3 point saddle - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
  • 1 Post By Matt216
  • 1 Post By Switched
  • 1 Post By Signal1
  • 4 Post By manchestersparky
  • 2 Post By TGGT
  • 1 Post By 99cents
  • 1 Post By JohnJ65
Old 12-20-2017, 11:18 PM   #1
Default 3 point saddle
Whats up guys I've been doing electrical work for going on 2 years now. Ive got offsets on hand benders down and I'm getting there on the saddles. Ok so I want to know how to bend a 3 point saddle with a 1" rise after a box offset, and 15 1/2" of space to the obstruction the correct way. What degree should I use for the saddle? Thanks
FlyGuy5 likes this.
Matt216 is offline   Reply With Quote
Old 12-20-2017, 11:21 PM   #2
Switched's Avatar
Rewards Points: 10,418
Take a look at this: http://www.porcupinepress.com/_bendi...ndDrawings.htm
This should help you with calculations and such...
FlyGuy5 likes this.
Old 12-21-2017, 12:16 PM   #3
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,684
Get this
https://www.amazon.com/Benfield-Cond.../dp/0872885100
You'll thank yourself later.
FlyGuy5 likes this.
Old 12-21-2017, 12:52 PM   #4
Rewards Points: 110
For small saddles I bend the center bend at 30 degrees and the outside bends at 15 degrees. The multiplier is 3.9 for 15 degree bends. I add a little to distance between bends so the saddle doesn't rest right on whatever is being saddled. I also always bend 3 bend saddles from the center of the bend using marks that I put on the bender. I put center marks on the bender for 15, 22.5 and 30 degree bends (the notch is center of a 45 degree bend). That way you don't have to reverse the direction of the pipe in the bender. That's how I do it anyway. YMMV.
Mulder is offline   Reply With Quote
Old 12-21-2017, 01:12 PM   #5
Professional Nit Picker
manchestersparky's Avatar
Rewards Points: 2,276
I use to tell my guys to get Benfields book on conduit bending. I had one on hand for them to look at on site.
Heres a link where you can actually read the manual ( and I think download it as a pdf)
https://www.scribd.com/document/2648...Bending-Manual
I think every conduit person should know how to bend a 3 point saddle. I also think every conduit person should avoid the use of them as much as possible as they do make wiring pulling harder.
Navyguy, glen1971, TGGT and 1 others like this.
Anything Worth Doing ....
Is Worth Doing Right
The Following User Says Thank You to manchestersparky For This Useful Post:
TGGT (12-21-2017)
Old 12-21-2017, 01:16 PM   #6
Rewards Points: 2,149
Agreed. Total degrees are the same but a 4 point is better to pull.
Just depends on the space limitations to fit the bend.
Old 12-21-2017, 01:40 PM   #7
Rewards Points: 1,900
Put 7/8" strut behind your box and forget about the saddle.
B-Nabs and sdelgado5650 like this.
Old 12-22-2017, 09:51 PM   #8
Rewards Points: 26
I like the Electrical wiring lite app. Punch in what you want and away you go. They have a paid version also with more features.
Sent from my XT1080 using Tapatalk
WIsparky71 is offline   Reply With Quote
Old 12-23-2017, 08:12 AM   #9
MTW
Rewards Points: 12,587
The Benfield method turned me from an amateur into a pipe bending master.
Old 12-23-2017, 08:51 AM   #10
Rewards Points: 90
Check out the app called ibend pipe, comes in pretty handy.
29573 is offline   Reply With Quote
Old 12-23-2017, 08:58 AM   #11
Rewards Points: 3,057
Start your own business. That way, the boss isn't looking in the dumpster to see how much pipe you wasted.
TOOL_5150 likes this.
Old 12-23-2017, 10:44 AM   #12
Better yet learn to become a conduit master on someone else's dime. That way when you go on your own your not wasting time on bending incorrectly and money on wasted materials ..............
Old 12-27-2017, 08:45 AM   #13
A good bending app and a digital level can go a long way.
Old 12-27-2017, 11:03 AM   #14
Rewards Points: 531
I found this simple guide that came with my Ideal bender to have the perfect solution to three point saddles. It even gives a nice chart that shows how much to advance the middle mark to account for shrinkage.
https://idealind.com/content/pdfs/gu...nder_guide.pdf
FlyGuy5 likes this.
JohnJ65 is offline   Reply With Quote
Old 12-27-2017, 11:54 AM   #15
Rewards Points: 21,945
Everybody go look and see what telsa did to the op's home page.....
I stand with Hax and Tucker Carlson
datalogging with AD Point of View just the cowboy PLCs, VFDs, Motors and Controls 0 05-04-2017 02:17 PM
point of attachment RA0305 Services and Service Equipment 8 04-05-2017 04:41 AM
Point plumb lasers bobs NDC Tools, Equipment and New Products 8 09-05-2016 08:00 PM
Single Point Ground Question DannyB General Electrical Discussion 28 01-13-2016 11:33 PM
