4 way switch - Electrician Talk - Professional Electrical Contractors Forum
Like Tree42Likes
Old 04-29-2016, 09:58 PM   #1
corn-fused
papaotis's Avatar
Rewards Points: 620
Default 4 way switch
kinda burnt out this week. i have a four way circuit that has probly never worked. after checking all the switches making drawings till i cant see straight, all i know for sure is the problem is at one end. what configuration would take the 4way out of the loop? there should be power to one terminal or the other at all times right?
Old 04-29-2016, 10:05 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Two terminals should always have power. Which two depends on how the upstream 3-way is set and how the 4-way is wired internally.
telsa likes this.
Old 04-29-2016, 10:06 PM   #3
corn-fused
papaotis's Avatar
Rewards Points: 620
right, and the four way should always have power. right?
Old 04-29-2016, 10:07 PM   #4
Band Member
emtnut's Avatar
Rewards Points: 2,556
Should have power at each switch, and power to one of the travellers too.
If it never worked ... I'd check how the traveller's are connected
Old 04-29-2016, 10:09 PM   #5
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,820
Slap me if it's dumb but could any type of cali switch wiring be involved to add to the confusion/exhaustion?
Old 04-29-2016, 10:12 PM   #6
Assuming the upstream 3-way is correctly wired, yes.... two terminals should always be energized.
Old 04-29-2016, 10:13 PM   #7
Ditch Digging Dummy
3D Electric's Avatar
Rewards Points: 52
Just tie the two pairs of travelers together. Complete the circuit and deal with a standard 3 way if it's being a pain.
3D Electric is offline   Reply With Quote
Old 04-29-2016, 10:19 PM   #8
corn-fused
papaotis's Avatar
Rewards Points: 620
have to go back for some other things so will rehash it on a fresh start! has to be one end, not the middle.................unless the wires go to light box first Hmmmmmmmmm
Old 04-29-2016, 10:21 PM   #9
Ditch Digging Dummy
Rewards Points: 52
Could be back fed. Sending power down on the white and some one confused it with a neutral. Pull the fixture down and see if the travelers go through the light box.
hardworkingstiff likes this.
The Following 2 Users Say Thank You to 3D Electric For This Useful Post:
splatz (04-30-2016), Spunk#7 (04-30-2016)
Old 04-29-2016, 10:25 PM   #10
corn-fused
papaotis's Avatar
Rewards Points: 620
yeah, thats what the hmmmm was about. havent got that far yet!
Old 04-29-2016, 10:39 PM   #11
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
Funny this thread showed now as i just came back from fixing a neighbours
4 way. It had me confused for a while cause I'm used to seeing 4 switch 4
ways wired power-3way-4way-4way-3way-light. This was wired with both
the power and light out of the first 3way box. Combine that with wires removed
from various places by the homeowner trying to figure it out himself, and it took
a while to sort it out.
Since that likely doesn't help the op, I'll throw out a couple thoughts:
1)Identify where power enters the switch system
2)Identify where power leaves the switch system to go to the light
3)If you have to, un-wire the boxes and use your meter to find both ends
of each wire. Make a drawing and put it back together properly.
Was this post useful or'd I have 1 too many beers?
P&L
Old 04-29-2016, 10:41 PM   #12
Majewski's Avatar
P&L
This method is how I've saved my sanity a few times. Oh look I have beer, cheers!
emtnut and PlugsAndLights like this.
Old 04-29-2016, 11:53 PM   #13
corn-fused
papaotis's Avatar
Rewards Points: 620
been drinkin it over myself! ill find it when i go back. thanks for the support and a couple reminders
Old 04-30-2016, 12:14 AM   #14
For the paltry sum of $4,000, I'll drive over tomorrow and fix it for you.
hardworkingstiff and Majewski like this.
cal1947 (04-30-2016)
Old 04-30-2016, 06:03 AM   #15
Retired Account
Rewards Points: 14,650
P&L
Beer makes everything better.....
Remember all the configurations we had to do back in our apprenticeship Plugs?
3way-4way-power-light.-4way-3way.
light-power-3way-4way-4way-3way.
etc etc......~CS~
emtnut likes this.
Old 04-30-2016, 06:04 AM   #16
Retired Account
I bid $3950 ......beer provided via others
Majewski likes this.
Old 04-30-2016, 08:55 AM   #17
Band Member
emtnut's Avatar
Don't you have to be less than 480 to get the job ?
chicken steve likes this.
Old 04-30-2016, 09:15 AM   #18
Rewards Points: 2,901
Meter out your 4 ways to determine which way the = and X are going. I can't remember the details now but I had one job with weird 4 ways.
PlugsAndLights likes this.
Old 04-30-2016, 09:18 AM   #19
There's no standard. Some (like Levition, I think) go side-to-side. Others (P&S) are end-to-end.
readydave8 likes this.
Old 04-30-2016, 09:28 AM   #20
Yeah, like I say, I can't remember the details but there was something weird going on that day and the only thing that solved it for me was ohming out the switches.
Is micro switch diagram correct? wes5458 Commercial Electrical Forum 4 03-28-2016 12:43 PM
Wireless Remote Switch electricguy Canadian Electrical Forum 17 03-11-2016 08:29 AM
transfer switch for generator blacknpurplejs General Electrical Discussion 2 02-21-2016 09:17 PM
light switch near shower huntingflower Canadian Electrical Forum 4 02-17-2016 07:09 AM
Rangehood operation by remote switch katwalatapan Canadian Electrical Forum 4 01-29-2016 01:37 PM
