only powers compressor, it will be fine. I think bigger kva genset will help, but i need to know if i can transform the 3 phase compressor to a single phase, so that the genset will be enough for these loads.
Sent from my MI 5
Old 12-10-2016, 04:06 AM   #16
Rewards Points: 12
Oh btw the compressor requires 18A to run
Old 12-10-2016, 06:49 AM   #17
Southeast Power's Avatar
Rewards Points: 9,264
We have always found that changing the motor, especially a small under 5hp one, is way more economical and efficient than bringing in a phase converter.
kW is kW.
If you are thinking of changing the alternator to a single phase configuration, you are going to lose about 40% if its capacity if I remember correctly.
Old 12-10-2016, 11:51 AM   #18
Rewards Points: 12
kW is kW.
Do you mean losing 40% of the power rating?
Old 12-10-2016, 12:15 PM   #19
Rewards Points: 3,432
A transformer will not solve the problem, the generator is too small. It cannot handle all 3 loads at the same time.
If the compressor is 18 amps at 380 volts 3 phase then it will take almost all of the capacity of the generator. There is not enough left for the building loads.
JBoen likes this.
Old 12-10-2016, 01:39 PM   #20
Use this:
http://www.dieselserviceandsupply.co...alculator.aspx
Majewski and JBoen like this.
3 Phase / 1 Phase question J91 Commercial Electrical Forum 16 10-23-2016 04:25 AM
2 Phase Elevator Edfish General Electrical Discussion 5 06-30-2016 09:07 PM
3 phase to single phase te12co2w PLCs, VFDs, Motors and Controls 62 03-14-2016 10:47 AM
220 single phase to 3 phase? TechieBecky Canadian Electrical Forum 16 02-19-2016 03:46 AM
Can be both a three or single phase motor just the cowboy General Electrical Discussion 2 01-21-2016 10:36 AM
