4-way and 3-way Switch Wiring - Electrician Talk - Professional Electrical Contractors Forum
Old 02-25-2015, 06:48 PM   #1
Rewards Points: 100
Default 4-way and 3-way Switch Wiring
Hey guys I'm back again with a question. I've been trying to find some general principles to go by when wiring 3-way/4-way lighting circuits, because I know just memorizing colors is not a solid way of understanding how to wire a 3-way/4-way switch lighting circuit.
So far this is what I've come up with by looking at diagrams where the source comes in at either a switch box or at the light:
1. One of the two 3-way switches will have their common connected to the power source.
2. The other 3-way switch will have its common connected directly to the light/load.
My question is, from what I just wrote is there a situation where those two principles would not hold true? Like would adding a certain amount of 4-ways or having the source come in at a specific device location make it so 1&2 are not true?
Once again thanks for reading this and I appreciate any info/advice.
badreligion9265 is offline   Reply With Quote
Old 02-25-2015, 06:54 PM   #2
Rewards Points: 319
just remember one switch has a power leg, and the another switch has a a switch leg actually controlling the lights, and don't get your travelers mixed up.
IBEW Local 2085
fisstech is offline   Reply With Quote
Old 02-25-2015, 06:57 PM   #3
I own stock in FotoMat!
Rewards Points: 6,520
The best way to understand how to wire 3-way and 4-way switches is to get one of each and take a continuity tester to them.
The_Modifier (02-27-2015)
Old 02-25-2015, 07:04 PM   #4
Rest In Peace
aftershockews's Avatar
Rewards Points: 7,003
My father once told me that there are 11 ways to wire a 3 way switch configuration. I know of 7 that I have done. I alway look at the 4 way as being in series of the wiring. Keeps from making it complicated.
Your 3 ways are the key. Using 3 wire, your hot and switch leg can be in any of the switch boxes (pretty much) to make any configuration work.
I trouble shoot some where the 3 wire for the 3 ways goes through the light box for which they are controlling.
Boss calls it a 3 up-3 down method.
Official troll magnet.
aftershockews is offline   Reply With Quote
The Following User Says Thank You to aftershockews For This Useful Post:
SdCountySparky (02-26-2015)
Old 02-25-2015, 07:04 PM   #5
The_kid's Avatar
Rewards Points: 12
Except when you have the switch leg and feed both in one box and you have to send over the feed (or switch leg) to the other box.
In that case you would tie the feed on to the common terminal, the red and black of the 3 wire between the boxes as the travelers and the white of the 3 wire spliced to the switch leg.
In the other box, the travelers are still travelers, and the white would be your common.
The_kid is offline   Reply With Quote
Old 02-25-2015, 07:15 PM   #6
Rest In Peace
When I first started this trade, I found and animated GIF that helped me to learn 3 ways.
I hope this may help.
The Following 3 Users Say Thank You to aftershockews For This Useful Post:
51360 (02-25-2015), just the cowboy (02-26-2015), The_Modifier (02-27-2015)
Old 02-25-2015, 08:16 PM   #7
Rewards Points: 56
Here is a similar animation for a circuit with a 4-way switch too: http://users.wfu.edu/matthews/misc/s...Animation.html
jhartz is offline   Reply With Quote
The Following User Says Thank You to jhartz For This Useful Post:
hardworkingstiff (02-26-2015)
Old 02-25-2015, 08:29 PM   #8
wendon's Avatar
Rewards Points: 54
There are a lot of different ways to wire them but my preferred method is:
Power in at 3way #1
14-3 daisy chained between all the 4-way locations terminating at
3-way #2.
Power out to lights from 3-way #2
Easy to trim out and you don't end up with a pile of conductors in your ceiling box. JMHO
The Following 2 Users Say Thank You to wendon For This Useful Post:
hardworkingstiff (02-26-2015), shocksystems (02-25-2015)
Old 02-25-2015, 08:37 PM   #9
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
I hate the setup you've mentioned. I like to feed and leg out of the same box. Dead end three way on the other end.
The Following 2 Users Say Thank You to mcclary's electrical For This Useful Post:
ponyboy (02-25-2015), The_kid (02-25-2015)
Old 02-25-2015, 09:02 PM   #10
Rewards Points: 3,090
Originally Posted by mcclary's electrical View Post
I hate the setup you've mentioned. I like to feed and leg out of the same box. Dead end the way on the other end.
I thought in the NEC, you had to have a neutral at every outlet, or something like that?
I'm asking because I am not knowing the NEC. Just curious. I do the dead end thing often, but with the new occupancy sensors now available, I think twice.
Borgi
Old 02-25-2015, 09:04 PM   #11
So you like paying for 14/4?
Old 02-25-2015, 09:05 PM   #12
evil bastard
Rewards Points: 746
Borgi
That's coming next code cycle for me, and often if it's a two three or for gang, it won't matter because chances are there will be a neutal they're anyway.
51360 (02-25-2015)
Old 02-25-2015, 09:06 PM   #13
wendon's Avatar
Rewards Points: 54
So you end up with (2) 14-2 and (1) 14-3 in a single gang box and that's assuming it's a circuit dedicated just for that lighting string. Like I said, it's just my preference. I like to try to keep the boxes as empty as possible.
Old 02-25-2015, 09:12 PM   #14
Licensed Electrician
knothole's Avatar
Rewards Points: 14
I never had any idea that there were 11 different ways to wire a 3 way circuit. Learn something new EVERY day....
Danny
knothole is offline   Reply With Quote
Old 02-25-2015, 09:25 PM   #15
Professional Nit Picker
manchestersparky's Avatar
Rewards Points: 2,214
There is only 2 ways to wire them .....................
The right way and the wrong way
Anything Worth Doing ....
Is Worth Doing Right
The Following 9 Users Say Thank You to manchestersparky For This Useful Post:
51360 (02-25-2015), Chris1971 (02-25-2015), crazyboy (03-02-2015), CTshockhazard (02-26-2015), DesignerMan (02-27-2015), gardiner (02-26-2015), glen1971 (02-26-2015), The_Modifier (02-27-2015), wendon (02-25-2015)
Old 02-25-2015, 11:11 PM   #16
Rewards Points: 100
Thanks for the info guys. Can anyone do me a favor and link or upload an image of the circuit mentioned which involves a 14-4 wire? I have never come across this before.
Old 02-25-2015, 11:13 PM   #17
corn-fused
papaotis's Avatar
Rewards Points: 620
i think ive seen 7 or 8, most of them worked!
Old 02-25-2015, 11:13 PM   #18
cabletie's Avatar
Rewards Points: 1,274
An old foremen of mine always said " there are two ways of doing it, my way and the Navy way. And my way is the Navy way"!
The Following User Says Thank You to cabletie For This Useful Post:
51360 (02-25-2015)
Old 02-25-2015, 11:46 PM   #19
evil bastard
Rewards Points: 746
Why would I do that?
Old 02-25-2015, 11:47 PM   #20
14/4 is used for a dead-end 3-way because the NEC requires a neutral there.
Wiring a Level Switch wwaller314 PLCs, VFDs, Motors and Controls 8 02-23-2015 07:18 PM
Need help wiring switch DIYguy General Electrical Discussion 33 02-11-2014 07:20 AM
When did we switch to 3 conductor wiring? cmhcissell NEC Code Forum 4 05-09-2013 08:00 PM
wiring a 3 way switch bt3476 General Electrical Discussion 39 12-08-2009 07:46 PM
