$35 PVC bender for 2 1/2" - Electrician Talk - Professional Electrical Contractors Forum
Old 05-24-2014, 11:55 AM   #1
Dash Dingo's Avatar
Rewards Points: 318
Default $35 PVC bender for 2 1/2"
 PVC bender for 2 1/2"-image-3919591282.jpg
 PVC bender for 2 1/2"-image-1253631358.jpg
Dash Dingo is offline   Reply With Quote
Old 05-24-2014, 01:47 PM   #2
Rewards Points: 17,747
Got a story to go along with that Dash?
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 05-24-2014, 02:12 PM   #3
220/221's Avatar
Rewards Points: 4,088
Heating blanket/pad for a bed?
For that little of a bend, I would have just forced it into place.
The Following 5 Users Say Thank You to 220/221 For This Useful Post:
Dash Dingo (05-24-2014), dronai (05-24-2014), sparky970 (05-24-2014), svh19044 (05-24-2014), walkerj (05-26-2014)
Old 05-24-2014, 03:58 PM   #4
Rewards Points: 1,250
Yes that would be nice. Is that a plain old heat gun? Or a hair dryer? And what about the blanket, is it an electric blanket or just an old drop cloth??
By the way I learned a long time ago never to leave the glue open next to the trench.
The Following 2 Users Say Thank You to Joefixit2 For This Useful Post:
glen1971 (05-25-2014), Skipbayless (05-24-2014)
Old 05-24-2014, 04:56 PM   #5
Rewards Points: 88
Guess somebody didn't want to set fire to the pipe today
Old 05-24-2014, 05:09 PM   #6
Dash Dingo's Avatar
Rewards Points: 318
Originally Posted by Joefixit2
Yes that would be nice. Is that a plain old heat gun? Or a hair dryer? And what about the blanket, is it an electric blanket or just an old drop cloth?? By the way I learned a long time ago never to leave the glue open next to the trench.
Yeah all it is, is a heat gun and a drop cloth. We really didn't need it, but another worker didn't believe I could bend 2 1/2" with out a hot box or PVC blanket. I've used this method in a pinch before where I have been off a few inches on stub ups through concrete to been an offset.
The Following User Says Thank You to Dash Dingo For This Useful Post:
220/221 (05-24-2014)
Old 05-24-2014, 07:05 PM   #7
Rewards Points: 88
I didn't notice the heat gun sticking out of the end lol. What is the dropcloth for then?
Not long into my first year apprenticeship they had me in a hole under what was going to be an electrical room, using a heat gun to reshape dozens of conduit up to 3" that got shifted when the backfill guys collapsed the supports. Never heard of using a heat gun from the inside out though, that is clever.
Old 05-24-2014, 08:23 PM   #8
Skipbayless's Avatar
Rewards Points: 91
Sounds like someone is getting a taste of first year apprenticeship. Being sent in holes to bend pvc 3" with a heat gun.
I haven't seen the heat gun inside of a pipe to hear it either. I understand how it would work. I just don't understand how it doesn't melt the pipe by the tip of the gun.
Sent from my SCH-I535 using electriciantalk.com mobile app
Skipbayless is offline   Reply With Quote
Old 05-24-2014, 08:45 PM   #9
ponyboy's Avatar
Rewards Points: 709
Git r done.
That bend looks unnecessary to me though. When I do undergrounds I only heat up pieces when absolutely necessary. It's PVC, you can make that crap do whatever you want.
Old 05-24-2014, 08:52 PM   #10
CADPoint's Avatar
Rewards Points: 1,838
Use a big pipe, insert smaller pipe, close one end heat with heat gun,
works just have to watch burning outer portion of smaller pipe...Insert
a dead end if heating coupling end!
One can open end if desired it'll just be a 1/3 time longer!
If you are even thirsty, you are two quarts low.
The Following User Says Thank You to CADPoint For This Useful Post:
Old 05-24-2014, 09:56 PM   #11
Dash Dingo's Avatar
Rewards Points: 318
Originally Posted by Jarp Habib
I didn't notice the heat gun sticking out of the end lol. What is the dropcloth for then? Not long into my first year apprenticeship they had me in a hole under what was going to be an electrical room, using a heat gun to reshape dozens of conduit up to 3" that got shifted when the backfill guys collapsed the supports. Never heard of using a heat gun from the inside out though, that is clever.
The drop cloth just insulates the pipe so it heats up faster.
Old 05-24-2014, 11:05 PM   #12
ET rocks
3xdad's Avatar
Rewards Points: 2,174
Moist dirt? No boulders?
Lucky
3xdad is offline   Reply With Quote
Old 05-24-2014, 11:52 PM   #13
dcb_minded's Avatar
I've used the tailpipe of the truck several times.... takes about 10 minutes
Sent from my SGH-T599 using Tapatalk
dcb_minded is offline   Reply With Quote
Old 05-25-2014, 12:12 AM   #14
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
With your bare hands...
Old 05-25-2014, 01:40 AM   #15
Data Tech/Apprentice.
Rewards Points: 22
We get charged out at $69 an hour... its cheaper to grab some .45 and 90. sweeps and return them if we dont use them than it is to mess around bending PVC for underground but I am impressed that worked.
Old 05-25-2014, 03:50 PM   #16
Bkessler's Avatar
Rewards Points: 2,002
I thought you heated up the pipe and water for tea at the same time.
When's lunch?
When ls lunch?
1" Bender yes or no Edrick Tools, Equipment and New Products 30 08-23-2013 06:52 PM
Wanted: 1" powr jack bender dirtyfrank Electrician Swap 0 05-28-2013 07:01 PM
Wanted: 3/4" Rigid ONLY 6" radius bender Karahco Electrician Swap 10 03-29-2010 10:53 PM
Bending 1/2" EMT in 3/4" bender Conduit Phil General Electrical Discussion 35 02-25-2010 09:15 PM
"New" Klein bender w/ Orange Handle Ross Tools, Equipment and New Products 17 06-08-2009 07:36 PM
