4 way switch - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree42Likes
Old 04-30-2016, 10:20 AM   #21
Retired Account
Rewards Points: 14,650
4 ways that go both ways......hmmmm....~CS~
Old 04-30-2016, 10:37 AM   #22
cal62
Rewards Points: 93
Smile cal1947
For the paltry sum of $4,000, I'll drive over tomorrow and fix it for you.
I will fix it for $3999.99
cal1947 is offline   Reply With Quote
Old 04-30-2016, 10:48 AM   #23
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,820
I'll fix it for a new ladder rack!
Old 05-01-2016, 10:33 AM   #24
daks's Avatar
Rewards Points: 146
There's no standard. Some (like Levition, I think) go side-to-side. Others (P&S) are end-to-end.
And the 3rd format I've seen which was an X (criss cross) can't remember who made those though.
Just follow the power feed through the circuit. I.e. start at the 3 ways for problem solving the circuit.
Most common problem I see is that a 3 way has power or light fed from a traveler screw. Then if a 4 way is involved it was just wired up without following the connection instructions on the back of the switch or by ohming it out.
daks is offline   Reply With Quote
Old 05-01-2016, 11:08 AM   #25
Rewards Points: 1,360
Like was already said, tie the travelers straight through at the 4-way and see if the 3-ways are behaving properly.
Bird dog likes this.
Old 05-01-2016, 12:09 PM   #26
backstay's Avatar
Rewards Points: 296
Originally Posted by papaotis View Post
been drinkin it over myself! ill find it when i go back. thanks for the support and a couple reminders
When the elephant is sitting on your head, all you see is gray. Sometimes getting away from it and coming back you say, Hey! there's and elephant?
Old 05-01-2016, 12:12 PM   #27
gnuuser's Avatar
Rewards Points: 1,540
that depends on what part of its butt is on your head you may be seeing black and stinky
Old 05-01-2016, 12:21 PM   #28
gnuuser's Avatar
heres one way
but you could have just googled 4 way switch wiring and printed out the different jpg's and compared them to what you have.
print outs can be a help when you run into issues like that
chicken steve and Majewski like this.
Old 05-01-2016, 12:21 PM   #29
Rewards Points: 3,078
First -Disconnect the 3 ways and 4 ways. Test them with a meter.
Greg
Old 05-01-2016, 12:34 PM   #30
I own stock in FotoMat!
Rewards Points: 6,520
Originally Posted by gnuuser View Post
........print outs can be a help when you run into issues like that
Knowing how 3- and 4-ways actually work internally (mechanically and electrically) is an even bigger help.
Your diagram shows how to hook up a 4-way like a Levition. Hook up a P&S like that and it'll drive you nuts.
Old 05-01-2016, 12:41 PM   #31
Rewards Points: 21,739
The OP should go down to the Home Depot and ask the isle guy working there for assistance. He'll know how to fix it.
I stand with Tucker Carlson
Old 05-01-2016, 12:45 PM   #32
gnuuser's Avatar
true but thats only one way, and there are many different configurations
believe me the first time i ran into a 4 way circuit i about went nuts trying to figure it out
Majewski likes this.
Old 05-01-2016, 01:49 PM   #33
Majewski's Avatar
I'm still nuts from it!
Old 05-03-2016, 11:38 PM   #34
Rewards Points: 2,979
I was having problems with 4 ways today that someone else had wired. It turns out the pressure plate connections were temperamental. I wrapped the wires around the screws and they worked fine (after fixing a bad splice). Like many troubleshooting jobs, you look for one issue and it turns out you have two.
Old 05-04-2016, 05:54 AM   #35
Rewards Points: 14,714
Hey OP, how's it going? What did you find?
Old 05-04-2016, 06:11 AM   #36
Majewski's Avatar
He quit. He joined the plumbers Union. Sad day....
Jk jk
Old 05-10-2016, 09:55 PM   #37
corn-fused
papaotis's Avatar
Rewards Points: 620
a fresh start always helps! trying to remove a backstabbed switch the light kept coming on. changed the switch and everythings fine!
emtnut and Majewski like this.
Old 05-10-2016, 11:21 PM   #38
Majewski's Avatar
hmmmmm
Is micro switch diagram correct? wes5458 Commercial Electrical Forum 4 03-28-2016 12:43 PM
Wireless Remote Switch electricguy Canadian Electrical Forum 17 03-11-2016 08:29 AM
transfer switch for generator blacknpurplejs General Electrical Discussion 2 02-21-2016 09:17 PM
light switch near shower huntingflower Canadian Electrical Forum 4 02-17-2016 07:09 AM
Rangehood operation by remote switch katwalatapan Canadian Electrical Forum 4 01-29-2016 01:37 PM
